[NEWBIE] Unable to boot on SD card with Ubuntu .img from the tutorial
Good evening all,
As a small company, we acquired a Firefly RK3288 Reloaded today (yay!). When we powered the board for the first time, it booted on Android 5.1.1 and we were able to switch on Lubuntu with success.
However, we wanted to boot on SD card with Ubuntu in it. We followed the tutorial Boot Ubuntu from SD card from the wiki. The thing is, when we put the SD card in the board and then power it, it does not boot at all : even the blue isn’t up.
We tried to flash the .img file from the drive using the utility tool on Windows 10 64 bits, at first it didn’t work. Then we ran the tool as Windows 7 compatibility and the tool “successfully flashed” the .img, sending the success message at the end. As result, it didn’t boot at all.
We then tried to flash manually the .img file using the dd command from Linux, and it didn’t work too.
However, we tried to find some help on Google and we found this Google Plus topic explaining that it should work by running the tool on a 32 bits OS. We didn’t try this solution yet, may be tomorrow.
Plus, it seems that the .img file is outdated from the wiki page and that there is a new .img here.
Are we missing something ? Are there others steps to follow ? Did you encounter this problem like us ?
Thank you in advance for your help !
Regards
Hi
maybe youshould use new loader in your SD card IMG.
当社CertJukenは多くの優秀な専門家や教授がいます。過去数年、これらの専門家と教授は、すべての顧客向けにSPLK-1003試験問題を設計するために最善を尽くしました。さらに重要なことは、最終的にSPLK-1003試験問題でSPLK-1003認定を取得すると、人生の楽しみと人間関係の改善、ストレスの軽減、全体的な生活の質の向上という大きなメリットが得られることです。そのため、SPLK-1003試験に合格し、関連する認定を取得するために全力を尽くすことは非常に重要です。
The article is truly moving, thank you for sharing! The AP-204 valid practice questions free test played a pivotal role in my promotion and pay raise—get it for free today!
I truly appreciate your article, it is stunning! This Exam CKYCA quick prep helped me achieve a promotion and pay raise. Now I’m sharing it for free with everyone. Wishing you all great success in your careers!
