Hi!
Tested your pad version of the SDK on firefly and it works fine! Now I want to check this software on a different setup. But I I miss the original files for rockchips evaluation kits. Normally the SDKs are having these files like rk3188_defconfig or similar. But in this SDK ther is no rk3288_defconfig for the rockchip original evaluation kit.
As these kits are often used as a design example, they are good reference. Did you remove the files and can you add them to the SDK again on bitbucket or are these files not available for any special reason?
I am talking about defconfig, dtb and uboot config.
Thank you. I found the original files for the developer kits as rk3288-tb.dts and rk3288-tb_8846.dts
Furthermore I’d like to add some rk3188 devices to the repo and I made some corrections to the dts and other things in kernel and Android. So where and how can I add these to the repo?
