I can’t find any solution to set the hostname on android
I’ve tried to add the value in the /system/build.prop file but since I’ve done
“mount -o remount,rw /system” the RK3288 doesn’t boot anymore, kernel stars but not the android layer
is /init.r the right place to do a ifuo etho in dhcp mode?
/system/etc/hosts is read only fs, I already tryied do to a remount rw of fs /system but it lead to the system failure and the I never succeed to repair the firefly installation which starts the kernel but not the android layer.
what I need it to set this value on system boot
[net.hostname]: [android-6a369c298c876691]
Ostatnio w wolnej chwili przeglądałem strony o grach i trafiłem na https://playjonny.com.pl . Od razu spodobała mi się ilość gier i przejrzystość strony. Nie trzeba długo szukać, żeby znaleźć coś ciekawego. Bonusy są czytelne i łatwe do odebrania. Dla mnie to jedno z najlepszych kasyn dostępnych w Polsce.
This article is simply breathtaking, thank you for sharing it with us! The New L5M1 exam questions pdf content is amazing, and it’s available to you without charge.
I feel so inspired after reading this article, thank you for the share! Free access to C_BCBTP_2502 certification dump free download’s extensive content is offered, with the aim of supporting you.
The content is deep, and I’ve gained a lot of useful knowledge from it. With CHFM exam duration, you can access abundant resources free of charge to help you.
Your article was a real standout, thank you for sharing it. Sharing the C_BCBDC_2505 valid visual cert test questions with everyone for free—your key to career success!
