Hi everyone,
I am working on some modifications on the kernel device-tree (Firefly) and as the kernel re-compilation ends, the new images kernel.img and resources.img are ready to be flashed.
Using the Rockchip tools (AndroidTool v2.3 for Windows) I can successfully flash these images on the board however changes do not take effect.
Looking at the bash script mkimage.sh, developers can decide to create an OTA compatible boot image (boot.img) and same for the recovery image (recovery.img) which can also contain the kernel image itself.
In case boot.img and/or recovery.img already contain the kernel image, will flashing a stand-alone kernel.img be ignored until new boot.img/recovery.img are flashed as well?
Thank you!
If boot.img contains kernel (OTA mode), it will take precedence over kernel.img, which means kernel.img is always ignored.
I have always been told that one will have to also tick on the parameter to reenter the new Kernel and Resource.img’s. I assume that this will show where to load these .img’s in the partician.
later----cappybob
Thanks folks!
In the end, I solved the problem by compiling the full Android SDK and creating (then flashing) a boot.img without kernel - now every time I flash a modified kernel.img and resource.img the new kernel (and device tree) are correctly initialised!
Your article really shocked me; thank you for sharing! The MSP-Foundation vce torrent materials are excellent, and they’re totally free.
200-201テスト資料の評価システムはスマートで非常に強力です。まず、当社の研究者は、200-201テスト問題のデータスコアリングシステムが実用性のテストに耐えられるようにするために多大な努力を払ってきました。学習タスクを完了してトレーニング結果を送信すると、評価システムは200-201試験トレントのマークの統計的評価を迅速かつ正確に実行し始めます。これにより、学習タスクを適切に調整し、対象の学習に集中できます200-201テストの質問があるタスク。
This content is outstanding, and my like is locked in. The Exam Workday-Pro-HCM-Core assessment content is outstanding, and it’s available at no charge.
