On rk3288
What is kernel.img file? Is it ramdisk.img + uImage ? if yes, why don’t we call it as boot.img ? what are the core changes in uboot to make it rkboot? Has any one tried Rootfs over NFS, if so what parameters should be passed as bootargs, the default bootcmd is set to bootrk and looks nand flash partions needs to be passed as CMDLINE
Tried with
setenv bootargs “androidboot.hardware=rk30board androidboot.console=ttyFIQ0 console=ttyFIQ0,115200n8 ip=dhcp init=init noinitrd root=/dev/nfs rw nfsroot=IPaddr:/ifs/fs/firefly/rootfs,tcp,v3”
Kernel boots and starts crashing at MTD partitions
Hi,
have you ever solved this issue? I’m also trying to use NFS but it seems to fail. Could someone show me a correct CMDLINE to use NFS? Is there a way to add tftp support to bootrk?
thanks
Andrea
Fast2test이 바로 아주 좋은Microsoft SC-300인증시험덤프를 제공할 수 있는 사이트입니다. Fast2test 의 덤프자료는 IT관련지식이 없는 혹은 적은 분들이 고난의도인Microsoft SC-300인증시험을 패스할 수 있습니다. 만약Fast2test에서 제공하는Microsoft SC-300인증시험덤프를 장바구니에 넣는다면 여러분은 많은 시간과 정신력을 절약하실 수 있습니다. 우리Fast2test 의Microsoft SC-300인증시험덤프는 Fast2test전문적으로Microsoft SC-300인증시험대비로 만들어진 최고의 자료입니다.
Information-Technology-Managementクイズガイドは、毎年の質問の調査と分析を通じて、多くの隠れたルールを調査する価値があることがわかりました。さらに、強力な専門家チームがあるため、ルールを要約して使用できます。 Information-Technology-Managementトレントの準備は、毎年の質問の分析に基づいて行うことができ、近年の関連知識と組み合わせて、資格試験に関連する一連の重要な結論が結論付けられます。 Information-Technology-Managementテスト資料は、今年のトピックと提案の傾向を正確に予測する能力を向上させ、Information-Technology-Management試験に合格するのに役立ちます。
Thank you for your powerful article, it left a lasting impression. Free Positive AP-212 feedback exam resources are available now—good luck!
Your article is absolutely stunning, I’m so grateful for your share! Free Test NS0-528 cram pdf resources are shared—good luck to all!
