Video Playback broken on FireFly-RK3288_Android5.1_201509151011
Hi
When I try to play 4K videos on this Lollipop firmware, it plays in slow motion, not hardware accelerated. Also some 1080p/4K videos also just show a green screen and freeze.
Please help.
Is there a setting in the kernel config file to change to fix video playback and make a new kernel?
If I use UGOOS 5.1 beta firmware kernel with Firefly firmware, video playback is fine and no problems.
http://ugoos.net/blog/beta-android-lollipop-5.1-firmware
It work in 1080p? with this kernel?
the Firefly firmware 5.1 not is 1080p system, is only 720p the max resolution.
Thank you for your article; it really opened my eyes! The Valid C-S4CPR-2508 test pass4sure content is impressive, and it’s free for you to explore.
Instant like; this content is too good. The C-ARSOR-2404 Dump Torrent content is excellent, and you can access it for free.
What an awe-inspiring read, thank you for sharing this article! Get ahead in your career with the free New Mule-Arch-201 test prep test questions—your key to promotion!
Jpshikenあなたに 最高のMicrosoftのDP-900試験問題集を提供して差し上げます。あなたを成功への道に引率します。JpshikenのMicrosoftのDP-900試験トレーニング資料は試験の準備をしているあなたにヘルプを与えます。当社の資料はあなたがIT専門家になるように特別に受験生の皆さんのために作成したものです。JpshikenのMicrosoftのDP-900試験トレーニング資料はあなたに最も適用して、あなたのニーズを満たす資料です。はやくJpshikenのサイトを登録してくだい。きっと棚ぼたがありますよ。
Your article was truly refreshing, thank you so much. The Reliable CPHQ exam simulator material is top-notch, and I hope it assists you, with no cost involved.
