Hello, I was checking the links above and it was active…
Ok. I will try to insert logs here.
When I do connect HDMI display “on the go” (after OS is loaded) I got this log:
[ 7.879]
X.Org X Server 1.15.1
Release Date: 2014-04-13
[ 7.879] X Protocol Version 11, Revision 0
[ 7.879] Build Operating System: Linux 3.2.0-67-highbank armv7l Ubuntu
[ 7.879] Current Operating System: Linux firefly 3.14.0 #129 SMP Mon Jun 6 15:15:00 CST 2016 armv7l
[ 7.879] Kernel command line: earlyprintk=ttyS2,115200 console=tty0 console=ttyS2,115200 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 root=/dev/block/mtd/by-name/linuxroot linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00010000@0x00002000(boot),0x00002000@0x00012000(backup),-@0x00014000(linuxroot) storagemedia=emmc loader.timestamp=2015-01-21_16:36:44 androidboot.mode=emmc
[ 7.879] Build Date: 12 February 2015 02:55:07PM
[ 7.879] xorg-server 2:1.15.1-0ubuntu2.7 (For technical support please see http://www.ubuntu.com/support)
[ 7.879] Current version of pixman: 0.30.2
[ 7.879] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 7.879] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 7.879] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jan 1 08:00:07 1970
[ 7.879] (==) Using config file: "/etc/X11/xorg.conf"
[ 7.880] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 7.880] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 7.880] (==) ServerLayout "DefaultLayout"
[ 7.880] (**) |-->Screen "DefaultScreen" (0)
[ 7.880] (**) | |-->Monitor "<default monitor>"
[ 7.881] (**) | |-->Device "Mali FBDEV"
[ 7.881] (==) No monitor specified for screen "DefaultScreen".
Using a default monitor configuration.
[ 7.881] (**) Option "NoTrapSignals" "true"
[ 7.881] (**) Option "DontZap" "false"
[ 7.881] (**) Option "BlankTime" "0"
[ 7.881] (**) Option "StandbyTime" "0"
[ 7.881] (**) Option "SuspendTime" "0"
[ 7.881] (**) Option "OffTime" "0"
[ 7.881] (**) Option "IgnoreABI" "1"
[ 7.881] (**) Ignoring ABI Version
[ 7.881] (==) Automatically adding devices
[ 7.881] (==) Automatically enabling devices
[ 7.881] (==) Automatically adding GPU devices
[ 7.881] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 7.881] Entry deleted from font path.
[ 7.881] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 7.881] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 7.881] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
[ 7.881] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 7.881] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 7.881] (==) FontPath set to:
/usr/share/fonts/X11/misc,
built-ins
[ 7.881] (==) ModulePath set to "/usr/lib/arm-linux-gnueabihf/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 7.881] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 7.881] (II) Loader magic: 0xb6f93f10
[ 7.881] (II) Module ABI versions:
[ 7.881] X.Org ANSI C Emulation: 0.4
[ 7.881] X.Org Video Driver: 15.0
[ 7.881] X.Org XInput driver : 20.0
[ 7.881] X.Org Server Extension : 8.0
[ 7.882] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 7.882] Initializing built-in extension Generic Event Extension
[ 7.882] Initializing built-in extension SHAPE
[ 7.882] Initializing built-in extension MIT-SHM
[ 7.882] Initializing built-in extension XInputExtension
[ 7.882] Initializing built-in extension XTEST
[ 7.882] Initializing built-in extension BIG-REQUESTS
[ 7.882] Initializing built-in extension SYNC
[ 7.882] Initializing built-in extension XKEYBOARD
[ 7.882] Initializing built-in extension XC-MISC
[ 7.882] Initializing built-in extension SECURITY
[ 7.882] Initializing built-in extension XINERAMA
[ 7.882] Initializing built-in extension XFIXES
[ 7.882] Initializing built-in extension RENDER
[ 7.882] Initializing built-in extension RANDR
[ 7.882] Initializing built-in extension COMPOSITE
[ 7.882] Initializing built-in extension DAMAGE
[ 7.882] Initializing built-in extension MIT-SCREEN-SAVER
[ 7.882] Initializing built-in extension DOUBLE-BUFFER
[ 7.882] Initializing built-in extension RECORD
[ 7.882] Initializing built-in extension DPMS
[ 7.883] Initializing built-in extension Present
[ 7.883] Initializing built-in extension DRI3
[ 7.883] Initializing built-in extension X-Resource
[ 7.883] Initializing built-in extension XVideo
[ 7.883] Initializing built-in extension XVideo-MotionCompensation
[ 7.883] Initializing built-in extension SELinux
[ 7.883] Initializing built-in extension XFree86-VidModeExtension
[ 7.883] Initializing built-in extension XFree86-DGA
[ 7.883] Initializing built-in extension XFree86-DRI
[ 7.883] Initializing built-in extension DRI2
[ 7.883] (II) LoadModule: "glx"
[ 7.886] (WW) Warning, couldn\'t open module glx
[ 7.886] (II) UnloadModule: "glx"
[ 7.886] (II) Unloading glx
[ 7.886] (EE) Failed to load module "glx" (module does not exist, 0)
[ 7.886] (II) LoadModule: "armsoc"
[ 7.887] (II) Loading /usr/lib/xorg/modules/drivers/armsoc_drv.so
[ 7.888] (II) Module armsoc: vendor="X.Org Foundation"
[ 7.888] compiled for 1.15.1, module version = 0.0.1
[ 7.888] Module class: X.Org Video Driver
[ 7.888] ABI class: X.Org Video Driver, version 15.0
[ 7.888] (II) ARMSOC: Driver for TI OMAP: exynos5
[ 7.888] (++) using VT number 7
[ 7.893] (WW) Falling back to old probe method for armsoc
[ 7.893] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 7.893] (II) ARMSOC(0): Creating default Display subsection in Screen section
"DefaultScreen" for depth/fbbpp 24/32
[ 7.893] (**) ARMSOC(0): Depth 24, (--) framebuffer bpp 32
[ 7.893] (==) ARMSOC(0): RGB weight 888
[ 7.893] (==) ARMSOC(0): Using gamma correction (1.0, 1.0, 1.0)
[ 7.893] (==) ARMSOC(0): Default visual is TrueColor
[ 7.894] (II) ARMSOC(0): Chipset: exynos5
[ 7.894] (II) ARMSOC(0): Setting the video modes ...
[ 7.894] (II) ARMSOC(0): [CRTC:21] HW Cursor using [BO:1]
[ 7.894] (II) ARMSOC(0): [CRTC:26] HW Cursor using [BO:2]
[ 7.894] (II) ARMSOC(0): Output HDMI-1 has no monitor section
[ 7.895] (II) ARMSOC(0): Output VGA-1 has no monitor section
[ 7.895] (II) ARMSOC(0): EDID for output HDMI-1
[ 7.896] (II) ARMSOC(0): EDID for output VGA-1
[ 7.896] (II) ARMSOC(0): Output HDMI-1 disconnected
[ 7.896] (II) ARMSOC(0): Output VGA-1 disconnected
[ 7.896] (WW) ARMSOC(0): No outputs definitely connected, trying again...
[ 7.896] (WW) ARMSOC(0): Unable to find connected outputs - setting 1024x768 initial framebuffer
[ 7.896] (II) ARMSOC(0): Got KMS resources
[ 7.896] (==) ARMSOC(0): DPI set to (96, 96)
[ 7.896] (II) Loading sub module "dri2"
[ 7.896] (II) LoadModule: "dri2"
[ 7.896] (II) Module "dri2" already built-in
[ 7.896] (II) Loading sub module "exa"
[ 7.896] (II) LoadModule: "exa"
[ 7.896] (II) Loading /usr/lib/xorg/modules/libexa.so
[ 7.897] (II) Module exa: vendor="X.Org Foundation"
[ 7.897] compiled for 1.15.1, module version = 2.6.0
[ 7.897] ABI class: X.Org Video Driver, version 15.0
[ 7.897] (II) Loading sub module "fb"
[ 7.897] (II) LoadModule: "fb"
[ 7.897] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 7.897] (II) Module fb: vendor="X.Org Foundation"
[ 7.897] compiled for 1.15.1, module version = 1.0.0
[ 7.897] ABI class: X.Org ANSI C Emulation, version 0.4
[ 7.897] (--) Depth 24 pixmap format is 32 bpp
[ 7.922] (II) ARMSOC(0): Initialized a depth-32 visual for XRGB8888
[ 7.922] (II) ARMSOC(0): Soft EXA mode
[ 7.923] (II) EXA(0): Driver allocated offscreen pixmaps
[ 7.923] (II) EXA(0): Driver registered support for the following operations:
[ 7.923] (II) Solid
[ 7.923] (II) Copy
[ 7.923] (II) Composite (RENDER acceleration)
[ 7.923] (II) ARMSOC(0): [DRI2] Setup complete
[ 7.923] (II) ARMSOC(0): [DRI2] DRI driver: armsoc
[ 7.923] (==) ARMSOC(0): Backing store enabled
[ 7.923] (==) ARMSOC(0): Silken mouse enabled
[ 7.923] (II) ARMSOC(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 7.923] (==) ARMSOC(0): DPMS enabled
[ 7.923] (--) RandR disabled
[ 7.937] (II) SELinux: Disabled on system
[ 7.987] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[ 7.992] (II) config/udev: Adding drm device (/dev/dri/card0) card0 /sys/devices/display-subsystem.4/drm/card0
[ 7.992] (II) config/udev: Ignoring already known drm device (/dev/dri/card0)
[ 7.993] (II) config/udev: Adding input device gpio_ir_recv (/dev/input/event0)
[ 7.993] (**) gpio_ir_recv: Applying InputClass "evdev keyboard catchall"
[ 7.993] (II) LoadModule: "evdev"
[ 7.993] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 7.996] (II) Module evdev: vendor="X.Org Foundation"
[ 7.996] compiled for 1.15.0, module version = 2.8.2
[ 7.996] Module class: X.Org XInput Driver
[ 7.996] ABI class: X.Org XInput driver, version 20.0
[ 7.996] (II) Using input driver \'evdev\' for \'gpio_ir_recv\'
[ 7.996] (**) gpio_ir_recv: always reports core events
[ 7.996] (**) evdev: gpio_ir_recv: Device: "/dev/input/event0"
[ 7.996] (--) evdev: gpio_ir_recv: Vendor 0x1 Product 0x1
[ 7.996] (--) evdev: gpio_ir_recv: Found keys
[ 7.996] (II) evdev: gpio_ir_recv: Configuring as keyboard
[ 7.996] (**) Option "config_info" "udev:/sys/devices/gpio-ir-receiver.13/rc/rc0/input0/event0"
[ 7.996] (II) XINPUT: Adding extended input device "gpio_ir_recv" (type: KEYBOARD, id 6)
[ 7.996] (**) Option "xkb_rules" "evdev"
[ 7.996] (**) Option "xkb_model" "pc105"
[ 7.996] (**) Option "xkb_layout" "us"
[ 7.997] (II) config/udev: Adding input device gpio-keys.12 (/dev/input/event3)
[ 7.997] (**) gpio-keys.12: Applying InputClass "evdev keyboard catchall"
[ 7.997] (II) Using input driver \'evdev\' for \'gpio-keys.12\'
[ 7.997] (**) gpio-keys.12: always reports core events
[ 7.997] (**) evdev: gpio-keys.12: Device: "/dev/input/event3"
[ 7.997] (--) evdev: gpio-keys.12: Vendor 0x1 Product 0x1
[ 7.997] (--) evdev: gpio-keys.12: Found keys
[ 7.997] (II) evdev: gpio-keys.12: Configuring as keyboard
[ 7.997] (**) Option "config_info" "udev:/sys/devices/gpio-keys.12/input/input3/event3"
[ 7.997] (II) XINPUT: Adding extended input device "gpio-keys.12" (type: KEYBOARD, id 7)
[ 7.997] (**) Option "xkb_rules" "evdev"
[ 7.997] (**) Option "xkb_model" "pc105"
[ 7.997] (**) Option "xkb_layout" "us"
[ 7.998] (II) config/udev: Adding input device RockchipHDMI HDMI Jack (/dev/input/event2)
[ 7.998] (II) No input driver specified, ignoring this device.
[ 7.998] (II) This device may have been added with another device file.
[ 7.999] (II) config/udev: Adding input device MCE IR Keyboard/Mouse (gpio-rc-recv) (/dev/input/event1)
[ 7.999] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): Applying InputClass "evdev pointer catchall"
[ 7.999] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): Applying InputClass "evdev keyboard catchall"
[ 7.999] (II) Using input driver \'evdev\' for \'MCE IR Keyboard/Mouse (gpio-rc-recv)\'
[ 7.999] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): always reports core events
[ 7.999] (**) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Device: "/dev/input/event1"
[ 7.999] (--) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Vendor 0 Product 0
[ 7.999] (--) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Found 3 mouse buttons
[ 7.999] (--) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Found relative axes
[ 7.999] (--) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Found x and y relative axes
[ 7.999] (--) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Found keys
[ 7.999] (II) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Configuring as mouse
[ 7.999] (II) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Configuring as keyboard
[ 7.999] (**) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): YAxisMapping: buttons 4 and 5
[ 7.999] (**) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 7.999] (**) Option "config_info" "udev:/sys/devices/virtual/input/input1/event1"
[ 7.999] (II) XINPUT: Adding extended input device "MCE IR Keyboard/Mouse (gpio-rc-recv)" (type: KEYBOARD, id 8)
[ 7.999] (**) Option "xkb_rules" "evdev"
[ 7.999] (**) Option "xkb_model" "pc105"
[ 7.999] (**) Option "xkb_layout" "us"
[ 8.000] (II) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): initialized for relative axes.
[ 8.000] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): (accel) keeping acceleration scheme 1
[ 8.000] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): (accel) acceleration profile 0
[ 8.000] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): (accel) acceleration factor: 2.000
[ 8.000] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): (accel) acceleration threshold: 4
[ 171.238] (II) ARMSOC(0): hotplug=1, match=1
[ 171.520] (II) ARMSOC(0): EDID vendor "RKC", prod id 17480
[ 171.520] (II) ARMSOC(0): DDCModeFromDetailedTiming: Ignoring: We don\'t handle stereo.
[ 171.521] (II) ARMSOC(0): Printing DDC gathered Modelines:
[ 171.521] (II) ARMSOC(0): Modeline "472x295"x82.0 14.85 472 480 528 584 295 296 299 310 -hsync +vsync (25.4 kHz e)
[ 171.521] (II) ARMSOC(0): Modeline "504x378"x84.0 21.07 504 520 568 632 378 379 382 397 -hsync +vsync (33.3 kHz e)
[ 171.521] (II) ARMSOC(0): Modeline "600x375"x97.0 29.88 600 624 688 776 375 376 379 397 -hsync +vsync (38.5 kHz e)
[ 171.521] (II) ARMSOC(0): Modeline "248x139"x64.0 2.30 248 232 248 248 139 140 143 145 -hsync +vsync (9.3 kHz e)
[ 171.521] (II) ARMSOC(0): Modeline "1384x865"x93.0 159.63 1384 1480 1632 1880 865 866 869 913 -hsync +vsync (84.9 kHz e)
[ 171.521] (II) ARMSOC(0): Modeline "248x2040"x1275.0 3135.89 248 272 304 360 2040 2041 2044 6832 -hsync +vsync (8710.8 kHz e)
[ 171.521] (II) ARMSOC(0): Modeline "11744x376"x235.0 1637.85 11744 12632 13920 16096 376 377 380 433 -hsync +vsync (101.8 kHz e)
[ 171.521] (II) ARMSOC(0): Modeline "4112x744"x465.0 2710.87 4112 4504 4968 5824 744 745 748 1001 -hsync +vsync (465.5 kHz e)
[ 171.521] (II) ARMSOC(0): Modeline "2040x1275"x105.0 401.49 2040 2208 2432 2824 1275 1276 1279 1354 -hsync +vsync (142.2 kHz e)
[ 171.521] (II) ARMSOC(0): Modeline "376x235"x76.0 8.23 376 376 408 440 235 236 239 246 -hsync +vsync (18.7 kHz e)
[ 171.521] (II) ARMSOC(0): Modeline "744x465"x62.0 27.97 744 768 840 936 465 466 469 482 -hsync +vsync (29.9 kHz e)
[ 171.521] (II) ARMSOC(0): Modeline "248x155"x79.0 3.40 248 232 256 264 155 156 159 163 -hsync +vsync (12.9 kHz e)
[ 171.521] (II) ARMSOC(0): Modeline "0x5"x522.0 0.00 0 0 0 0 5 6 9 8 -hsync +vsync (4.2 kHz e)
[ 171.521] (II) ARMSOC(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 171.521] (II) ARMSOC(0): Modeline "640x480"x0.0 25.18 640 648 744 800 480 482 484 525 -hsync -vsync (31.5 kHz e)
[ 171.521] (II) ARMSOC(0): Modeline "1440x480i"x0.0 27.00 1440 1478 1602 1716 480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[ 171.521] (II) ARMSOC(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 171.521] (II) ARMSOC(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 171.521] (II) ARMSOC(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 171.521] (WW) ARMSOC(0): Output HDMI-1: Strange aspect ratio (522/32), consider adding a quirk
[ 171.521] (II) ARMSOC(0): EDID vendor "RKC", prod id 17480
[ 171.521] (II) ARMSOC(0): DDCModeFromDetailedTiming: Ignoring: We don\'t handle stereo.
[ 171.522] (II) ARMSOC(0): Modeline "744x465"x62.0 27.97 744 768 840 936 465 466 469 482 -hsync +vsync (29.9 kHz e)
[ 171.522] (II) ARMSOC(0): Modeline "248x155"x79.0 3.40 248 232 256 264 155 156 159 163 -hsync +vsync (12.9 kHz e)
[ 171.522] (II) ARMSOC(0): Modeline "0x5"x522.0 0.00 0 0 0 0 5 6 9 8 -hsync +vsync (4.2 kHz e)
[ 171.522] (II) ARMSOC(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 171.522] (II) ARMSOC(0): Modeline "640x480"x0.0 25.18 640 648 744 800 480 482 484 525 -hsync -vsync (31.5 kHz e)
[ 171.522] (II) ARMSOC(0): Modeline "1440x480i"x0.0 27.00 1440 1478 1602 1716 480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[ 171.522] (II) ARMSOC(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 171.522] (II) ARMSOC(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 171.522] (II) ARMSOC(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
If I boot up OS while HDMI is already connected, I am getting this one:
[ 9.421]
[ 9.421] X Protocol Version 11, Revision 0
[ 9.421] Build Operating System: Linux 3.2.0-67-highbank armv7l Ubuntu
[ 9.421] Current Operating System: Linux firefly 3.14.0 #129 SMP Mon Jun 6 15:15:00 CST 2016 armv7l
[ 9.421] Kernel command line: earlyprintk=ttyS2,115200 console=tty0 console=ttyS2,115200 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 root=/dev/block/mtd/by-name/linuxroot linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00010000@0x00002000(boot),0x00002000@0x00012000(backup),-@0x00014000(linuxroot) storagemedia=emmc loader.timestamp=2015-01-21_16:36:44 androidboot.mode=emmc
[ 9.421] Build Date: 12 February 2015 02:55:07PM
[ 9.421] xorg-server 2:1.15.1-0ubuntu2.7 (For technical support please see http://www.ubuntu.com/support)
[ 9.421] Current version of pixman: 0.30.2
[ 9.421] Before reporting problems, check http://wiki.x.org
[ 9.421] Markers: (--) probed, (**) from config file, (==) default setting,
[ 9.421] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jan 1 08:00:09 1970
[ 9.422] (==) Using config file: "/etc/X11/xorg.conf"
[ 9.422] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 9.422] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 9.422] (==) ServerLayout "DefaultLayout"
[ 9.422] (**) |-->Screen "DefaultScreen" (0)
[ 9.422] (**) | |-->Monitor "<default monitor>"
[ 9.423] (**) | |-->Device "Mali FBDEV"
[ 9.423] (==) No monitor specified for screen "DefaultScreen".
[ 9.423] (**) Option "NoTrapSignals" "true"
[ 9.423] (**) Option "DontZap" "false"
[ 9.423] (**) Option "BlankTime" "0"
[ 9.423] (**) Option "StandbyTime" "0"
[ 9.423] (**) Option "SuspendTime" "0"
[ 9.423] (**) Option "OffTime" "0"
[ 9.423] (**) Option "IgnoreABI" "1"
[ 9.423] (**) Ignoring ABI Version
[ 9.423] (==) Automatically adding devices
[ 9.423] (==) Automatically enabling devices
[ 9.423] (==) Automatically adding GPU devices
[ 9.423] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 9.423] Entry deleted from font path.
[ 9.423] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 9.423] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 9.423] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
[ 9.423] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 9.423] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 9.423] (==) FontPath set to:
built-ins
[ 9.423] (==) ModulePath set to "/usr/lib/arm-linux-gnueabihf/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 9.423] (II) The server relies on udev to provide the list of input devices.
[ 9.423] (II) Loader magic: 0xb6f6af10
[ 9.423] (II) Module ABI versions:
[ 9.423] X.Org ANSI C Emulation: 0.4
[ 9.423] X.Org Video Driver: 15.0
[ 9.423] X.Org XInput driver : 20.0
[ 9.423] X.Org Server Extension : 8.0
[ 9.424] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 9.424] Initializing built-in extension Generic Event Extension
[ 9.424] Initializing built-in extension SHAPE
[ 9.424] Initializing built-in extension MIT-SHM
[ 9.424] Initializing built-in extension XInputExtension
[ 9.424] Initializing built-in extension XTEST
[ 9.424] Initializing built-in extension BIG-REQUESTS
[ 9.424] Initializing built-in extension SYNC
[ 9.424] Initializing built-in extension XKEYBOARD
[ 9.424] Initializing built-in extension XC-MISC
[ 9.424] Initializing built-in extension SECURITY
[ 9.424] Initializing built-in extension XINERAMA
[ 9.424] Initializing built-in extension XFIXES
[ 9.424] Initializing built-in extension RENDER
[ 9.424] Initializing built-in extension RANDR
[ 9.424] Initializing built-in extension COMPOSITE
[ 9.424] Initializing built-in extension DAMAGE
[ 9.424] Initializing built-in extension MIT-SCREEN-SAVER
[ 9.424] Initializing built-in extension DOUBLE-BUFFER
[ 9.424] Initializing built-in extension RECORD
[ 9.424] Initializing built-in extension DPMS
[ 9.424] Initializing built-in extension Present
[ 9.424] Initializing built-in extension DRI3
[ 9.424] Initializing built-in extension X-Resource
[ 9.424] Initializing built-in extension XVideo
[ 9.424] Initializing built-in extension XVideo-MotionCompensation
[ 9.424] Initializing built-in extension SELinux
[ 9.424] Initializing built-in extension XFree86-VidModeExtension
[ 9.425] Initializing built-in extension XFree86-DGA
[ 9.425] Initializing built-in extension XFree86-DRI
[ 9.425] Initializing built-in extension DRI2
[ 9.425] (II) LoadModule: "glx"
[ 9.428] (WW) Warning, couldn\'t open module glx
[ 9.428] (II) UnloadModule: "glx"
[ 9.428] (II) Unloading glx
[ 9.428] (EE) Failed to load module "glx" (module does not exist, 0)
[ 9.428] (II) LoadModule: "armsoc"
[ 9.429] (II) Loading /usr/lib/xorg/modules/drivers/armsoc_drv.so
[ 9.430] (II) Module armsoc: vendor="X.Org Foundation"
[ 9.430] compiled for 1.15.1, module version = 0.0.1
[ 9.430] Module class: X.Org Video Driver
[ 9.430] ABI class: X.Org Video Driver, version 15.0
[ 9.430] (II) ARMSOC: Driver for TI OMAP: exynos5
[ 9.430] (++) using VT number 7
[ 9.436] (WW) Falling back to old probe method for armsoc
[ 9.436] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 9.436] (II) ARMSOC(0): Creating default Display subsection in Screen section
[ 9.436] (**) ARMSOC(0): Depth 24, (--) framebuffer bpp 32
[ 9.436] (==) ARMSOC(0): RGB weight 888
[ 9.436] (==) ARMSOC(0): Using gamma correction (1.0, 1.0, 1.0)
[ 9.436] (==) ARMSOC(0): Default visual is TrueColor
[ 9.436] (II) ARMSOC(0): Chipset: exynos5
[ 9.436] (II) ARMSOC(0): Setting the video modes ...
[ 9.436] (II) ARMSOC(0): [CRTC:21] HW Cursor using [BO:1]
[ 9.436] (II) ARMSOC(0): [CRTC:26] HW Cursor using [BO:2]
[ 9.437] (II) ARMSOC(0): Output HDMI-1 has no monitor section
[ 9.438] (II) ARMSOC(0): Output VGA-1 has no monitor section
[ 9.439] (II) ARMSOC(0): EDID for output HDMI-1
[ 9.439] (II) ARMSOC(0): Manufacturer: RKC Model: 4448 Serial#: 1
[ 9.439] (II) ARMSOC(0): Year: 2004 Week: 20
[ 9.439] (II) ARMSOC(0): EDID Version: 1.3
[ 9.439] (II) ARMSOC(0): Digital Display Input
[ 9.439] (II) ARMSOC(0): Max Image Size [cm]: horiz.: 80 vert.: 45
[ 9.439] (II) ARMSOC(0): Gamma: 2.20
[ 9.439] (II) ARMSOC(0): No DPMS capabilities specified
[ 9.439] (II) ARMSOC(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 9.439] (II) ARMSOC(0): First detailed timing is preferred mode
[ 9.439] (II) ARMSOC(0): redX: 0.625 redY: 0.340 greenX: 0.280 greenY: 0.595
[ 9.439] (II) ARMSOC(0): blueX: 0.155 blueY: 0.070 whiteX: 0.283 whiteY: 0.298
[ 9.439] (II) ARMSOC(0): Manufacturer\'s mask: 0
[ 9.439] (II) ARMSOC(0): #0: hsize: 472 vsize 295 refresh: 82 vid: 5660
[ 9.439] (II) ARMSOC(0): #0: hsize: 504 vsize 378 refresh: 84 vid: 22560
[ 9.439] (II) ARMSOC(0): #0: hsize: 600 vsize 375 refresh: 97 vid: 9516
[ 9.439] (II) ARMSOC(0): #0: hsize: 248 vsize 139 refresh: 64 vid: 50176
[ 9.439] (II) ARMSOC(0): #0: hsize: 1384 vsize 865 refresh: 93 vid: 8590
[ 9.439] (II) ARMSOC(0): #1: hsize: 2040 vsize 1275 refresh: 105 vid: 11744
[ 9.439] (II) ARMSOC(0): #1: hsize: 376 vsize 235 refresh: 76 vid: 4112
[ 9.439] (II) ARMSOC(0): #1: hsize: 744 vsize 465 refresh: 62 vid: 574
[ 9.439] (II) ARMSOC(0): #1: hsize: 248 vsize 155 refresh: 79 vid: 4864
[ 9.439] (II) ARMSOC(0): #1: hsize: 1384 vsize 865 refresh: 93 vid: 8590
[ 9.439] (II) ARMSOC(0): Supported detailed timing:
[ 9.439] (II) ARMSOC(0): clock: 74.2 MHz Image Size: 522 x 32 mm
[ 9.439] (II) ARMSOC(0): h_active: 1280 h_sync: 1280 h_sync_end 1320 h_blank_end 1650 h_border: 32
[ 9.440] (II) ARMSOC(0): v_active: 720 v_sync: 724 v_sync_end 729 v_blanking: 750 v_border: 32
[ 9.440] (II) ARMSOC(0): Stereo: left channel on sync
[ 9.440] side-by-side interleaved(II) ARMSOC(0): Monitor name: GENERIC
[ 9.440] (II) ARMSOC(0): Supported detailed timing:
[ 9.440] (II) ARMSOC(0): clock: 74.2 MHz Image Size: 708 x 398 mm
[ 9.440] (II) ARMSOC(0): h_active: 1280 h_sync: 1390 h_sync_end 1430 h_blank_end 1650 h_border: 0
[ 9.440] (II) ARMSOC(0): v_active: 720 v_sync: 725 v_sync_end 730 v_blanking: 750 v_border: 0
[ 9.440] (II) ARMSOC(0): clock: 25.2 MHz Image Size: 530 x 398 mm
[ 9.440] (II) ARMSOC(0): h_active: 640 h_sync: 648 h_sync_end 744 h_blank_end 800 h_border: 8
[ 9.440] (II) ARMSOC(0): v_active: 480 v_sync: 482 v_sync_end 484 v_blanking: 525 v_border: 8
[ 9.440] (II) ARMSOC(0): clock: 27.0 MHz Image Size: 531 x 398 mm
[ 9.440] (II) ARMSOC(0): h_active: 1440 h_sync: 1478 h_sync_end 1602 h_blank_end 1716 h_border: 0
[ 9.440] (II) ARMSOC(0): v_active: 240 v_sync: 244 v_sync_end 247 v_blanking: 262 v_border: 0
[ 9.440] (II) ARMSOC(0): clock: 148.5 MHz Image Size: 708 x 398 mm
[ 9.440] (II) ARMSOC(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 9.441] (II) ARMSOC(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 9.441] (II) ARMSOC(0): Number of EDID sections to follow: 1
[ 9.441] (II) ARMSOC(0): EDID (in hex):
[ 9.441] (II) ARMSOC(0): 00ffffffffffff004963484401000000
[ 9.441] (II) ARMSOC(0): 140e010380502d780a0dc9a057479827
[ 9.441] (II) ARMSOC(0): 12484c00000001010101010101010101
[ 9.441] (II) ARMSOC(0): 010101010101000000fa001c1620582c
[ 9.441] (II) ARMSOC(0): 2500c48e2100000a000000fa00e02d10
[ 9.441] (II) ARMSOC(0): 103e0200138e2100000a011d007251d0
[ 9.441] (II) ARMSOC(0): 1e20002845000a2020202020000000fc
[ 9.441] (II) ARMSOC(0): 0047454e455249430a20202020200150
[ 9.441] (WW) ARMSOC(0): Output HDMI-1: Strange aspect ratio (522/32), consider adding a quirk
[ 9.441] (II) ARMSOC(0): EDID vendor "RKC", prod id 17480
[ 9.441] (II) ARMSOC(0): DDCModeFromDetailedTiming: Ignoring: We don\'t handle stereo.
[ 9.441] (II) ARMSOC(0): Printing DDC gathered Modelines:
[ 9.441] (II) ARMSOC(0): Modeline "472x295"x82.0 14.85 472 480 528 584 295 296 299 310 -hsync +vsync (25.4 kHz e)
[ 9.441] (II) ARMSOC(0): Modeline "504x378"x84.0 21.07 504 520 568 632 378 379 382 397 -hsync +vsync (33.3 kHz e)
[ 9.442] (II) ARMSOC(0): Modeline "600x375"x97.0 29.88 600 624 688 776 375 376 379 397 -hsync +vsync (38.5 kHz e)
[ 9.442] (II) ARMSOC(0): Modeline "248x139"x64.0 2.30 248 232 248 248 139 140 143 145 -hsync +vsync (9.3 kHz e)
[ 9.442] (II) ARMSOC(0): Modeline "1384x865"x93.0 159.63 1384 1480 1632 1880 865 866 869 913 -hsync +vsync (84.9 kHz e)
[ 9.442] (II) ARMSOC(0): Modeline "248x2040"x1275.0 3135.89 248 272 304 360 2040 2041 2044 6832 -hsync +vsync (8710.8 kHz e)
[ 9.442] (II) ARMSOC(0): Modeline "11744x376"x235.0 1637.85 11744 12632 13920 16096 376 377 380 433 -hsync +vsync (101.8 kHz e)
[ 9.442] (II) ARMSOC(0): Modeline "4112x744"x465.0 2710.87 4112 4504 4968 5824 744 745 748 1001 -hsync +vsync (465.5 kHz e)
[ 9.442] (II) ARMSOC(0): Modeline "2040x1275"x105.0 401.49 2040 2208 2432 2824 1275 1276 1279 1354 -hsync +vsync (142.2 kHz e)
[ 9.442] (II) ARMSOC(0): Modeline "376x235"x76.0 8.23 376 376 408 440 235 236 239 246 -hsync +vsync (18.7 kHz e)
[ 9.442] (II) ARMSOC(0): Modeline "744x465"x62.0 27.97 744 768 840 936 465 466 469 482 -hsync +vsync (29.9 kHz e)
[ 9.442] (II) ARMSOC(0): Modeline "248x155"x79.0 3.40 248 232 256 264 155 156 159 163 -hsync +vsync (12.9 kHz e)
[ 9.442] (II) ARMSOC(0): Modeline "0x5"x522.0 0.00 0 0 0 0 5 6 9 8 -hsync +vsync (4.2 kHz e)
[ 9.442] (II) ARMSOC(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 9.442] (II) ARMSOC(0): Modeline "640x480"x0.0 25.18 640 648 744 800 480 482 484 525 -hsync -vsync (31.5 kHz e)
[ 9.442] (II) ARMSOC(0): Modeline "1440x480i"x0.0 27.00 1440 1478 1602 1716 480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[ 9.442] (II) ARMSOC(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 9.442] (II) ARMSOC(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 9.442] (II) ARMSOC(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 9.442] (II) ARMSOC(0): Printing probed modes for output HDMI-1
[ 9.442] (II) ARMSOC(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz eP)
[ 9.442] (II) ARMSOC(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 9.442] (II) ARMSOC(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 9.442] (II) ARMSOC(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 9.442] (II) ARMSOC(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 9.442] (II) ARMSOC(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 9.442] (II) ARMSOC(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 9.442] (II) ARMSOC(0): Modeline "640x480"x60.0 25.18 640 648 744 800 480 482 484 525 -hsync -vsync (31.5 kHz e)
[ 9.442] (II) ARMSOC(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 9.443] (II) ARMSOC(0): EDID for output VGA-1
[ 9.443] (II) ARMSOC(0): Output HDMI-1 connected
[ 9.443] (II) ARMSOC(0): Output VGA-1 disconnected
[ 9.443] (II) ARMSOC(0): Using exact sizes for initial modes
[ 9.443] (II) ARMSOC(0): Output HDMI-1 using initial mode 1280x720
[ 9.443] (II) ARMSOC(0): Got KMS resources
[ 9.443] (**) ARMSOC(0): Display dimensions: (800, 450) mm
[ 9.443] (**) ARMSOC(0): DPI set to (40, 40)
[ 9.443] (II) Loading sub module "dri2"
[ 9.443] (II) LoadModule: "dri2"
[ 9.443] (II) Module "dri2" already built-in
[ 9.443] (II) Loading sub module "exa"
[ 9.443] (II) LoadModule: "exa"
[ 9.444] (II) Loading /usr/lib/xorg/modules/libexa.so
[ 9.444] (II) Module exa: vendor="X.Org Foundation"
[ 9.444] compiled for 1.15.1, module version = 2.6.0
[ 9.444] ABI class: X.Org Video Driver, version 15.0
[ 9.444] (II) Loading sub module "fb"
[ 9.444] (II) LoadModule: "fb"
[ 9.444] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 9.445] (II) Module fb: vendor="X.Org Foundation"
[ 9.445] compiled for 1.15.1, module version = 1.0.0
[ 9.445] ABI class: X.Org ANSI C Emulation, version 0.4
[ 9.445] (--) Depth 24 pixmap format is 32 bpp
[ 9.472] (II) ARMSOC(0): Initialized a depth-32 visual for XRGB8888
[ 9.472] (II) ARMSOC(0): Soft EXA mode
[ 9.472] (II) EXA(0): Driver allocated offscreen pixmaps
[ 9.472] (II) EXA(0): Driver registered support for the following operations:
[ 9.472] (II) Solid
[ 9.472] (II) Copy
[ 9.472] (II) Composite (RENDER acceleration)
[ 9.472] (II) ARMSOC(0): [DRI2] Setup complete
[ 9.472] (II) ARMSOC(0): [DRI2] DRI driver: armsoc
[ 9.472] (==) ARMSOC(0): Backing store enabled
[ 9.472] (==) ARMSOC(0): Silken mouse enabled
[ 9.474] (II) ARMSOC(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 9.475] (==) ARMSOC(0): DPMS enabled
[ 9.475] (--) RandR disabled
[ 9.488] (II) SELinux: Disabled on system
[ 9.490] (II) ARMSOC(0): Setting screen physical size to 338 x 190
[ 9.547] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[ 9.552] (II) config/udev: Adding drm device (/dev/dri/card0) card0 /sys/devices/display-subsystem.4/drm/card0
[ 9.552] (II) config/udev: Ignoring already known drm device (/dev/dri/card0)
[ 9.553] (II) config/udev: Adding input device gpio_ir_recv (/dev/input/event0)
[ 9.553] (**) gpio_ir_recv: Applying InputClass "evdev keyboard catchall"
[ 9.553] (II) LoadModule: "evdev"
[ 9.553] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 9.560] (II) Module evdev: vendor="X.Org Foundation"
[ 9.561] compiled for 1.15.0, module version = 2.8.2
[ 9.561] Module class: X.Org XInput Driver
[ 9.561] ABI class: X.Org XInput driver, version 20.0
[ 9.561] (II) Using input driver \'evdev\' for \'gpio_ir_recv\'
[ 9.561] (**) gpio_ir_recv: always reports core events
[ 9.561] (**) evdev: gpio_ir_recv: Device: "/dev/input/event0"
[ 9.561] (--) evdev: gpio_ir_recv: Vendor 0x1 Product 0x1
[ 9.561] (--) evdev: gpio_ir_recv: Found keys
[ 9.561] (II) evdev: gpio_ir_recv: Configuring as keyboard
[ 9.561] (**) Option "config_info" "udev:/sys/devices/gpio-ir-receiver.13/rc/rc0/input0/event0"
[ 9.561] (II) XINPUT: Adding extended input device "gpio_ir_recv" (type: KEYBOARD, id 6)
[ 9.561] (**) Option "xkb_rules" "evdev"
[ 9.561] (**) Option "xkb_model" "pc105"
[ 9.561] (**) Option "xkb_layout" "us"
[ 9.562] (II) config/udev: Adding input device gpio-keys.12 (/dev/input/event3)
[ 9.562] (**) gpio-keys.12: Applying InputClass "evdev keyboard catchall"
[ 9.562] (II) Using input driver \'evdev\' for \'gpio-keys.12\'
[ 9.562] (**) gpio-keys.12: always reports core events
[ 9.562] (**) evdev: gpio-keys.12: Device: "/dev/input/event3"
[ 9.562] (--) evdev: gpio-keys.12: Vendor 0x1 Product 0x1
[ 9.562] (--) evdev: gpio-keys.12: Found keys
[ 9.562] (II) evdev: gpio-keys.12: Configuring as keyboard
[ 9.562] (**) Option "config_info" "udev:/sys/devices/gpio-keys.12/input/input3/event3"
[ 9.562] (II) XINPUT: Adding extended input device "gpio-keys.12" (type: KEYBOARD, id 7)
[ 9.562] (**) Option "xkb_rules" "evdev"
[ 9.562] (**) Option "xkb_model" "pc105"
[ 9.562] (**) Option "xkb_layout" "us"
[ 9.563] (II) config/udev: Adding input device RockchipHDMI HDMI Jack (/dev/input/event2)
[ 9.563] (II) No input driver specified, ignoring this device.
[ 9.563] (II) This device may have been added with another device file.
[ 9.563] (II) config/udev: Adding input device MCE IR Keyboard/Mouse (gpio-rc-recv) (/dev/input/event1)
[ 9.563] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): Applying InputClass "evdev pointer catchall"
[ 9.563] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): Applying InputClass "evdev keyboard catchall"
[ 9.563] (II) Using input driver \'evdev\' for \'MCE IR Keyboard/Mouse (gpio-rc-recv)\'
[ 9.564] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): always reports core events
[ 9.564] (**) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Device: "/dev/input/event1"
[ 9.564] (--) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Vendor 0 Product 0
[ 9.564] (--) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Found 3 mouse buttons
[ 9.564] (--) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Found relative axes
[ 9.564] (--) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Found x and y relative axes
[ 9.564] (--) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Found keys
[ 9.564] (II) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Configuring as mouse
[ 9.564] (II) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Configuring as keyboard
[ 9.564] (**) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): YAxisMapping: buttons 4 and 5
[ 9.564] (**) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 9.564] (**) Option "config_info" "udev:/sys/devices/virtual/input/input1/event1"
[ 9.564] (II) XINPUT: Adding extended input device "MCE IR Keyboard/Mouse (gpio-rc-recv)" (type: KEYBOARD, id 8)
[ 9.564] (**) Option "xkb_rules" "evdev"
[ 9.564] (**) Option "xkb_model" "pc105"
[ 9.564] (**) Option "xkb_layout" "us"
[ 9.564] (II) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): initialized for relative axes.
[ 9.564] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): (accel) keeping acceleration scheme 1
[ 9.564] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): (accel) acceleration profile 0
[ 9.564] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): (accel) acceleration factor: 2.000
[ 9.564] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): (accel) acceleration threshold: 4
