How to build android to boot from SD card?
Hi,
I am building android lollipop by myself, I want to make it boot from SD card on rk3288 board.
I build the android code, and generate images via mkimage.sh.I download the android 4.4 sd card image from firefly website, extract it and replace boot.img, kernel.img, system.img with my own version, repack these image to release_update.img, and flash to SD card, and now the board cannot start correctly, the errors are like:
Failed to mount an un-encryptable or wiped partition on/dev/block/platform/ff0f0000.rksdmmc/by-name/system at /system options: noauto_da_alloc error: No such file or directory
It seems the boot.img for emmc and sdcard are different, does anyone know how to configure/build boot.img to make it run from SD card?
Or is there any special codes/steps I have to do before building?
Please have a look at the scripts post at:
https://plus.google.com/+IanMORRISON/posts/22Vxc6Sr5Ei
busybee Posted at 9/12/2015 10:52
Hi
thanks for your help, I tried this tool before, I have downloaded two android package from this website, one is android4.4 sd card version, the other is android4.4 non-sd card version. the steps I tried are:
  1. flash RK3288Loader_uboot_V2.17.02.bin
    ./create-android-sdcard android4.4_sd card
    this one can boot successfully from sd card
  2. flash RK3288Loader_uboot_V2.17.02.bin
    ./create-android-sdcard android4.4_sd non-card
    this one cannot boot, cannot find file system
  3. flash RK3288Loader_uboot_V2.17.02.bin
    extract these two images, and copy the boot.img, kernel.img, system.img from non-sd package to sd package, and then re-pack the sd package
    ./create-android-sdcard the_new_package
    the one has the same issue with 2, cannot find file system (cannot find system, userdata…)
and I also replaced with my own built images, the issues are similar.
Is there any problem with my steps?
I think you need the kernel.img & boot.img from sd package.
Normally, the kernel will only parse the MBR partition of the sd card.
I guess that kernel.img & boot.img from sd package will also parse
and handle the mtd partitions of the sd card.
If I use the images from sd package (4.4), and replace system.img with my own built 5.1 image, the kernel can bootup and file system can be load successfully, but severicemanager cannot start:
[ 24.315467] binder: 147:147 transaction failed 29189, size 0-0
[ 25.299560] binder: 147:147 transaction failed 29189, size 0-0
[ 26.283657] binder: 147:147 transaction failed 29189, size 0-0
[ 26.591163] binder: 260:260 transaction failed 29189, size 0-0
[ 26.807166] binder: send failed reply for transaction 8 to 265:265
[ 26.807322] init: critical process ‘servicemanager’ exited 4 times in 4 minutes; rebooting into recovery mode
29189 is BR_DEAD_REPLY, I think it may be that my system.img is incompatible with 4.4_sd package, because if I replace the system.img with non-sd package (4.4), it can work.
so the problem maybe that I don’t know how to configure the sd card version of boot.img (the boot.img from mkimage.sh is only about 1MB, but the boot.img from sd package is about 7MB, and if I use mkimage.sh ota and replace boot.img, then the board cannot find kernel)
I think you need a boot.img with kernel inside, separate kernel.img I don’t think will work with SD boot.
dewet Posted at 9/15/2015 23:48
I think you need a boot.img with kernel inside, separate kernel.img I don’t think will work with SD …
so do you know how to make boot.img work with sd card?
Have you tried
https://bitbucket.org/T-Firefly/firenow-lollipop/src/c27bca778047567048811e9e8e17dd494d5d04a5/RKTools/windows/SD_Firmware_Tool_v1.45.rar?at=fireprime&fileviewer=file-view-default
dewet Posted at 9/18/2015 00:06
Have you tried
I was using this tool to flash the update.img, but this tool is just used to flash images to sd card, it doesn’t help to config the boot.img.
300-535認定試験は専門知識と情報技術を検査する試験で、PassTestが一日早くCiscoの300-535認定試験「Automating and Programming Cisco Collaboration Solutions」に合格させるのサイトで試験の前に弊社が提供する訓練練習問題をテストして、短い時間であなたの収穫が大きいです。
Itexamdump전문가들은Amazon SAP-C02인증시험만을 위한 특별학습가이드를 만들었습니다.Amazon SAP-C02인증시험을 응시하려면 30분이란 시간만 투자하여 특별학습가이드로 빨리 관련지식을 장악하고,또 다시 복습하고 안전하게Amazon SAP-C02인증시험을 패스할 수 잇습니다.자격증취득 많은 시간과 돈을 투자한 분들보다 더 가볍게 이루어졌습니다
