Hello,
My project is an embedded application that will run on Linux only. To make room in the eMMC I want to remove partitions which are not needed for a single Linux boot. Is it possible - I mean safe - to do this? And how ?
Thanks
Hello,
Thanks
If I understand you correctly, you mean how to cut partitions from a multiboot system to a single Linux system?
I recommend not to do it that way. You can start with the single Linux firmware, or build your own firmware.
busybee Posted at 1/14/2016 09:55
If I understand you correctly, you mean how to cut partitions from a multiboot system to a single Li …
Thank you for your answer.
I’ve one more question ![]()
Just to be sure. There’s an image named “Ubuntu” at this location on the Firefly wiki:
http://en.t-firefly.com/en/firenow/firefly_rk3288/download/
If I use this image while following this tutorial:
http://wiki.t-firefly.com/index.php/Firefly-RK3288/Flash_image/en#Flash_update.img
Will I end up with a single Linux with an Ubuntu rfs?
And what about the recovery mode?
Thank you
Yes, you are right.
What kind of recovery mode would you expect?
FesterBester38 Posted at 1/20/2016 20:34
Thank you for your answer.I’ve one more question
Well, i don’t have a clear idea about the recovery mode. I’m thinking to a mean to boot the processor into a mode that would enable me - for instance - to reload a working kernel version if for some reason the last one isn’t working well. There’s a possibility to force the Firefly board to boot in a “loader mode” as explained here:
http://wiki.t-firefly.com/index.php/Firefly-RK3288/Boot_mode/en
This loader mode is entered when the RECOVERY switch is pressed at some point during the boot process. When this “loader/recovery” mode is entered, the loader is waiting for commands.
Will this switch still have an effect after the flashing of the single linux firmware?
On other platforms (e.g. Mac OS X) you can boot from a recovery partition and you end up running a lite version of MacOS. Same I think on a Windows machine. Is it possible to get such a “recovery” mode on a Firefly board? In essence, this would be sort of dual boot between a full scale Linux OS+ rfs on one hand and a reduced Linux OS+rfs on the other hand.
私たちJuniperのJN0-105学習教材の合格率は非常に高く、約99%です。 JN0-105の問題トレントの無料ダウンロードと試用を提供し、JN0-105試験トレントを頻繁に更新して、十分なテストバンクを取得し、理論と実践の傾向を追跡できるようにします。選択できる3つのバージョンが用意されているため、最も便利な学習方法を選択できます。 JN0-105の最新の質問は、経験豊富な専門家によって精巧にまとめられています。したがって、当社の製品を購入することは非常に便利であり、多くのメリットがあります。
Your article was incredibly insightful, and I’m truly thankful for it. I used the Reliable new IIA-CIA-Part3 exam format to get promoted and raise my salary. It’s free for everyone now. Wishing you quick career growth!
