Ambilight Project with Firefly RK3288
Hi.
I’m requesting some help because i saw one internet one project called ambilight for arduino and other devices.
[ytube]https://www.youtube.com/watch?v=H9iQ66ySrfI[/ytube]
Is possible to impletmente that project with our RK3288 Firefly board?
I need help to know if its possible and sodoby with know how bluiding it to us!!!
So replys is very appreciated :smiley:
That’s interesting!It is great if somebody work on the project and to share !
The Ubuntu 14.04/16.04 image created by the Firefly team does not support HDMI Input. So, unless you’re ok with basing on Android, you’ll need to modify the existing tc358743 driver (https://github.com/torvalds/linu … edia/i2c/tc358743.c) to support tc358749. That would give you a /dev/video0 device which you can grab frames from using the video4linux2 API.
While firefly does have a tc358749 driver, to my understanding it’s userspace and tied to the Android camera framework (along with a small kernel driver used to make the ‘raw’ device available in userspace). Perhaps something can be done with libhybris in order to use this driver on GNU/Linux?
If it work in android with Ambilight plugin for kodi it would be great.
http://kodi.wiki/view/Ambient_lighting
For start it don’t need the HDMI input, just analyze the screen out in android and controll the lights.
My problem is that i haven’t sufficient know-how and i don’t know how i can start this project.
We need enthusiasts for start this!! These will bring new life and competitive market in box market!! :smiley:
Fast2test確保廣大考生獲得最好和最新的Peoplecert ITIL-4-DITS題庫學習資料,您可以隨時隨地的訪問我們網站尋找您需要的考古題。我們提供所有熱門認證考試學習資料,其中包含PDF電子版本和軟件版本的ITIL-4-DITS題庫,還有APP在線版本支持離線使用,方便考生選擇使用。并且我們的ITIL-4-DITS考古題包含實際考試中可能出現的所有問題,是您的ITIL-4-DITS考試合格的最佳復習資料,幫助您輕松通過測試。
No hesitation, just hitting like for this great content. I’m giving away the NCP-US-6.10 latest braindumps free test resources for free. Good luck!
ExamPassdump의IBM인증 C1000-189덤프공부가이드에는IBM인증 C1000-189시험의 가장 최신 시험문제의 기출문제와 예상문제가 정리되어 있어IBM인증 C1000-189시험을 패스하는데 좋은 동반자로 되어드립니다. IBM인증 C1000-189시험에서 떨어지는 경우IBM인증 C1000-189덤프비용전액 환불신청을 할수 있기에 보장성이 있습니다.시험적중율이 떨어지는 경우 덤프를 빌려 공부한 것과 같기에 부담없이 덤프를 구매하셔도 됩니다.
