ArchLinux ARM on USB stick
Dear all,
After weeks of research and hacking, I finally figured out how to create an ArchLinux environment for Firefly-rk3288 with rfs on USB with a working wifi, VPU and mali GPU !!!
I wrote bellow a mini tutorial on how to create an ArchLinux ARM environment with rfs on USB, and hope the firefly team can inspire themselves in this post to write an article on the firefly wiki on how to install ArchLinux ARM on the firefly and officially support ArchLinux :slight_smile: ! ( and I’m able to help the firefly team to do so, providing images, writting articles … )
I would like to thanks the people of this forum that helped me with their previous posts and the firefly wiki.
You can find the tutorial here
I’m still finishing the wifi and VPU part (I have already it running, but I’m automating the process using systemd)
[EDIT]I’ve just included the wifi part. VPU is well tested yet :slight_smile: If there are people who doens’t want to go throught the hole process of building the entire system, I can also provide you minimal working images
Cheers \o/
nice job!!!{:2_27:}
Hi tlgimenes !
You made a great work with this !
I tried your scripts to boot Arch Linux from a usb key. However, I am experiencing some problems. When the firefly boots, it stops at the “Starting kernel…” phase. Then it bootloops for ever at this phase.
Maybe it fails to find the rootfs on the usb key when the kernel starts and then crash. I don’t really know…
Or maybe I have a problem with my bootloader. What firmware did you flash on the eMMC memory ?
Would you have some advice to help me ? Thank you !
Hello Asuuga !!
So, it’s being a while since I’ve done it, but I don’t remember having this issue. It looks like you have a serial debugging cable. If you do have one, I suggest you follow this tutorial.
In the subject of wich firmware I’m using, I’m using the official Android 5.0 one
Good luck and tell me if anything goes wrong again :slight_smile:
Asuuga Posted at 3/11/2016 17:53
Hi tlgimenes !
It look like that your console mismatch, refer to the SDK’s : FFTools/parameter/rk3288-3.10-uboot-linux.parameter.txt
tlgimenes Posted at 3/12/2016 10:59
Hello Asuuga !!
So, it’s being a while since I’ve done it, but I don’t remember having this issue …
Thank you I will try this one !
What about RK3399 running ArchLinuxARM? Any Tuts out there? __
hi can you give link again. the previous link cannot access.
Your article is truly phenomenal, I’m so grateful for you sharing it! The Latest CCSFP exam discount voucher material is excellent, and you don’t have to pay for it.
Your article was so impressive, I’m truly thankful for it. The Study Guide Professional-Data-Engineer questions were the turning point in my career—now, I’m sharing them with you for free!
Your article was incredibly impactful, I truly appreciate it. Free Latest FCSS_LED_AR-7.6 dumps pdf exam questions—good luck to everyone!
This article is rich in content and has given me many insights. The New MC-201 test simulator fee content is highly informative, and it’s offered at no cost.
