Make your own SDcard Linux image
Hi all,
Can anyone help what I am doing wrong that I cannot pack my own “linuxroot” into the update
image?
Here is what I am doing:
  1. Have downloaded the official Ubuntu 14.04 SD image and unpacked it in my Linux machine
  2. unpacked “update.img” in the folder
  3. modified “linux-rootfs.img” by adding additional 2GB to allow me to copy all my own rootfs stuff
  4. mounted both my own rootfs and official linux-rootfs.img into the two different mount points
  5. have deleted all the official rootfs contents and copied all my rootfs contents into it
  6. unmount both rootfs and so the official linux-rootfs.img has my stuff in it.
  7. try to pack the update.img but it does not do it properly. The new_update.img creates quickly and I believe it doesn’t add the newly modified “linux-rootfs.img” into it
I had a look at “parameter” file but the size of linux-rootfs partition is mentioned with “-”. I assume the size not required to be specified as when I use the original “linux-rootfs.img” file the packing procedure works again and it takes more time to generate update.img!
Any help will be appreciated.
It would be gratefull if you correct my procedure or teach me the right way to create my own Linux SD card image to be able to boot my Firefly RK3288 device.
Many many thanks…
{Busybee, I think you are the one can help me :wink: }
Hi All,
I can confirm that the procedure is working fine if I use the “linux-rootfs.img” upto 1024mb (1GB).
I actually tried to create the ext4 “linux-rootfs” image from scratch bu using these commands:
dd if=/dev/zero of=linux-rootfs.img bs=1M count=1024
mkfs.ext4 -F -L linuxroot linux-rootfs.img
Then I tries two different rootfs which they are less than 1GB and both worked fine.
I tried first “busybox” rootfs and second “Angstrom” linux rootfs and both could be packed and I could load the device from SD for both of them.
I do not know why ‘afptool’ cannot properly pack the images if the ‘linux-rootfs.img’ size is more than 1GB?!!!
Any clue?
Finaly I found the work around.
The problem is linux “afptool”.
I tried to use windows ‘rockdev’ tools to create the release_update image with “Linuxium” 3gb “linux-rootfs” and the tools on windows could create the update image and release_update image successfully.
I could be able to load the firmware wit in windows and Linux could successfully load from SD card.
Thanks anyone who even didn’t reply !!! :wink:
sghazagh Posted at 8/2/2015 17:00
I tried to use windows ‘rockdev’ t …
Stumbled also into this issue… Great that you found a work-around! Tnx!
Truly a brilliant article, I’m so appreciative of your sharing. Real TDA-C01 braindumps was key to my career and salary growth. Now, I’m sharing it for free with you!
The article is very practical, and I have gained a lot of specific guidance from it. The HPE7-A06 latest study plan helped me with a promotion and raise. Now it’s free to everyone. May your career progression be swift!
It’s truly amazing, thank you for the fantastic share! Here are the free Latest 1Z0-947 braindumps pdf resources—good luck, everyone!
どうやって安くて正確性の高いSalesforceのManufacturing-Cloud-Professional問題集を買いますか。Fast2testは最も安い値段で正確性の高いSalesforceのManufacturing-Cloud-Professional問題集を提供します。Fast2testの学習教材はベストセラーになって、他のサイトをずっと先んじています。私たちのSalesforceのManufacturing-Cloud-Professional問題集を使ったら、SalesforceのManufacturing-Cloud-Professional認定試験に合格できる。Fast2testを選んだら、成功を選ぶのに等しいです。
Amazing stuff here, definitely hitting that like. The rich material of 300-610 latest practice questions ebook is free and available to help you in your learning.
