Hi,
does the Firefly-RK3288 support access point mode? I’m trying to set up hostapd on Ubuntu but I’ve not been able to make it work. Anyone managed to do it?
Thanks!
some one have support it, but it is chinese:
http://developer.t-firefly.com/thread-1684-1-1.html
Actually, this is a YES.
Here is the link (but in Chinese, use Google translate):
Thanks, I’ll try to understand what’s in there… ![]()
Thanks, I’ve followed the instructions on the link you posted and I can confirm it works. It is a pain to bring everything down and upload a new firmware, but better than nothing. ![]()
Hi,
after some testing I’ve managed to make it work. No need to rewrite the firmware, just need to change the “op_mode” and restart wifi. At the moment, the only way I’ve found to restart the wifi is to use rfkill or nmcli:
sudo nmcli radio wifi off
sudo su -c "echo 2 > /sys/module/bcmdhd/parameters/op_mode"
sudo nmcli radio wifi on
Now I’m facing the problem that while in AP mode, network manager can’t scan the network anymore (nmcli dev wifi rescan). When it tries, I see this error in dmesg:
CFG80211-ERROR) __wl_cfg80211_scan : Invalid Scan Command at SoftAP mode
CFG80211-ERROR) wl_cfg80211_scan : scan error (-22)
The error seems to imply that scan can’t be done, but using iwlist it seems to work instead (iwlist wlan0 scan), even if the kernel complains:
bcmsdh_sdmmc mmc2:0001:2 wlan0: (WE) : Wireless Event (cmd=0x8B19) too big (65303)
CFG80211-ERROR) wl_notify_scan_status : scan is not ready
Any idea or suggestion? Thanks!
通過Salesforce PDII的考試是不簡單的,選擇合適的培訓是你成功的第一步,選擇好的資訊來源是你成功的保障,而Testpdf的產品是有很好的資訊來源保障。如果你選擇了Testpdf的產品不僅可以100%保證你通過Salesforce PDII認證考試,還可以為你提供長達一年的免費更新。
This article gave me a new perspective, thank you for sharing! With the help of the 250-584 reliable exam question, I achieved a promotion and pay raise. Now it’s free for everyone. Wishing you all success!
