用串口调试的输出如下:
U-Boot 2014.10-RK3288-02 (Jan 21 2015 - 17:07:53)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 300000000HZ
ddr pll = 200000000HZ
codec pll = 594000000HZ
DRAM: Found dram banks:1
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_ID:007!
power key: bank-0 pin-5
light power led: bank-8 pin-1
pmic:act8846
#Boot ver: 2015-01-21#2.17
empty serial no.
checkKey
vbus = 0
recovery key pressed.
no fuel gauge found
no fuel gauge found
no fuel gauge found
failed to find part:recovery
‘recovery’ does not seem to be a partition nor an address
Unable to boot:recovery
try to start backup
failed to find part:kernel
ERROR: [rk_load_image_from_storage]: bootrk: bad boot or kernel image
Unable to boot:backup
try to start rockusb
DDR Version 1.00 20141007
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
CPU: rk3288
128 MiB
storage init OK!
GetParam
pmic:act8846
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
rkboot #
