Is max clock frequency 24MHz? 14MHz?
A summary of the frequency ratio restrictions between the bit-rate clock (sclk_out / sclk_in) and the SPI peripheral clock (spi_clk) are described as,
When SPI Controller works as master, the Fspi_clk>= 2 × (maximum Fsclk_out)
When SPI Controller works as slave, the Fspi_clk>= 6 × (maximum Fsclk_in)
zhansb Posted at 3/30/2015 14:19
A summary of the frequency ratio restrictions between the bit-rate clock (sclk_out / scl …
what is the maximun Fspi_clk?
What an incredible article, thank you for letting us read it. The 350-601 valid exam pass4sure test questions are now available for free—your career success is just a step away!
Thank you for your insightful article, it really left a mark. The Hot C_ABAPD_2507 questions questions are crucial for your promotion and salary raise—now available for free!
The article is full of inspiration, thank you for sharing it! Get the 312-50 reliable new test format test questions for free—your promotion and salary boost are within reach!
