First successful try of the main line kernel
Table of Contents
1 Preparation
.. 1.1 Toolchain
.. 1.2 Tools
.. 1.3 Put your device into loader mode
2 U-Boot
.. 2.1 Compile U-Boot
.. 2.2 Flash U-Boot
3 Parameter file
4 Kernel
.. 4.1 Compile Kernel
.. 4.2 Flash Kernel
5 Linux rootfs
6 Initramfs
7 Reboot
8 FAQ
.. 8.1 Where’re my paritions in eMMC storage?
.. 8.2 What currently works in mainline kernel
.. 8.3 What currently not work in mainline kernel
.. 8.4 Mainline & sdk kernel difference
1 Preparation
Suppose your working directory is “~/proj/linux-rockchip”
│ mkdir -p ~/proj/linux-rockchip
1.1 Toolchain
Then copy the Android prebuilt directory to it:
│ cd ~/proj/linux-rockchip
│ cp -rl ANDROID_SDK/prebuilts .
We’re using arm-eabi-4.6 and arm-eabi-4.7 in
“prebuilts/gcc/linux-x86/arm/”.
U-Boot prefers arm-eabi-4.7 than arm-eabi-4.6, and kernel uses
arm-eabi-4.6.
1.2 Tools
Install
• rkflashtool: [https://github.com/linux-rockchip/rkflashtool]
• rkflashkit: [https://github.com/linuxerwang/rkflashkit]
• rk_upgrade_tool:
RK3288_SDK/RKTools/linux/Linux_Upgrade_Tool_v1.2/upgrade_tool
Check
[http://wiki.t-firefly.com/index.php/Firefly-RK3288/Flash_image/en] .
2 U-Boot
2.1 Compile U-Boot
Compile U-Boot first:
│ git clone https://github.com/linux-rockchip/u-boot-rockchip.git u-boot
│ cd u-boot
│ make rk3288_defconfig
│ make -j4
If U-Boot is built succeesfully, the last lines of the build process
are:
│ LD u-boot
│ OBJCOPY u-boot.bin
│ OBJCOPY u-boot.srec
│ ./tools/boot_merger --subfix “.01.bin” ./tools/rk_tools/RKBOOT/RK3288.ini
│ out:RK3288UbootLoader.bin
│ fix opt:RK3288UbootLoader_V2.19.01.bin
│ merge success(RK3288UbootLoader_V2.19.01.bin)
“RK3288UbootLoader_V2.19.01.bin” is the newly built u-boot which is
ready to flash using rk_upgrade_tool:
2.2 Flash U-Boot
│ sudo rk_upgrade_tool ul RK3288UbootLoader_V2.19.01.bin
3 Parameter file
You need the kernel partition to hold main line kernel image, and an
optional boot partition to hold initramfs (if you use it).
Below is the default dual boot parameter, which is sufficient to test
the main line kernel:
│ FIRMWARE_VER:4.4.2
│ MACHINE_MODEL:rk30sdk
│ MACHINE_ID:007
│ MANUFACTURER:RK30SDK
│ MAGIC: 0x5041524B
│ ATAG: 0x60000800
│ MACHINE: 3066
│ CHECK_MASK: 0x80
│ PWR_HLD: 0,0,A,0,1
#KERNEL_IMG: 0x62008000
#FDT_NAME: rk-kernel.dtb
#RECOVER_KEY: 1,1,0,20,0
│ CMDLINE:console=ttyFIQ0 androidboot.hardware=rk30board androidboot.console=ttyFIQ0 board.ap_has_alsa=0 root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init initrd=0x62000000,0x00800000 mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00180000@0x00092000(system),0x00002000@0x00212000(metadata),0x00200000@0x00214000(userdata),0x00620000@0x00414000(linuxroot),-@0x00a34000(user)
To fetch the parameter file of your device, run:
│ sudo rkflashkit backup @parameter parameter.txt
To flash the new parameter file to your device, run:
│ sudo rkflashkit flash @parameter parameter.txt
4 Kernel
This is naobsd’s linux-next tree with Firefly-RK3288 develpment board
support:
[https://github.com/naobsd/linux/tree/naobsd/next-20141231]
4.1 Compile Kernel
First, fetch the sources:
│ git clone -b naobsd/next-20141231 https://github.com/naobsd/linux.git kernel
kerne.img can be made with following commands:
│ cd ~/proj/linux-rockchip/kernel
│ export ARCH=arm
│ export CROSS_COMPILE=$PWD/../prebuilts/gcc/linux-x86/arm/arm-eabi-4.6/bin/arm-eabi-
│ make -j4 zImage
│ make rk3288-firefly.dtb
│ cat arch/arm/boot/zImage arch/arm/boot/dts/rk3288-firefly.dtb > zImage-dtb
│ rkcrc -k zImage-dtb kernel.img
4.2 Flash Kernel
│ sudo rkflashkit erase @resource
│ sudo rkflashkit flash @kernel kernel.img
5 Linux rootfs
Put your rootfs to the first partition of your SD-card.
If you want to change the root path, please change CONFIG_CMDLINE in
the kernel configuration file:
│ CONFIG_CMDLINE=“console=ttyS2,115200 earlyprintk init=/sbin/init root=/dev/mmcblk0p1 rootwait”
6 Initramfs
If you want to use initramfs, please use rkcrc to pack it first, then
flash it to boot partition
│ rkcrc -k initramfs.img boot.img
│ sudo rkflashkit flash @boot boot.img
7 Reboot
Insert the SD-card, and reboot the device with:
│ sudo rkflashkit reboot
8 FAQ
The main line kernel does not support rk style partition scheme which
uses command line to specify partition layout.
• USB
• TF-CARD
• Ethernet
• HDMI
• WiFi
mainline sdk
console /dev/ttyS2 /dev/ttyFIQ0
Many thanks to the linux-rockchip community!
you can use more up-to-date gcc for mainline kernel. currently I’m using gcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux fromhttp://www.linaro.org/downloads/
I prepared new patch here https://github.com/naobsd/linux/tree/naobsd/next-20150114
gmac (GbE) works now, but it seems sdmmc has a problem…
https://github.com/naobsd/linux/tree/na … t-20150123
this version fixes sdmmc issue. please use this.
I hope this version will be merged into upstream…
Hello,
Have anyone ported Debian/Ubuntu with kernel 3.19 with firefly…
I will appreciate if any one can suggest me in brief how I can do it .
thanks in advance ..
Hello,
any existing root file system image will work, or you may make your own root file system with debootstrap or similar common tools.
minor modification may be needed, but it should be minor.
What an insightful article, I truly appreciate your sharing it! Free Exam 156-836 actual tests materials are here. Best of luck in your exams!
I am deeply inspired by this article, thanks for sharing! Reliable test Sustainable-Investing cram sheet file offers a wealth of content and is available for free, hoping it assists you.
I can’t express how much I appreciate your article, it was truly memorable. This is the Valid study guide GICSP book exam that helped me get promoted and earn a pay raise. It’s available for free today—good luck with your career goals!
What an impressive article, thank you for sharing your wisdom! I’m sharing AWS-Certified-Developer-Associate latest study guide resources for free. Wishing you all the best!
