Dear Developers,
Actually today (25.05.2015), does the Firefly RK3288 supports the portrait mode in Android or in Lubuntu? Any third party distros which support the Portrait mode?
Thank you in advance, Vlad.
Dear Developers,
Hello,
Revert “Android->frameworks:Forced rotation to horizontal screen if insert hdmi”
This reverts commit 137bead4fffd7f212ee144456420933d54fbd0ef.
diff --git a/frameworks/base/policy/src/com/android/internal/policy/impl/PhoneWindowManager.java b/frameworks/base/policy/src/com/android/intern
index 53e7068..fc80328 100755
— a/frameworks/base/policy/src/com/android/internal/policy/impl/PhoneWindowManager.java
+++ b/frameworks/base/policy/src/com/android/internal/policy/impl/PhoneWindowManager.java
@@ -1112,7 +1112,7 @@ public class PhoneWindowManager implements WindowManagerPolicy {
} else {
mDemoHdmiRotation = mLandscapeRotation;
mDemoHdmiRotationLock = SystemProperties.getBoolean("persist.demo.hdmirotationlock", true);
mDemoHdmiRotationLock = SystemProperties.getBoolean("persist.demo.hdmirotationlock", false);
you can chance the “true” to “false” or git revert it
Hello Madman, thank you very much for quick reply…
It takes time for me but I have compiled a system image, a kernel image etc… I’ve got all required images and furthermore I’ve built a new complete image.
However, despite all my efforts, I’ve got the same error message as those from this discussion: http://bbs.t-firefly.com/forum.php?mod=viewthread&tid=306.
All my similar attempts to fix the issue give me nothing. The board is still in the loop. My attempt to write FirFly original images for the latest Android image as well as for the Dual boot image gives my the same loop.
To clarify, I write parameters file by using the Android Tool release 2.33. It doesn;t work - the same loop. After that, I have made a full image by unpacking the latest Android image I have downloaded from your website and packed it back with my boot.img, kernel.img, misc.img. recovery.img, resource.img, system.img in Ubunut 14.10. In this time RKBatchTool v.1.7 wrote the image but I still got the loop.
Hereby is the text of the loop, which ends by a string “OUT” and after that it repeats the same again and again:
**************** Start of the boot listing *****************************
U-Boot 2014.10-RK3288-02 (Jan 21 2015 - 17:07:53)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 300000000HZ
ddr pll = 200000000HZ
codec pll = 594000000HZ
DRAM: Found dram banks:1
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_ID:007!
power key: bank-0 pin-5
light power led: bank-8 pin-1
pmic:act8846
#Boot ver: 2015-01-21#2.17
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
got recovery cmd from misc.
failed to load fdt from recovery!
kernel @ 0x02000000 (0x00653540)
ramdisk @ 0x04bf0000 (0x003dc705)
Secure Boot state: 0
bootrk: do_bootm_linux…
Loading Device Tree to 04808000, end 04826935 … OK
DDR Version 1.00 20141007
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
******************** End of the boot listing *********************
By now the card is dead as I cannot use it. Please give me any idea how I can fix it?
I used Windows and Linux tools - the same result. It looks like the card doesn’t allow to write parameters file and thus it cycled in the boot sequence.
Thank you for any help,
Vlad.
I opened a new topic as follows: http://bbs.t-firefly.com/forum.php?mod=viewthread&tid=559
Well, In my case, the reason of the kernel loop was the power cable. I took a USB cable from Cubieboard and it power up the board just to flash. However, as soon as the board starts, the board doesn’t have enough power and the board reboots.
All of a sudden, I realized, I have another USB cable, the original one. As soon as I replaced the power cable, the board starts working and the boot continues…
By now, I can confirm the board can work in “Portrait mode” as flashing the new compiled image brought me the board in the Portrait mode even at the boot…
Thank you for your guidance,
Vlad.
It looks like the code change doesn’t work in not pad versin of the firmware. Can you clarify what shell I change in non pad version of the firmware?
Thank you, Vlad.
Could the problem be Drupal? Perhaps you should contact a professional who can offer Drupal maintenance services, and that way your problem will surely be resolved. What do you think? Wouldn’t this work as a solution? At least consider what I just told you. It may be the solution to your problem. I hope my comment is helpful. Best regards.
Migrating from Drupal can be complex, especially when dealing with version upgrades, module compatibility, and data integrity. Issues like deprecated features, custom code adjustments, and performance optimizations often arise, requiring careful planning. If you’re facing difficulties, professional assistance can make the process smoother. I recommend checking out drupal migration services, where experts can handle everything from site audits to full-scale migrations. A structured approach ensures security, functionality, and a seamless transition.
Updating Drupal is a serious thing. Especially since version 7. It has a completely different code base. I tried several times to do it myself, but still ended up with something not working correctly. Thank you for the link. I could use tech support for this cms right now.
Exactly what Diana92 recommended is what we were all looking for, a serious company that offers 100% professional Drupal migration services, right? Seriously, thank you very much. I’ve been looking for a company like that for days and I can’t believe I finally found it here thanks to you. You are the best Diana92. I love you very much. You should read the message I left you. I assure you that we will get along well and it will be the beginning of a great friendship. Believe me.
I just saw this post, I’m shocked at how many comments there are in one place, I think it’s great that everyone has joined together to start commenting on a chain in which everyone helps each other until they find the best answer and the best help, I find it extremely fascinating, seriously, I would like to contribute something on my part but the truth is that I don’t have much to contribute sincerely more than what has already been said.
当社の唯一の目的は、各顧客が試験に合格するのを支援するとともに、短時間で重要な認定を取得することです。試験に合格し、自分にとって非常に重要なNonprofit-Cloud-Consultant-JPN認定を取得したい場合は、当社のNonprofit-Cloud-Consultant-JPN認定準備資料を選択して、試験の理解を深めることを強くお勧めします。あなたが準備するつもりです。弊社からNonprofit-Cloud-Consultant-JPN試験教材を購入することに決めた場合、試験に合格し、他の人よりもリラックスした方法で認定資格を取得できると考えています。
After reading this article, my work thoughts have become clearer. Wishing myself all the best for the Reliable AP-220 exam duration exam!
It offered a wealth of insights I hadn’t considered before. Enhance your IT expertise and get free Reliable study questions H19-427_V1.0-ENU sheet. Wishing you all the best!
"Vlad, thanks for sharing such a detailed account of your debugging journey—especially the part about the power cable causing the boot loop! That’s a classic hardware lesson that many of us have learned the hard way. Your experience with forcing the display orientation is really interesting for anyone working on custom Android or Linux builds for specific devices.
In my own projects, I’ve been exploring how different display orientations can affect user interaction, particularly for devices used in digital signage or kiosks that might show video content. Lately, I’ve been experimenting with AI tools like Crevid.ai to quickly generate test video content in various aspect ratios (like portrait mode for vertical screens) to see how different orientations impact the viewing experience. It’s amazing how these modern tools can speed up the prototyping phase for hardware-software integration.
Thanks again for sharing your solution—it’s a great reference for the community!"
