flashing tools
Hi,
My firefly-rk3288 board has broken when I tried to flash a different bootloader and I have recovered it back flashing recovery image. I could see board boots to android.
BUT when I tried to flash kernel Image (kernel-4.0) that I have built. Although flashing tools says flashing completed successfully but I don’t see board uses the kernel Image I flashed. It still uses older kernel that was flashed as part of recovery image.
When rkflashkit tool used
sudo rkflashkit flash @kernel kernel.img reboot
Found devices:
0x2207:0x320a
============= 2016-04-27 12:24:08 ============
    Reading flash information
    Loading partition information
    CMDLINE:console=tty0 console=ttyFIQ0 earlyprintk androidboot.hardware=rk30board androidboot.console=ttyFIQ0 board.ap_has_alsa=0 root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init initrd=0x62000000,0x00800000 mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00180000@0x00092000(system),0x00002000@0x00212000(metadata),0x00200000@0x00214000(userdata),0x00620000@0x00414000(linuxroot),-@0x00a34000(user)
    Partitions:
    uboot        (0x00002000 @ 0x00002000)    4 MiB
    misc         (0x00002000 @ 0x00004000)    4 MiB
    resource     (0x00008000 @ 0x00006000)   16 MiB
    kernel       (0x00008000 @ 0x0000E000)   16 MiB
    boot         (0x00010000 @ 0x00016000)   32 MiB
    recovery     (0x00010000 @ 0x00026000)   32 MiB
    backup       (0x0001A000 @ 0x00036000)   52 MiB
    cache        (0x00040000 @ 0x00050000)  128 MiB
    kpanic       (0x00002000 @ 0x00090000)    4 MiB
    system       (0x00180000 @ 0x00092000)  768 MiB
    metadata     (0x00002000 @ 0x00212000)    4 MiB
    userdata     (0x00200000 @ 0x00214000) 1024 MiB
    linuxroot    (0x00620000 @ 0x00414000) 3136 MiB
    user         (0x012EB000 @ 0x00A34000) 9686 MiB
    Done!
    Writing file kernel.img to partition 0x00008000@0x0000E000
    writing flash memory at offset 0x0000E000
    writing flash memory at offset 0x0000F000
    Done!
    Comparing partition 0x00008000@0x0000E000 with file kernel.img
    reading flash memory at offset 0x0000E000
    reading flash memory at offset 0x0000F000
    Done!
    Rebooting device
    Done!
When upgrade_tool used
upgrade_tool di -k kernel.img
Download kernel start…
Download image ok.
Also tried erasing kernel image and I see the same result
does anyone know what would has gone wrong here? Why does board still uses older kernel image?
Thanks
I’m so impressed by this article, thank you for sharing. Improve your IT skills by accessing free Workday-Pro-Compensation reliable exam questions and answers. Best wishes for your success!
I’m impressed—this deserves a like. Get your hands on the free New Salesforce-Media-Cloud test pdf exam questions. Wishing you the best of luck!
