can not power up SDA7123
I want to work VGA output.
HSYNC/VSYNC is working.
But Color-Signal not working.
I check SDA7123(LCD to VGA).
PSAVE signal is 1.1V. (not 3.3V)
I tryed.
PMUGPIO0_c1 is enabled.
GOIO0_C1 set to ‘1’.
How do I ?
Additional,
I was done following.
CRU_CLKSEL27_CON <= 0xff008000 /* LCDC clock prescale */
/* following is written on VOP manual(IO_MUX setting). /
GRF_GPIO1D_IOMUX <= 0x00550055
GRF_GPIO1H_SR <= 0x0f000f00
GRF_GPIO1D_E <= 0x00ff00ff
GRF_SOC_CON6 <= 0x00080000
GRF_SOC_CON7 <= 0x1fff1840
for LVDS (for LCDC) /
lvds+0x00
4 <= 0x7f
lvds+0x014 <= 0x40
lvds+0x02
4 <= 0x00
lvds+0x034 <= 0x46
lvds+0x04
4 <= 0x3f
lvds+0x054 <= 0x3f
lvds+0x0d
4 <= 0x0a
lvds+0x404 <= 0x7f
lvds+0x41
4 <= 0x40
lvds+0x424 <= 0x00
lvds+0x43
4 <= 0x46
lvds+0x444 <= 0x3f
lvds+0x45
4 <= 0x3f
lvds+0x4d*4 <= 0x0a
/* this is setting for SDA7123 PSAVE pin */
PMU_GPIO0_C_PULL <= 0x3ff
PMU_GPIO0_C_DRV <= 0x3f
PMU_GPIO0_C_IOMUX <= 0x00000000
/* following is VOP manual (RGBsetting) /
VOP_SYS_CTRL <= VOP_SYS_CTRL | (0x01u<<21) /
VOP DMA on /
following is default setting (may be MCGA) /
VOP_DSP_HTOTAL_HS_END
VOP_DSP_HACT_ST_END
VOP_DSP_VTOTAL_HS_END
VOP_DSP_VACT_ST_END
VOP_DSP_VS_ST_END_F1
VOP_DSP_VACT_ST_END_F1
VOP_DSP_BG<= (0xff<<20)|(0x3f<<10)|(0xf) /
background color /
VOP_REG_CFG_DONE<= 0x01 /
DONE!! */
I was resolved myself.
I did not set GPIO direction and GPIO output.
I did miss-coding.
(And little mistake)
I was modified my-code, VGA-output OK!!
