I received my Firefly RK3288 a few days ago and have been running XBMC in Android. When connected through a wired LAN cable to my home network, streaming playback is often halting for “Buffering…X%”. Disconnecting the cable, running wifi instead gives better, albeit not perfect, performance. Today I measured the network speed on the four different variants and the results were as follows:
Wifi Wired
Android 40-50 Mbps 2-3 Mbps
Lubuntu 40-50 Mbps 40-50 Mbps
For some reason the wired LAN connection doesn’t work properly under Android, while I get not problem under Lubuntu. Hence, it doesn’t look as if it is hardware related.
I got exactly the same problem here under android AND linux. here are my statements . Network transfert is ugly when speed is 1000 FULL Negociated or Fixed.
If you force 100/Full on your interface (i dont know how to make it on Android) iperf indicated about 90MB.
I dont know if it’s hardware side or kernel side but the problem is here with all linux/android (even self compile) image i tried. I tried with an other giga switch , problem is the same.
I dont know if Firefly staff is around but i never receive “Real” answer for my problem
I tried modified parameter, But it is not working on Ubuntu with modified 0x16 rx_delay. It works only for minutes with eth0 gigabit interface, and it stops network functionality. It is very unstable on Ubuntu.?
I tried on Unbuntu with this delay but I stops network functionality. Do you have any problem with 0x16 rx_delay? Could you let me know to how to fix a slow problem on Unbuntu?
I’m in awe of your article, thank you for sharing! We’re providing Test C_ABAPD_2507 dates at no cost, packed with rich material to support your learning.
Your article has left me in awe, thank you for sharing such a gem! Upgrade your IT knowledge with free Latest 1z0-1057-25 exam forum. Wishing you all the best!
I’m deeply moved by this article, thank you for sharing it! Exam DEP-2025 collection pdf has fantastic materials, and it’s offered to you free of charge.
