Changing U-boot environment variable
Hello All,
I have added extra environment variable in rockchip u-boot. I can modify and save its value at uboot prompt through setenv and sa option. Further, I want to change u-boot env varaible once I entered into rootfs. I guess there is u-boot utility fw_setenv by which we can set u-boot env. Does any one has compiled this fw_setenv tool for rk3288.
Thanks
You might have to compile it yourself.
If you encounter any problem, you can post it here.
Thanks for reply, ok I will give it a try and will let you know if encounter any problem.
Hi Prash,
I am using rockchip 3128 (rk3128) in my project, I am new to u-boot. Can you please guide me how to add new environmental variable in u-boot.?
Thanks and Regards
Shravan S
I appreciate this thought-provoking article, thank you for sharing! Best of luck with your exams—free Valid L5M6 exam bootcamp exam papers are available now!
