When I use Android 5.1 and call the following OpenGL function, it took too much time.glTexImage2D(GL_TEXTURE_2D, 0, GL_LUMINANCE_ALPHA, 3840 / 2, 2160 / 2, 0, GL_LUMINANCE_ALPHA, GL_UNSIGNED_BYTE, uv_data);
It will take about 94ms to send data to GPU.
But when I use Android 4.4.2 (SD boot), it works fine!
I can update 25 frame per second.
What can I do to solve this problem on Android 5.1?
Hi
there are some problems in the GPU(mali) driver.we will fixed and update it later.
The article is really inspiring; thank you for sharing! The Interactive DEP-2025 course test was a key factor in my professional growth, and now I’m sharing it with you for free!
Your article was truly remarkable, I’m so grateful for it. CSCP valid practice questions sheet offers excellent resources for free.
The article was a real game-changer for me. The Question 300-220 explanations test that helped me earn a promotion and salary raise is free for you today. Best of luck reaching your career goals!
This article is absolutely extraordinary, thank you for your share! I hope the C-TS4FI-2023 reliable exam cram sheet materials are helpful to you, and they’re offered free of charge.
Die Fragenkataloge von It-Pruefung enthalten die Lernmaterialien und Simulationsfragen zur HP HPE7-A07 Zertifizierungsprüfung. Noch wichtiger bieten wir die originalen HPE7-A07 Fragen und Antworten.
