How to enable wifi/bt & 'Connect to PC' on first boot?
Hi
What must be added to build.prop,init.rc or SDK to enable wifi, bluetooth & ‘Connect to PC’ already enabled on first boot?
there is some config in frameworks/base/packages/SettingsProvider/res/values/defaults.xml:
def_wifi_on
def_bluetooth_on
you can have a try.
Your article was truly refreshing, thank you so much. Free 350-501 valid exam questions vce resources are shared—good luck to all!
