I managed to brick my Firefly RK3288. Whatever I do (erase flash, low level format, try to update with other images), I cannot seem to get it to boot into anything.
However, I do not get to load the OS from the card, what happens is that when SD card is inside, the system uses it’s boot image to load the OS on eMMC (not on the SD card).
So - is there a way to re-flash the boot (or everything) back into the eMMC so that it can start up without SD card?
How did you know the OS is loaded from eMMC when SD card is inserted?
When a bootable SD card is inserted, Firefly will boot from SD card(i.e load related images from SD card).
This article is remarkable, thank you for sharing it with me. I used the 500-560 test dumps.zip to get promoted and earn more. Now, it’s available for free. Best of luck with your career!
