we try to remplave Radxa (RK3188 Mali 400) by the Firefly RK3288. On paper, Firefly performance are better than the Radxa one. But we meet a problem using surfaceview / Canvas refresh rate:
→ On Radxa the time between to frame is stable and around 16ms
→ On Firefly, the same code give 25 or 32 ms … and show lag and “fickering” on screen.
radxa has android 4.2.2 and firefly “out of the box” 4.4.
Please is some one as an idea from where this lower performance can came from.
thank you for your help.
I have try Android 5.1 and the result is worse … i can back to 4.4 (mars 2016 the last one).
What i do is develop android application in witch i want to display a 360° panorama 'turning at a given velocity".
For that i have a SurfaceView, surfaceholder and a thread.
the thread run is like : public void run() {
Canvas c;
[b]while/b{
c=null; try{
c=surfaceholder.lockCanvas(null);
[b]synchronized/b{ surf.draw(c);
}finally{
[b]if /b{ surfaceholder.unlockCanvasAndPost(c);
}in the draw function i have :
canvas.drawBitmap(bipmap, src , dst, null) ;
the bitmap hold the 360° panorama,
src is a rect that move everuy call to draw function and dst is a fixed rect on all screen.
On a RK3188+Mali400 it runs perfectly with a very nice smooth motion (time between to call to
draw is stable and is 16ms).
On firefly the time between to calls are between 25 and 35 ms without stability creating saccades
movement.
If i remove he DrawBitmap call and replace by a simple canvas draw call the time between to calls
came back to 16ms … so i suspect the drawbitmap call is the problem (memory access ?)…
i replace surfaceview by textureview and it is better, but not perfect… next step us GLSurfaceView … but still not normal that performances of Rk3288 + Mali T760 looks lower than RK3188 + Mali 400 for this point.
now i use a GLSurfaceView (2.0) and texture to dsplay a bitmap… (small one).
It is not normal that with the RK3288 and Mali T764 i have poor render performance using any display technique (SurfaceView, TextureView, GLSurfaceView)…
With a “basic” RK3188+MALI 400 stick it is perfect … (smooth animation without lag). And with this RK3288 i have many saccadic movement. !!!
I have noticed a slower performance as well on the GPU. My board is a Firefly Rk3288 reload.
My application loads a 1080 texture. Here is the information I could get.
Firefly-RK3288_Beta_Android4.4_201501271125
Average loading time 100ms
Driver = OpenGL ES 3.1 v1.r6p0-02rel0.0f4218be5cc66c20a4f31b6cc856ee46
GPU : Mali-T760
FireFly-RK3288-Reload_Android5.1_201603111814
Average loading time 11ms
Driver = OpenGL ES 3.0
GPU = Mali-T764
I think the driver has been updated in the Android 5.1 image. How can I select or re-install the GPU driver used in the 4.4 image? Where to get it from?
Hi,
we still meet problem regarding RK3288 performances / resolution.
In fact we found that with Android 4.4 and HDMI screen resolution 1280x720 all graphic canvas use 1280x720 resolution
(SurfaceView.width = 1280 and SurfaceView.height = 720). This makes that big bitmap manipulation are on 1280x720
With Android 5.1 and HDMI screen resolution 1280x720 all graphic canvas still use 1920x1080 resolution …
(SurfaceView.width = 1920 and SurfaceView.height = 1080) … this is the reason that high frame rate (60fps) display is not possible as the Bitmap used is 1920x1080 pixels !!! (even with HDMI output set to 1280x720).
So we back to Android 4.4 on our old RK3288 and it was OK !
Last month we receive new RK3288 from firefly, .. .and it is now impossible to install Android 4.4 … so our problem is back again.
Finally we want to use the 5.1 reload firmware, BUT Why the 'working resolution (in Android APK) is not equal to HDMI output mode !! )
… also i notice that when using the VGA output in place of HDMI and select any available resolution (from very low to high), the SurfaceView “canvas” Width and Height still fixed to 1920x1080 …
Everything looks like the Android 5.1 works in 1920x1080 and make a final scale to the choosen resolution …
Witch was not the case for Android 4.4
Thank you for the article, it really broadened my outlook. Sharing the free HPE6-A87 reliable test cram pdf test questions—your key to career advancement and higher earnings!
I feel much more informed after reading that piece. Thanks to the H35-211_V2.5 latest practice exam fee test, I reached new career heights—now, I’m offering it to you for free!
I’m sincerely grateful for your article, it really stood out to me. Free API-571 latest practice questions sheet resources—unlock promotions and salary increases today!
