isle Posted at 10/19/2016 15:25
the version of mali driver is r9p0 .
the score of glmark2-es2 is lower the before ,because use a ne …
Actually i am new to this linux development…
i have build Android and flash the image in RK3288 board but now i want to run ubuntu in rk3288 board…
How can i get the source for ubuntu, build it and flash it…
Thank you in advance…
Is there any way to get the VAAPI support working with Chromium? Also, why is there a reference to a server on your local network in /etc/apt/apt.conf so apt doesn’t work?
Hi wouter
1 I don’t know whether the VAAPI can use be uesd in chromuim or not . but I will have a try later.
2 Yes ,please remove /etc/apt/apt.conf,that is my fault . I should delete it when the firmware was build .
we build a proxy server to accelerate the speed when we use the “apt” command.
I flashed this image, and the OpenGL works, but I can’t get Wifi working - is there any image that has working wifi and OpenGL? I can’t seem to find any.
To clarify, I was wondering if there’s an image that has both Wifi and OpenGL working without needing to recompile a kernel or fiddle with drivers. The wifi seemed broken in this image.
