I’m trying to set the cpu frequencies on a stock Fireprime (linux kernel 3.10.0 #98) using the pseudo files located in /sys/devices/system/cpu/cpux/xxxx.
I selected a userspace governor with the command:
sudo echo userspace > /sys/devices/system/cpu/cpu3/scaling_governor
And then tried the following command:
sudo echo 1320000 > /sys/devices/system/cpu/cpu3/scaling_setspeed
The available frequencies list includes the highest values 1200000, 1296000 and 1320000. But the frequency which is set is limited to 1200000 as shown by the command:
sudo cat /sys/devices/system/cpu/cpu3/scaling_cur_freq
Any idea why the max freq is limited to 1200000 instead of 1320000?
try to modify clk_core_dvfs_table in arch/arm/boot/dts/rk3128-fireprime.dts:
virt-temp-limit-*-cpu-busy: add high cpu freq list
target-temp = <85>: increase the temperate value
be careful of the cpu temperate, you should need heat radiating sheet or fan
Thank you for your article, it truly caught my attention. The D-PSC-DY-23 valid exam camp file test led to my promotion and salary increase. Today, I’m giving it away for free to help you too!
Your article truly left me in awe, thank you for sharing! Free access to the FCP_FAC_AD-6.5 reliable test cost test materials. Best of luck on your exams!
