Audio passthrough with HDMI or SPDIF
Hi Guys,
here is me again with a new question.Passthrough (HDMI or SPDIF) dont seems to work. I got no sound on my receiver when i select those parameters.
Here is the sound section of my kernel config
CONFIG_SOUND=y
# CONFIG_SOUND_OSS_CORE is not set
CONFIG_SND=y
CONFIG_SND_TIMER=y
CONFIG_SND_PCM=y
CONFIG_SND_HWDEP=y
CONFIG_SND_RAWMIDI=y
CONFIG_SND_COMPRESS_OFFLOAD=y
CONFIG_SND_JACK=y
# CONFIG_SND_SEQUENCER is not set
# CONFIG_SND_MIXER_OSS is not set
# CONFIG_SND_PCM_OSS is not set
# CONFIG_SND_HRTIMER is not set
# CONFIG_SND_DYNAMIC_MINORS is not set
# CONFIG_SND_SUPPORT_OLD_API is not set
CONFIG_SND_VERBOSE_PROCFS=y
CONFIG_SND_VERBOSE_PRINTK=y
# CONFIG_SND_DEBUG is not set
# CONFIG_SND_RAWMIDI_SEQ is not set
# CONFIG_SND_OPL3_LIB_SEQ is not set
# CONFIG_SND_OPL4_LIB_SEQ is not set
# CONFIG_SND_SBAWE_SEQ is not set
# CONFIG_SND_EMU10K1_SEQ is not set
# CONFIG_SND_DRIVERS is not set
# CONFIG_SND_ARM is not set
# CONFIG_SND_SPI is not set
CONFIG_SND_USB=y
CONFIG_SND_USB_AUDIO=y
# CONFIG_SND_USB_UA101 is not set
# CONFIG_SND_USB_CAIAQ is not set
# CONFIG_SND_USB_6FIRE is not set
CONFIG_SND_SOC=y
CONFIG_SND_SOC_DMAENGINE_PCM=y
CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y
# CONFIG_SND_ATMEL_SOC is not set
# CONFIG_SND_DESIGNWARE_I2S is not set
CONFIG_SND_RK_SOC=y
CONFIG_SND_RK_SOC_I2S=y
CONFIG_SND_RK_SOC_SPDIF=y
CONFIG_SND_RK_SOC_CARD_SPDIF=y
# CONFIG_SND_RK_SOC_AK4396 is not set
CONFIG_SND_RK_SOC_ES8323=y
# CONFIG_SND_SOC_ES8323_PCM is not set
# CONFIG_SND_RK_SOC_WM8988 is not set
# CONFIG_SND_RK_SOC_WM8900 is not set
# CONFIG_SND_RK_SOC_RT5512 is not set
# CONFIG_SND_RK_SOC_CX2070X is not set
# CONFIG_SND_RK_SOC_RT5621 is not set
# CONFIG_SND_RK_SOC_RT5623 is not set
# CONFIG_SND_RK_SOC_RT5631 is not set
# CONFIG_SND_RK_SOC_RT5631_PHONE is not set
# CONFIG_SND_RK_SOC_RT5625 is not set
# CONFIG_SND_RK_SOC_RT5640 is not set
# CONFIG_SND_RK_SOC_RT3224 is not set
# CONFIG_SND_RK_SOC_RT5639 is not set
# CONFIG_SND_RK_SOC_RT5616 is not set
# CONFIG_SND_RK_SOC_RT3261 is not set
# CONFIG_SND_RK_SOC_CS42L52 is not set
# CONFIG_SND_RK_SOC_AIC3111 is not set
# CONFIG_SND_RK_SOC_AIC3262 is not set
# CONFIG_SND_RK_SOC_RK1000 is not set
# CONFIG_SND_RK_SOC_RK3190 is not set
CONFIG_SND_SOC_I2C_AND_SPI=y
# CONFIG_SND_SOC_ALL_CODECS is not set
CONFIG_SND_SOC_ES8323=y
CONFIG_SND_SOC_HDMI_SPDIF=y
# CONFIG_SND_SIMPLE_CARD is not set
# CONFIG_SOUND_PRIME is not set
Is there something i must activate ?
Best regards
Pacopad
Passthrough only works on the latest firmware.
where is the latest firmware? i had instaled Firefly-RK3288_DualBoot_201412111722.img (the latest) and passthrough don′t work.
Can you help me?
I also tried Firefly-RK3288_Android4.4_201412111722.img and don′t work audio passthrough!
Any one have a solution? I need a dual boot image android/linux that works spdif audio passthrough in android. Have anyone an image file or a solution to upgrade my software?
Thanks
João Xavier
which audio format you test., dts/ac3?
Yes, dts ac3, dolby digital, and none of them work!
I check in settings → about the device->firmware->update and i have the latest firmware !
I try ugoos and rikomagic firmware and they work fine so the problem is firefly android firmware.
Any one have an idea or a solution for the problem?
Thanks
João Xavier
Itcertkr에서 제공되는NREMT EMT인증시험덤프의 문제와 답은 실제시험의 문제와 답과 아주 유사합니다. 아니 거이 같습니다. 우리Itcertkr의 덤프를 사용한다면 우리는 일년무료 업뎃서비스를 제공하고 또 100%통과 율을 장담합니다. 만약 여러분이 시험에서 떨어졌다면 우리는 덤프비용전액을 환불해드립니다.
I’m in awe of the quality of your article, thank you for sharing it! This D-PSC-DY-23 latest exam sample online helped me advance in my career and get a raise. Now it’s available for free. Wishing you all the best in your professional journeys!
Thank you for the article, it really broadened my outlook. Free Latest CMMC-CCP exam pattern exam papers—good luck with your preparation!
I really appreciate your article, it has been an eye-opening experience. Comm-Dev-101 sure pass offers detailed and free content, aimed at assisting you with your goals.
The article is full of motivational insights, thank you for sharing! The Reliable L5M15 exam camp pdf helped me secure a promotion and raise. Now it’s free to everyone. Wishing you all a bright future in your careers!
