Bluetooth not work with official img
rk3288 burned with official Firefly-RK3288_Ubuntu14.04_201512031755.img
startup log shows that bluetooth initializaiton fail:
  • Starting bluetooth initialization[fail]
I can select the bluetooth manager to open bluetooth, in the desktop menu, but still not work.
uart log shows that bluetooth is turning off automatically:
[ 48.977937] [BT_RFKILL]: ENABLE UART_RTS
[ 49.086227] [BT_RFKILL]: DISABLE UART_RTS
[ 49.090283] [BT_RFKILL]: bt turn on power
[ 51.319665] [BT_RFKILL]: bt shut off power
[ 55.462317] [BT_RFKILL]: bt shut off power
[ 56.072678] [BT_RFKILL]: ENABLE UART_RTS
[ 56.180912] [BT_RFKILL]: DISABLE UART_RTS
[ 56.184995] [BT_RFKILL]: bt turn on power
[ 58.424441] [BT_RFKILL]: bt shut off power
Any sort of help will be appreciated, thanks.
You can have a look at this thread:
http://bbs.t-firefly.com/forum.php?mod=viewthread&tid=244&highlight=bluetooth
I’m all in on this content, hitting like right away. I’m sharing the Latest test Project-Management collection pdf resources for free—good luck!
This article is simply incredible, thank you for sharing! Free DA0-001 exam simulator online exam questions—your key to career growth and a better salary!
I’m all about this content—definitely liking it. I used the Exam SOA-C02 simulator free set to achieve my promotion and pay raise. It’s now free for everyone. Best of luck in your promotions!
Thank you for your thought-provoking article, it made a lasting impact. The Dumps H12-841_V1.5 cost content is of great value, and it’s completely free.
This article is truly a work of art, I’m grateful for your sharing. The rich material of Related NSE7_SSE_AD-25 Exams is free and available to help you in your learning.
This article is absolutely remarkable, I’m so thankful for your share. Best of luck! Here are the Dumps 300-445 PDF materials, free for all!
學歷不等於實力,更不等於能力,學歷只是代表你有這個學習經歷而已,而真正的能力是在實踐中鍛煉出來的,與學歷並沒有必然聯繫。不要覺得自己能力不行,更不要懷疑自己,當你選擇了MSSC的CLT考試認證,就要努力通過,如果你擔心考不過,你可以選擇VCESoft MSSC的CLT考試培訓資料,不管你學歷有多高,你能力有多低,你都可以很容易的理解這個培訓資料的內容,並且可以順利的通過考試認證。
I’m genuinely grateful for your share, this article is fantastic! The Valid practice questions NSE6_SDW_AD-7.6 pdf questions are free for everyone. Good luck on your exams!
