I can’t connect to Wifi connection(Wifi gone in network manager) in Lubuntu.
I can correctly connect with ethernet but it doesn’t connect to wifi or pick up any wifi connection or device any more.
Wifi stopped being picked up just after I did some Lubuntu updates and restarted it.
I am using dual-boot Lubuntu firmware.
I did so many customizations, would be very sad too loose everything just to reinstall firmware for working wifi.
Are there terminal commands I can try or uninstall/reinstall network manager to get it to pick up wifi again.
I recopied the wifi firmware files AP6335.bin etc. from here - https://github.com/gouwa/hwpacks back and it worked.
Somehow after a ‘sudo update’ the wifi firmware files went missing.
This article is truly an outstanding work, and I’ve benefited greatly from it. Free FCSS_LED_AR-7.6 reliable real test answer resources to help you. Wishing you the best of luck in your exam!
Reading this article, I have gained a completely new understanding of the issue. The extensive content in Latest visual C_ARSOR_2404 cert exam is offered free of charge to support you.
