mackodi/macspmc: KODI and SPMC on LINUX for firefly and fireprime
mackodi/macspmc V0.1.1: KODI Isengard 15.2 and SPMC Isengard 15.0 for LINUX on RK3188, RK3288 and RK312X
(testrelease: i only tested this on my own devices - mk809iii, firefly, radxa rock2, ugoos ut3s and fireprime (the latter: sound only through audio jack))
Wintertime has just started, evenings getting darker and colder. So what’s better than a new and improved kodi release for your rockchip linux device?
After having spent way too many hours of compilation, building, packing and unpacking images -over-and-over-again- on a terribly slow computer, finally an update!
Now running more smooth (using androids native surfaceflinger as window composer), added better video decoding (zero-copy-ing frames, 60 fps) and better media support (HEVC/H265). And for those having other rockchip devices than RK3288: RK3188 and RK312X are now supported too! (disclaimer: I only tested this on my good old mk809iii RK3188 device and my FirePrime (sponsored by firefly): so would be interested if this runs on other devices too!)
Short release notes:
  • mackodi*0.1.1: kodi isengard 15.2, latest stable release (october) using surfaceflinger, zero-copy-ing decoded video frames and HEVC/H265 support
  • macspmc*0.1.1: spmc isengard 15.0, latest stable release (july) using surface flinger, zero-copy-ing decoded video frames and HEVC/H265 support
  • machybris*0.1.1: support for RK3188, RK3288 and RK312X devices, support for Androids native surfaceflinger as window composer
  • packages for ubuntu trusty (14.04), utopic (14.10), vivid (15.04) and debian jessie (8.x)
For fireprime there might be a sound issue: on my prime i only get sound through the audio jack and not through HMDI. But i also have this for all other audio apps like mplayer or aplay. So i wonder if people that have good HDMI sound with mplayer or aplay on fireprime also experience good HDMI sound with kodi or spmc. Issue has probably nothing to do with kodi or spmc as same code works OK for other RK3188 and RK3288 devices…
Have fun!
And if you like it: please get me a faster computer by giving a small donation; it will benefit my impatience during compilation/building, my nails and future releases; any help is welcome!
Donate…
Cheers – mac-l1
HOW TO INSTALL
See: http://freaktab.com/forum/tv-player-support/rk3288-devices/534861-mackodi-macspmc-kodi-and-spmc-on-linux-for-rockchip-devices
I’m very grateful for your article, it really caught my attention. Latest test AZ-120 questions and answers was the catalyst for my career and salary increase—now I’m giving it to you for free!
SAA-C03学習教材の試用版を無料でダウンロードできます。 SAA-C03学習教材の試用版を使用した後、SAA-C03トレーニングエンジンの利点をより深く理解できると思います。社会の発展により、SAA-C03学習教材を進歩させて使用し、より速く進歩し、この時代のリーダーになるように促しています。必要なのは、最高の試験準備資料です。私たちのSAA-C03試験シミュレーションは、より良い未来にあなたを連れて行きます。
KaoGuTi為通過CAMS7-CN考試提供最完整有效的方案,幫祝廣大考生在考試中獲得更多的優勢。確保你只獲得最新的和最有效的ACAMS CAMS7-CN考古題,我們也希望客戶能隨時隨地的訪問,于是有了多個版本的題庫資料。PDF版的題庫方便你閱讀,為你真實地再現CAMS7-CN考試題目,軟件版本的題庫作為一個測試引擎,可以幫你模擬真實的CAMS7-CN考試環境,為考生做好充足的考前準備。通過ACAMS CAMS7-CN考試不再是夢想,我們的考古題就可以確保你成功。
This article is wonderfully written, and I’ve learned many useful techniques from it. This C-TS452-2022 latest exam dumps file helped me advance in my career and get a raise. Now it’s available for free. Wishing you all the best in your professional journeys!
Such an outstanding article, thank you for your generosity in sharing. The Best AIP-C01 practice content is fantastic, and you can access it freely.
Happy that I passed Amazon AIP-C01. The Exam Questions I reviewed on Certifycerts were pretty useful.
https://www.certifycerts.com/amazon/aip-c01-dumps.html
