user24
July 18, 2016, 2:16am
Android5.1 update:
1.update loader version 2.30.10
2.update camerahal driver
3.fix pcba test some issue
4.add dual screen patch and multiwindow patch
5.fix some application feature
6.update media play library
7.system optimization and stability
Ubuntu update:
1.support nfs
2.add kernel headers
3.open uart1 and uart3
Please refer to the Download Android SDK on wiki, and upgrade to the latest tag: Firefly-RK3288-Reload_Android5.1_201603151017
You can download the latest firmware from the following links:
Android Firmware from google drive
Ubuntu Firmware from google drive
DualBoot(Android&Ubuntu) Firmware from google drive
Hi Wico,
Downloaded images from https://drive.google.com/drive/folders/0B7HO8lbGgAqAeXlaa29rRF82dzA and used upgrade_tool to flash the this image.
Flashed successfully
$ upgrade_tool uf Firefly-RK3288_DualBoot_201607151016.img
Loading firmware…
Support Type:RK32 FW Ver:5.0.00 FW Time:2016-07-15 10:16:28
Loader ver:2.30 Loader Time:2016-07-15 09:57:34
Upgrade firmware ok.
But board does not boot.
U-Boot 2014.10-RK3288-10 (Jul 15 2016 - 09:57:27)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 300000000HZ
ddr pll = 200000000HZ
codec pll = 594000000HZ
DRAM: Found dram banks: 1
128 MiB
G
rebooted it couple of times and still board stuck at uboot.
Any idea what could be the issue?
Thanks
Tried on other hardware and it worked. Meaning I could flash Image from https://drive.google.com/drive/folders/0B7HO8lbGgAqAeXlaa29rRF82dzA and board boots to android without any issue.
But I could not halt booting at uboot prompt. Looks like uboot delay is made 0.
Can this delay be increased ?
Does the bootloader with this image support fastboot ?
I can flash standard android Image?
could you also provide me refer to uboot code? do we have rk3288 support in mainline uboot?
Thanks,
We don’t have any possibility to use fireasy apk anymore on android 5.1?? Somebody knows any possibility to use this app?
Cheers
isle
November 11, 2016, 1:52am
5
It can be run on android5.1 .
Did you have any problem?
psycmos
November 26, 2016, 1:42pm
6
I tested two versions of fireasy apk v1.0 and v1.1
in this version 5.1:
Rk3288_box_userdebug5.1.1 LMY49F ENG guanzl.20160912.143552 test-keys
You have tested in this version?
I love fireasy so can confirm if this version have it working?
isle
November 28, 2016, 6:47am
7
Yes, the firmware you mentioned can run fireasy apk rightly.
あなたのIT能力が権威的に認められるのがほしいですか。ISACAのCISM 試験に合格するのは最良の方法の一です。我々Japancertの開発するISACAのCISMソフトはあなたに一番速い速度でISACAのCISM試験のコツを把握させることができます。豊富な資料、便利なページ構成と購入した一年間の無料更新はあなたにISACAのCISM試験に合格させる最高の支持です。
What a stunning article, thank you for sharing this amazing piece! The C-BCBAI-2509 reliable exam questions answers helped me secure a promotion and raise. Now, I’m giving it away for free. May your career paths be filled with success!
