Hello,
Does anyone knows of a command that would work with the stock Ubuntu release to read processor cores temperature?
Thanks
Hello,
Thanks
I have not (yet) tried, but you should be able to use lm-sensors on Ubuntu → http://www.lm-sensors.org
Alternatively, check in the filesystem location /proc - there might be a binding to CPU related details (e.g. /proc/cpuinfo) which also reports temperatures - also check /sys/class/thermal/ if it does exist.
This assumes that the kernel you’re running is properly built to read temperatures from the SoC.
return0 Posted at 7/1/2015 07:54
I have not (yet) tried, but you should be able to use lm-sensors on Ubuntu → http://www.lm-sensors. …
Thank you,
I’ll give a try to lm-sensors asap.
In the meantime I found a set of pseudo-files such as:
/sys/class/hwmon/hwmon0/device/temp0_input
When I “cat” the file I get a sensible result (between 40 and 62 depending on the load). There are also temp<1 to 3>_input files, but a “cat” yields the same result whatever the index. I’m wondering if there are several temperature sensors inside the RK3288 - say one sensor for each core.
It’s very possible that there are multiple temperature sensors in an SoC - specifically for the RK3288, there is a sensors controller which supports up to 4 individual sensors → http://bbs.t-firefly.com/forum.php?mod=attachment&aid=NTc0fDNlNTUxNmEzfDE0MzU3NTQ3Njh8MzA2M3wyNzU%3D
Some of the temperatures that you see might be reported by the kernel but not related to any hardware components in particular - the kernel often shows random battery temperature on boards where there is absolutely no battery connected, for example. This is basically because with one kernel for that particular SoC architecture (say, RK3288) you can support different applications (e.g. mobile or dev board) without much porting effort.
FesterBester38 Posted at 7/1/2015 16:55
In the meantime I found a set of pseudo-files such as:/sys/class/hwmon/hwmon0/device/temp0_input
from TRM
The system has three Temperature Sensors, channel0 is reserve, and channel 1is for CPU, and
channel 2 is for GPU.
if your system is well stable(no or constant workload), it might report same values.
it’s very hardware component(SoC) related sensor. it’s not random temperature, not for different applications.
What are you referring to, exactly?
Uh? Perhaps you want to clarify where the temperature below is read from then (Firefly RK3288):
root@rk3288:/sys/class/hwmon/hwmon1 # cat name; cat temp1_input
test_battery
2600
Same SoC, different device, no battery (SunChip CX929):
battery
1400
This one also does not look SoC related to me (P90HD RK3288):
root@p90hd:/sys/class/hwmon/hwmon0 # cat name; cat temp1_input
battery
28500
I gave a try to lm-sensors but it returns temperature equal to 0 for tsadc. The same for the GUI tool Psensor (maybe that Psensor is based on lm-sensors?).
If I “cd” to “/sys/class/hwmon/hwmon0/device” and then type “cat name; cat temp0_input;… cat temp3_input”
I get :
rockchip-tsadc
42
43
42
42
Of course the values displayed vary with the current load but they stay close to each other. If I have correctly understood the TSADC chapter of the TRM the temp0_input could be the “reserved” channel, the temp1_input could be the CPU channel, and the temp2_input the GPU.
FesterBester38 Posted at 7/2/2015 21:04
I gave a try to lm-sensors but it returns temperature equal to 0 for tsadc. The same for the G …
Hi, probably lm_sensors does not support the TS-ADC embedded into the RK3288
- yes most GUIs for temperature monitoring in Linux rely on lm_sensors.
An idea to help you find out which temperature actually relates to the CPU is to run a stress-test that only involves CPU processing and not GPU at all - in theory, you should observe the CPU temp increasing while the GPU temp should remain noticeably lower.
For example, try the excellent “stress” and “cpuburn” programs which should be available via package manager in Ubuntu (hopefully for ARM architecture).
http://manpages.ubuntu.com/manpages/trusty/en/man1/stress.1.html
http://manpages.ubuntu.com/manpages/utopic/en/man1/cpuburn.1.html
The fact is also that these sensors are very close to each others in the SoC package, so it is unlikely to see a very high CPU temp and low GPU temp (and vice versa).
For the sake of experimenting, I verified that all the 4 available temperatures (excluding test_battery) temp0_input to temp3_input, remain relatively close in value when the CPU is performing stress-benchmarks.
Definitely a useful Android app: https://play.google.com/store/apps/details?id=com.into.stability&hl=en
I sincerely thank you for sharing; the article is truly fantastic! The Valid NCE-ABE guide files helped me secure a promotion and raise. It’s now free to all. Wishing you success in your promotion journey!
This article is incredibly thought-provoking, thank you for sharing! I owe my career success to the New NCP-MCA exam topics pdf test, and now I’m sharing it with you free of charge!
Your article was such a pleasant surprise, thank you! The Exam PL-300 name test led to my promotion and salary increase. Today, I’m giving it away for free to help you too!
I’m so impressed by your article, thank you for your amazing share! CISM valid exam braindumps provides excellent materials, and they are free to access.
I’m in awe of your insights, thank you for sharing your article! Wishing you all the best! Here’s the free C-P2WAB-2507 latest real test material.
This article is absolutely amazing, thank you for sharing it with us. Sharpen your IT knowledge with free FCSS_ADA_AR-6.7 reliable test dumps sheet. Best of luck to you!
