FirePrime with Android5.1+Ubuntu15.04 will be avilibale
FirePrime support the latest Android5.1 and Ubuntu15.04!FirePrime is core board combined with backplane, core board is on the basis of standard PCIE interface design, with minimum function!
FirePrime’s :RK3128
Excellent ability of image processing
The latest Android5.1 and Ubuntu15.04 dual system
Core-board combines with Backplane
LPDDR2+Nandfls
Excellent network function
More interface
Firefly WeChat:fireflytee
Firefly:http://www.t-firefly.com
Firefly community:http://developer.t-firefly.com
Guess we should have a Firefly Kernel soon. The RockChip SDK can be found here https://bitbucket.org/T-Firefly/firenow-lollipop but this is only for the newer chips with the RK32xx and RK31xx are listed as generic.
cappybob Posted at 6/7/2015 04:35
Looks nice :slight_smile:
Did you ever thought of providing different CPU daughter boards with the same connectivity, for instance a daughter board equipped with an RK3288 processor? Or maybe later processors based on 64 bits ARM cores (Cortex A57 and A72)?
Thx
FesterBester38 Posted at 6/8/2015 16:34
Looks nice
Did you ever thought of providing different CPU daughter boards with the same con …
FesterBester,
I AGREE, but am not seeing Sata, USB 3, and etc need to be added also. The 3288 has fallen through the “no more any support hole”. Newer chip soc’s will be 64 bit (AMD), x86, and etc. to be build compliant with the big chip Companies Hierarchies and also with new android Hierarchies which started with Android build 5. I am not buying anything for awhile until “M” comes out and is on the shelf for awhile. Tired of being left with no support for what I have and I do not like AMD and Intel their open source sucks past, now, and in the future.
MSoft is still the same, asked for some files for their new RK adventure and was rewarded with a return E-Mail with all the licensing agreements reminding me to read them. Open source is going good-bye fairly fast.
Dear Firefly
Could you recommended a JTAG debugger for Your Products, fireprime.
Because, Now We’re developing a new products based on fireprime with Android 5.1.
We need to debugging and developing the Linux device driver.
Thank you.
