Bluetooth
Hi,
I tried to run bluetooth on lubutu but no success so far.
I installed blueman bluetooth manager but it does not recognize any new device (no adapter).
Somebody has any hint/how to?
cheers
Adam
You can post the log here and someone may help you.
Hi herbat . You need to copy the bluetooth hcd file and hciattach it first.
Here’re the instructions (run with root):
1. Mount Android system partition and copy out the AP6335 hcd file:
 # mount Android system partition
mount /dev/block/mtd/by-name/system /mnt
# mkdir for compatiblity
mkdir -p /system/vendor/firmware
# copy required hcd file
cp /mnt/vendor/firmware/bcm4339a0.hcd /system/vendor/firmware/
# umount
umount /mnt
2. Install the neccessary bluetooth packages:
apt-get install --no-install-recommends brcm-patchram-plus-nexus7 bluetooth ussp-push
3. Power on the bluetooth and do initializaion:
# Power on
cat /sys/class/rfkill/rfkill0/type   # bluetooth
echo 1 > /sys/class/rfkill/rfkill0/state
# Upload hcd file
brcm_patchram_plus -d --patchram /system/vendor/firmware/bcm4339a0.hcd --baudrate 1500000 --enable_lpm --enable_hci --no2bytes /dev/ttyS0 &
4. Wait some time until the brcm_patchram_plus settles down, then use bluez related commands to test:
root@firefly:~# hciconfig -a
hci0:	Type: BR/EDR  Bus: UART
	BD Address: 43:39:00:00:1F:AC  ACL MTU: 1021:8  SCO MTU: 64:1
	UP RUNNING PSCAN
	RX bytes:1186 acl:0 sco:0 events:39 errors:0
	TX bytes:956 acl:0 sco:0 commands:39 errors:0
	Features: 0xbf 0xfe 0xcf 0xfe 0xdb 0xff 0x7b 0x87
	Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
	Link policy: RSWITCH SNIFF
	Link mode: SLAVE ACCEPT
	Class: 0x600100
	Service Classes: Audio, Telephony
	Device Class: Computer, Uncategorized
	HCI Version: 4.0 (0x6)  Revision: 0x10c
	LMP Version: 4.0 (0x6)  Subversion: 0x6109
	Manufacturer: Broadcom Corporation (15)
hci0 should be up and running now.
5. Shutdown bluetooth.
echo 0 > /sys/class/rfkill/rfkill0/state
@busyby : thanks for answer
I came with your procedure. Adapter is working as you can see
UP RUNNING PSCAN ISCAN
RX bytes:647 acl:0 sco:0 events:36 errors:0
TX bytes:1429 acl:0 sco:0 commands:36 errors:0
Class: 0x700100
Service Classes: Object Transfer, Audio, Telephony
Unfortunately, after adding device it came with an error with paring procedure.
I am using Blueman applet 1.23 for managing my bluetooth devices.
For example, It recognized my phone (samsung galaxt s5) but it sends wrong paring codes (wrong numbers) to paring device.
This same problem I have with bluetooth keyborad (Rapoo T Series)
@herbat
I tried blueman, and it paired my phone well with correct code display.
I install it with:
sudo apt-get install blueman notify-osd
Maybe you need to launch the blueman-applet in a terminal window to see detailed log.
What an insightful article, I truly appreciate your sharing it! The New ITIL-4-DITS study materials material is top-notch, and I hope it assists you, with no cost involved.
Thank you for your article, it was incredibly thought-provoking. C_ARP2P_2508 valid test camp sheet is available to everyone for free, packed with content that can aid you.
I’m deeply appreciative of your article, it was truly enlightening. I’m sharing the Reliable GH-900 test camp free exam materials for free—best of luck!
I’m in awe of your article, thank you for sharing! The AD0-E725 exam voucher content is truly useful, and it’s all yours at no cost.
IT업계에서 자신만의 위치를 찾으려면 자격증을 많이 취득하는것이 큰 도움이 될것입니다. Oracle 인증 1z0-1054-25시험은 아주 유용한 시험입니다. Oracle 인증1z0-1054-25시험출제경향을 퍼펙트하게 연구하여Itcertkr에서는Oracle 인증1z0-1054-25시험대비덤프를 출시하였습니다. Itcertkr에서 제공해드리는Oracle 인증1z0-1054-25시험덤프는 시장에서 판매하고 있는Oracle 인증1z0-1054-25덤프중 가장 최신버전덤프로서 덤프에 있는 문제만 공부하시면 시험통과가 쉬워집니다.
