compiled sdk not booting with update.img
Hey guys I have a quick question maybe someone here can help me out. When I upload my kernel, boot,system ,misc the system works fine as it should but when I upload update.img the box doesn’t boot at all.
If i replace my resource.img with the original one from the firefly? extracted from the firmware and make my new firmware the box boots no problems. Is there something special needing done with resource.img. I was debugging a little and i noticed my??resource.img unpacked fine with ? kernel/resource_tool --unpack resource.img but the firefly one didn’t is there anything special we need to do to this file to make the box boot properly
Our resource.img can be unpacked using following instructions:
~$ mkdir /tmp/t
~$ cd /tmp/t
/tmp/t$ cp ~/proj/firefly-44/kernel/resource.img .
/tmp/t$ ~/proj/firefly-44/kernel/resource_tool --unpack .
Dump header:
partition version:0.0
header size:1
index tbl:
offset:1 entry size:1 entry num:2
Dump Index table:
entry(0):
path:rk-kernel.dtb
offset:3 size:98693
entry(1):
offset:196 size:17184
Unack resource.img to . successed!
/tmp/t$ ls -l
total 236
-rw-r–r-- 1 djw users 17184 1月 14 14:45 logo.bmp
-rw-r–r-- 1 djw users 117760 1月 14 14:45 resource.img
-rw-r–r-- 1 djw users 98693 1月 14 14:45 rk-kernel.dtb
/tmp/t$ ~/proj/firefly-44/kernel/scripts/dtc/dtc -I dtb rk-kernel.dtb -O dts -o firefly-rk3288-kernel.dts
/tmp/t$ head firefly-rk3288-kernel.dts
/dts-v1/;
#address-cells = <0x1>;
#size-cells = <0x1>;
compatible = “rockchip,rk3288”;
rockchip,sram = <0x1>;
interrupt-parent = <0x2>;
chosen {
The resource.img contains a bitmap and a dtb. Please check your compiling.
Hi sorry I though I posted to this earlier. I done somethign to the sdk it was my bad. Im not sure what i done but I just re downloaded it and all is well now. Thanks for the reply. Everythign is working as it should be. I have one more question though if you done mind. If i compile a new resource.dat is there any way to upload it on with Linux_Upgrade_Tool_v1.2 I dont seen any option for it. I have to flash a full firmware every time. It seems the windows AndroidTool Release v2.3 supports this only problem is its just a quick re flashing the firmware by the time you copy the files to a windows partition and reboot.
Please try:
sudo?upgrade_tool di resource /path/to/resource.img
I really appreciate your article, it has been truly eye-opening. Free CPMAI valid vce exam simulator available for improving your IT skills. Wishing you the best!
Thank you for your article, it was a true eye-opener. This is the Reliable C1000-189 exam pattern test that led to my promotion and salary raise. It’s free for you today—hope you succeed in your career pursuits!
I was so impressed by the quality of the article. Free Valid exam CTFL-AcT registration to help you enhance your IT skills. Wishing you good luck!
Thank you for your article; it really opened my eyes. Sharing Real CFE-Financial-Transactions-and-Fraud-Schemes question materials for free with you all—best of luck!
ExamPassdump를 검색을 통해 클릭하게된 지금 이 순간 IT인증자격증취득Fortinet NSE7_SOC_AR-7.6시험은 더는 힘든 일이 아닙니다. 다른 분들이Fortinet NSE7_SOC_AR-7.6시험준비로 수없는 고민을 할때 고객님은 저희 Fortinet NSE7_SOC_AR-7.6덤프로 제일 빠른 시일내에 시험을 패스하여 자격증을 손에 넣을수 있습니다.
Jpshikenは、理論と実践の最新の開発に基づいた深い経験を持つ専門家によってコンパイルされたCGSS試験材料の高い合格率を提供するため、非常に価値があります。 CGSSトレーニングブレインダンプを試してから、CGSSスタディガイドを購入する前に、ウェブ上で無料のデモをご覧ください。 Certified Global Sanctions Specialist試験の合格に役立つだけでなく、時間とエネルギーを節約できるため、CGSS試験の準備を購入する価値があります。
I’m all in for this content—instant like. Free 400-007 valid braindumps files exam papers—your path to promotion and salary increase!
