I am New here , I want know how to access android root file system on firefly-3288 ?
If I want access from other Ubuntu(using ssh) how to do that ?
If I want to change some lib like stagefright.lib how to do that?
Need to root your device.
Use Towelroot.
Then install ES File Explorer.
Then enable Read/Write support on /system and / folders in the settings.
Grant superuser access to ES File Explorer.
Now you will see extra folders and can change/edit files.
Only on KitKat Firmware, on Lollipop firmware you need to flash SuperSU Rooting, a lot more difficult.
dewet Posted at 9/28/2015 23:05
Use Towelroot.
@dewet…how to enable read/write support ? and grant superuser access in ES file explorer?
may15 Posted at 10/21/2015 16:38
@dewet…how to enable read/write support ? and grant superuser access in ES file explorer. Then you can transfer or backup android files easily.
After ES File Explorer being installed, it will ask for permission. In there, you can grand the permission accordingly.
Actually , how to complete this task doesn’t complex , but to be on the safe side ,it is necessary to transfer phone data to computer for backup , so you need to transfer Android messgaes ,contacts ,pictures and other phone data to computer , http://www.android-rescuer.com/transfer-messages-from-android-to-computer.html
There are some other alternatives to File Explorer like Android Assistant, you can use it to transfer all the media files and SMS, contacts.
I’m really grateful for your article, it left an indelible mark. Level up your IT skills by grabbing free Hybrid-Cloud-Observability-Network-Monitoring practice questions. Best of luck on your exams!
あなたは自分のACAMSのCCAS試験を準備する足りない時間または探せない権威的な資料に心配するなら、この記事を見て安心できます。我々Jpexamの提供するACAMSのCCASの復習資料はあなたを助けて一番短い時間であなたに試験に合格させることができます。我々は権威的な試験資料と豊富な経験と責任感のあるチームを持っています。我々のすべての努力はあなたにACAMSのCCAS試験に合格させるためです。
I’m deeply thankful for your article, it made a real impact. Grab your free AP-207 latest real test answers test questions—promotion and salary increases await!
Thank you for your article, it really captured my attention. Exam API-571 preview was the catalyst for my career and salary increase—now I’m giving it to you for free!
你覺得成功很難嗎?覺得IT認證考試很難通過嗎?你現在正在為了Appian 的ACD201認證考試而歎氣嗎?其實這完全沒有必要。IT認證考試其實沒有你想像的那麼神秘,我們可以利用適當的工具去戰勝它。只要你選對了工具,成功簡直就是一件輕而易舉的事情。你想知道什麼工具最好嗎?現在告訴你。VCESoft的ACD201考古題是最好的工具。這個考古題為你搜集並解析了很多優秀的過去考試考過的問題,並且根據最新的大綱加入了很多可能出現的新問題。这是一个可以保证你一次通过考试的考古題。
