android 如何锁频CPU或GPU
各位大神,android可以实现cpu或GPU跑在一个频率上吗?
看了cpufreq调频,但是如何锁频?android有实现吗?
  1. 方式一: 可以在内核代码中,将其他频率屏蔽掉,比如RK3188的是修改 kernel/arch/arm/mach-rk3188/board-rk31-box.c
    static struct cpufreq_frequency_table dvfs_arm_table 频率表,将里面不需要的频率值屏蔽掉
    static struct cpufreq_frequency_table dvfs_arm_table = {
    // {.frequency = 312 * 1000, .index = 900 * 1000},
    // {.frequency = 504 * 1000, .index = 925 * 1000},
    // {.frequency = 816 * 1000, .index = 1000 * 1000},
    {.frequency = 1008 * 1000,      .index = 1075 * 1000},
    {.frequency = 1200 * 1000,      .index = 1150 * 1000},
    {.frequency = 1416 * 1000,      .index = 1250 * 1000},
    {.frequency = 1512 * 1000,      .index = 1250 * 1000},
    // {.frequency = 1608 * 1000,      .index = 1250 * 1000},
    {.frequency = CPUFREQ_TABLE_END},
  1. 方式二: 如果是想直接固定跑在最高主频上,可以在内核配置中打开CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE:
    CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE=y
    # CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_INTERACTIVE is not set
  2. 方式三: 如果想固定跑某一个主频(不是最高主频),比如1.4Ghz(1416000), 可以在系统开机初始化过程中,使用脚本进行主频固定:
    echo “userspace” >/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
    echo “1416000” >/sys/devices/system/cpu/cpu0/cpufreq/scaling_setspeed (当然,这个主频值在cpufreq_frequency_table dvfs_arm_table频率表里面要能找得到)
