Technical briefing for Firefly-RK3288-Reload: Updates firmware and codes
Android5.1 update:
1.fix lcdc set freq error
2.update rgb2hdmi resolution
3.modify scale default 100%
Ubuntu update:
1.ubuntu single system update paramter file
Please refer to the Download Android SDK on wiki, and upgrade to the latest tag: Firefly-RK3288-Reload_Android5.1_201603151017
You can download the latest firmware from the following links:
Please add Mali 3D drivers to Lubuntu part and RGA 2D drivers for acceleration.
“as rockchip rk3066 and rk3188 devices are also equiped with ARM’s mali 400 GPU for 3D acceleration, lgeek has made an improved version of ssvb’s work https://github.com/lgeek/xf86-video-fbturbo and added support for rk3188 2D by using its hardware acceleration unit (RGA) and some specific optimization for copying video windows (XV).” Maybe it can work for RK3288 also.
Is it possible to update Lubuntu image to 16.04 instead of 14.04?
Can you please give me the link for downloading the source for the RK3288 reload kernel?
Can we boot from SD card in the rk3288-reload board?
If so, can you please let me know where can I find the image for SD card load?
Thanks
Hello all,
I have a question: How to build android 5.1 for the firefly rk3288 reloaded?
First I do:
cd ~/proj/firefly-rk3288-lollipop/kernel
make firefly-rk3288-reload_defconfig
make -j8 firefly-rk3288.img
And then:
. build.sh
make -j8
./mkimage.sh
But the built image does not reflect the HDMI outputs. I cannot change the output resolution. I cannot display 4K (max available is only 1080p).
For some reason it says “TARGET_PRODUCT=rk3288_box”. I think it should be something like “reloaded” or something. Or maybe this has nothing to do with it.. maybe?
Help!!!
Thank you for sharing such an insightful and uplifting article! I’m offering the Latest AIGP exam braindumps resources for free—good luck!
This article really expanded my views, thank you for the fantastic share! Here’s the NSE5_FSW_AD-7.6 valid exam lab questions exam that helped me achieve career growth with a promotion and raise. It’s free for everyone today—best wishes in your career!
Fast2test는 몇년간 최고급 덤프품질로 IT인증덤프제공사이트중에서 손꼽히는 자리에 오게 되었습니다. Amazon SOA-C02-KR 덤프는 많은 덤프들중에서 구매하는 분이 많은 인기덤프입니다. Amazon SOA-C02-KR시험준비중이신 분이시라면Amazon SOA-C02-KR한번 믿고 시험에 도전해보세요. 좋은 성적으로 시험패스하여 자격증 취득할것입니다.
