Hello I need your help for I2C comunication
Hi, I try connect MPU-9250 in my firefly board, but I dont know the procedure. I’m reading in the web page but not understand. How I do changes in the kernel or how install libraries python for this?. Thanks you.
Hi
you need add a IIC device to your board.
see this :
http://wiki.t-firefly.com/index.php/Firefly-RK3288/I2C/en
and the mpu9250 driver ,here is a demo :
http://blog.csdn.net/wlr_tang/article/details/46562505
Hi, Thanks for the information and excuse my ignorance, but I don’t know how can write the information of the I2C device as a node in the dts file or access to the kernel.
Respectively the code in C for the MPU how to install?, only save and import this?
Thanks for your help!!! very so much!!!
Jpexamは実際の環境で本格的なSAPのC-BCSBN-2502「SAP Certified Associate - Positioning SAP Business Suite via SAP Supply Chain Management Solutions」の試験の準備過程を提供しています。もしあなたは初心者若しくは専門的な技能を高めたかったら、JpexamのSAPのC-BCSBN-2502「SAP Certified Associate - Positioning SAP Business Suite via SAP Supply Chain Management Solutions」の試験問題があなたが一歩一歩自分の念願に近くために助けを差し上げます。試験問題と解答に関する質問があるなら、当社は直後に解決方法を差し上げます。しかも、一年間の無料更新サービスを提供します。
Your article was truly remarkable, thank you for sharing it. I’m sharing the Test AD0-E117 voucher resources for free—best of luck to you!
