Hi,
I have modified the Android SD_Card image of RT3288 device to add an APK file as the Firefly wiki was explained.
I have unpacked the image, customized it by adding the an APK, packed it again and have loaded into the SD card…
De vice was booted from SD card however the Android asks for decryption password!
Why it is asking for encryption password? how can I pass it? or what is the Firefly RT3288 ‘system.img’ ext4 password which Android complains?
I actually added 128MB to SYSTEM but didn’t changed the system address from 0x00180000 (768) to something like 0x001C0000 (768+128).
Should I change the address in “parameter” file?!
I assume the system size is not more than the one provided so no need to change.
Am I correct?
Guys,
Just backed to this Post to help you not confusing.
At the time of writing this post I almost did know nothing about partitioning of Firefly RK3288.
Now that I am Guru in it, and have written the app to get the most out of it, I can confirm that my partitioning was wrong definitely.
I had added 128mb to System partition and didn’t change the partition parameter to make the right partition size for it.
In fact it altered part of system partition and that was why the system didn’t work fine…
Any way, use my tool and make your own ‘parameter’ file, error free …
Your article is nothing less than magnificent, thank you for sharing! This is the HPE7-A03 study materials review exam I passed for my promotion and salary raise. It’s free for you today—hope you reach your career milestones!
I’m simply in awe of your article, thank you for sharing such brilliance! I’m gearing up for the Braindumps C1000-173 pdf exam! Wish me luck, everyone!
Fortinet FCSS_SASE_AD-25시험이 정말 어렵다는 말을 많이 들으신 만큼 저희 ExamPassdump는Fortinet FCSS_SASE_AD-25덤프만 있으면Fortinet FCSS_SASE_AD-25시험이 정말 쉬워진다고 전해드리고 싶습니다. Fortinet FCSS_SASE_AD-25덤프로 시험패스하고 자격증 한방에 따보세요. 자격증 많이 취득하면 더욱 여유롭게 직장생활을 즐길수 있습니다.
Itexamdump에는 베터랑의전문가들로 이루어진 연구팀이 잇습니다, 그들은 it지식과 풍부한 경험으로 여러 가지 여러분이Salesforce인증AP-207시험을 패스할 수 있을 자료 등을 만들었습니다, Itexamdump 에서는 일년무료 업뎃을 제공하며, Itexamdump 의 덤프들은 모두 높은 정확도를 자랑합니다. Itexamdump 선택함으로 여러분이Salesforce인증AP-207시험에 대한 부담은 사라질 것입니다.
Juniper인증 JN0-481시험은 IT업종종사분들에게 널리 알려진 유명한 자격증을 취득할수 있는 시험과목입니다. Juniper인증 JN0-481시험은 영어로 출제되는만큼 시험난이도가 많이 높습니다.하지만 Fast2test의Juniper인증 JN0-481덤프만 있다면 아무리 어려운 시험도 쉬워집니다. 오르지 못할 산도 정복할수 있는게Fast2test제품의 우점입니다. Fast2test의Juniper인증 JN0-481덤프로 시험을 패스하여 자격증을 취득하면 정상에 오를수 있습니다.
