New PCB(RK3128) boot up fail [Solved]
Hi all,
New PCB
1st. burn NANDFlash in Maskrom Mode. ( img: FirePrime_Ubuntu15.04_201603030939.img )
2nd. boot up fail & Console message shown as below:
============================================ START
DDR Version 2.04 20150121
1A1A1B1B 3
DDR3
1A1B1B1B F
Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=8 Size=1024MB
mach:2
Boot1 Release Time: 2015-05-25, version: 2.25
ChipType = a 1359
No.1 FLASH ID:2c 64 44 4b a9 0
ECC:60
*V▒k%▒▒▒▒0 20
StorageInit ok = 463950
theL
U-Boot 2014.10-RK3128-10 (Dec 28 2015 - 14:53:17)
CPU: rk3128
CPU’s clock information:
arm pll = 300000000HZ
periph pll = 594000000HZ
ddr pll = 600000000HZ
codec pll = 400000000HZ
Uboot as second level loader
DRAM: Found dram banks:1
128 MiB
rk dma▒.▒K▒▒▒▒init OK!
GetParam
check parameter success
Unknow param: MACHINE_MODEL:rk312x!
Unknow param: MACHINE_ID:007!
power key: bank-3 pin-23
can’t find dts node for act8846
can’t find dts node for rk808
v01: power_hold GPIO pull up
cpu_det GPIO pull up
pmic:rk818
can’t find dts node for ADC
Enter power_led_init
id block not found.
prog error: = 3f0853
prog error: = 3f0854
prog error: = 3f0855
… (prog error: = +++)
============================================ END
SOS
Thank you.
Hello world!
Update information#
[ 1.461541] rk30xxnand_ko: module license ‘’ taints kernel.
[ 1.461584] Disabling lock debugging due to kernel taint
[ 1.464297] rknand_init:
[ 1.464402] FtlInit fffffffe
[ 1.464420] NandInit fail
[ 1.464438] init_nand_blk_dev:ret = ffffffff
execute insert module manually as follow:
(initramfs) insmod /lib/modules/rk30xxnand_ko.ko.3.10.0
returns error:
[ 2445.349965] rknand_init:
insmod: can’t insert ‘/lib/modules/rk30xxnand_ko.ko.3.10.0’: Operation not permitted
Complete log:
(initramfs) dmesg
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Linux version 3.10.0 (firefly@tchip-server) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #126 SMP PREEMPT Thu Mar 3 09:30:58 CST 2016
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] Machine: Rockchip RK3128, model: rockchip,rk3128
[ 0.000000] ion heap(cma): base(0) size(800000) align(0)
[ 0.000000] cma: CMA: reserved 8 MiB at 9f800000
[ 0.000000] ion_reserve: cma reserved base 9f800000 size 8388608
[ 0.000000] cma: CMA: reserved 16 MiB at 8e800000
[ 0.000000] On node 0 totalpages: 262144
[ 0.000000] free_area_init_node: node 0, pgdat c0d16c00, node_mem_map c0e41000
[ 0.000000] Normal zone: 1520 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 194560 pages, LIFO batch:31
[ 0.000000] HighMem zone: 528 pages used for memmap
[ 0.000000] HighMem zone: 67584 pages, LIFO batch:15
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c166b000 s14016 r8192 d14656 u36864
[ 0.000000] pcpu-alloc: s14016 r8192 d14656 u36864 alloc=9*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260624
[ 0.000000] Kernel command line: console=ttyFIQ0,115200 earlyprintk root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@01
[ 0.000000] allocated 2097152 bytes of page_cgroup
[ 0.000000] Memory: 1024MB = 1024MB total
[ 0.000000] Memory: 995268k/995268k available, 53308k reserved, 262144K highmem
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0ba6824 (11899 kB)
[ 0.000000] .init : 0xc0ba7000 - 0xc0c016c0 ( 362 kB)
[ 0.000000] .data : 0xc0c02000 - 0xc0d1e438 (1138 kB)
[ 0.000000] .bss : 0xc0d1e438 - 0xc0e404fc (1161 kB)
[ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000
[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1
[ 0.000000] rkclk_init_clks: cnt_parent = 25
[ 0.000000] rkclk_init_clks: cnt_rate = 17
[ 0.000000] process version: 0
[ 0.000000] channel:0, lkg:31
[ 0.000000] FirePrime hardware version: V01
[ 0.000000] Console: colour dummy device 80x30
[ 0.417465] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.417492] pid_max: default: 32768 minimum: 301
[ 0.417688] Security Framework initialized
[ 0.417717] SELinux: Initializing.
[ 0.417766] SELinux: Starting in permissive mode
[ 0.417854] Mount-cache hash table entries: 512
[ 0.419060] Initializing cgroup subsys debug
[ 0.419088] Initializing cgroup subsys memory
[ 0.419138] Initializing cgroup subsys freezer
[ 0.419209] CPU: Testing write buffer coherency: ok
[ 0.419735] /cpus/cpu@0 missing clock-frequency property
[ 0.419765] /cpus/cpu@1 missing clock-frequency property
[ 0.419784] /cpus/cpu@2 missing clock-frequency property
[ 0.419803] /cpus/cpu@3 missing clock-frequency property
[ 0.419877] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.419947] Setting up static identity map for 0xc0852b50 - 0xc0852ba8
[ 0.422038] last_log: 0x8e100000 map to 0xf0004000 and copy to 0xf0086000, size 0x80000 early 0x14d7 (version 3.0)
[ 0.495300] CPU1: Booted secondary processor
[ 0.495356] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.515003] CPU2: Booted secondary processor
[ 0.515048] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.534753] CPU3: Booted secondary processor
[ 0.534796] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.534983] Brought up 4 CPUs
[ 0.535035] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.535050] CPU: All CPU(s) started in SVC mode.
[ 0.536458] devtmpfs: initialized
[ 0.545451] pinctrl core: initialized pinctrl subsystem
[ 0.545952] regulator-dummy: no parameters
[ 0.547458] NET: Registered protocol family 16
[ 0.550270] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.550946] ion_snapshot: 0x8e218000 map to 0xf0107000 and copy to 0xc0e1ba84 (version 0.1)
[ 0.551167] Registered FIQ tty driver
[ 0.553410] console [ttyFIQ0] enabled
[ 0.553817] Registered fiq debugger ttyFIQ0
[ 0.555085] rockchip_get_bank_data:name=/pinctrl@20008000/gpio0@2007c000 start=0x2007c000,end=0x2007c0ff
[ 0.555228] rockchip_get_bank_data:name=/pinctrl@20008000/gpio1@20080000 start=0x20080000,end=0x200800ff
[ 0.555310] rockchip_get_bank_data:name=/pinctrl@20008000/gpio2@20084000 start=0x20084000,end=0x200840ff
[ 0.555389] rockchip_get_bank_data:name=/pinctrl@20008000/gpio3@20088000 start=0x20088000,end=0x200880ff
[ 0.555478] rockchip_get_bank_data:name=/pinctrl@20008000/gpio15@2008A000 start=0x20086000,end=0x200860ff
[ 0.555551] rockchip_pinctrl_probe:name=rk312x-GPIO,type=5
[ 0.555580] rockchip_pinctrl_probe:name=base start=0x20008000,end=0x200080a7
[ 0.555609] rockchip_pinctrl_probe:name=mux start=0x200080a8,end=0x200080f3
[ 0.555637] rockchip_pinctrl_probe:name=pull start=0x20008118,end=0x20008137
[ 0.555665] rockchip_pinctrl_probe:name=drv start=0x20008100,end=0x20008103
[ 0.555801] gpiochip_add: registered GPIOs 0 to 31 on device: gpio0
[ 0.555913] gpiochip_add: registered GPIOs 32 to 63 on device: gpio1
[ 0.556012] gpiochip_add: registered GPIOs 64 to 95 on device: gpio2
[ 0.556109] gpiochip_add: registered GPIOs 96 to 127 on device: gpio3
[ 0.556218] gpiochip_add: registered GPIOs 128 to 159 on device: gpio15
[ 0.558385] rockchip_pinctrl_probe:init ok
[ 0.566005] rk_iommu 1010e300.vop_mmu: (vop) Enter
[ 0.566062] rk_iommu 1010e300.vop_mmu: skip request vop mmu irq
[ 0.566154] rk_iommu 1010e300.vop_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.566183] rk_iommu 1010e300.vop_mmu: (vop) Initialized
[ 0.566456] rk_iommu 10104440.hevc_mmu: (hevc) Enter
[ 0.566613] rk_iommu 10104440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.566645] rk_iommu 10104440.hevc_mmu: (hevc) Initialized
[ 0.566911] rk_iommu 10106800.vpu_mmu: (vpu) Enter
[ 0.567037] rk_iommu 10106800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.567068] rk_iommu 10106800.vpu_mmu: (vpu) Initialized
[ 0.567318] rk_iommu 10108800.iep_mmu: (iep) Enter
[ 0.567459] rk_iommu 10108800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.567491] rk_iommu 10108800.iep_mmu: (iep) Initialized
[ 0.568706] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.568739] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.569019] DDR DEBUG: version 1.02 20140828
[ 0.569043] DDR DEBUG: DRAM Type:DDR3
[ 0.569068] DDR DEBUG: 1 CS, ROW=15, Bank=8, COL=10, Total Capability=1024MB
[ 0.569114] DDR DEBUG: init success!!! freq=300MHz
[ 0.622381] bio: create slab at 0
[ 0.623485] Rockchip hdmi driver version 2.0
[ 0.623485] .
[ 0.625231] SCSI subsystem initialized
[ 0.625593] usbcore: registered new interface driver usbfs
[ 0.625701] usbcore: registered new interface driver hub
[ 0.625930] usbcore: registered new device driver usb
[ 0.626926] of_get_named_gpio_flags exited with status 116
[ 0.626985] of_get_named_gpio_flags exited with status 30
[ 0.627787] of_get_named_gpio_flags exited with status 1
[ 0.627832] of_get_named_gpio_flags exited with status 0
[ 0.628088] rockchip_i2c 20072000.i2c: i2c-0: Rockchip I2C adapter
[ 0.630329] of_get_named_gpio_flags exited with status 3
[ 0.630376] of_get_named_gpio_flags exited with status 2
[ 0.630621] rockchip_i2c 20056000.i2c: i2c-1: Rockchip I2C adapter
[ 0.630796] media: Linux media interface: v0.10
[ 0.630885] Linux video capture interface: v2.00
[ 0.631094] pps_core: LinuxPPS API ver. 1 registered
[ 0.631118] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.631166] PTP clock support registered
[ 0.631264] i2c-core: driver [bq24296] using legacy suspend method
[ 0.631287] i2c-core: driver [bq24296] using legacy resume method
[ 0.632662] Rockchip ion module is successfully loaded (v1.1)
[ 0.632978] Advanced Linux Sound Architecture Driver Initialized.
[ 0.633740] Bluetooth: Core ver 2.16
[ 0.633818] NET: Registered protocol family 31
[ 0.633840] Bluetooth: HCI device and connection manager initialized
[ 0.633885] Bluetooth: HCI socket layer initialized
[ 0.633917] Bluetooth: L2CAP socket layer initialized
[ 0.633972] Bluetooth: SCO socket layer initialized
[ 0.634412] cfg80211: Calling CRDA to update world regulatory domain
[ 0.636077] act8931_i2c_probe,line=715
[ 0.636872] The device is not act8931
[ 0.637534] rk818_i2c_probe,line=1282
[ 0.637844] rk818_pre_init,line=1197
[ 0.645382] of_get_named_gpio_flags exited with status 118
[ 0.645417] of_get_named_gpio_flags exited with status 113
[ 0.645442] of_get_named_gpio_flags exited with status 25
[ 0.645459] ------------[ cut here ]------------
[ 0.645495] WARNING: at drivers/gpio/gpiolib.c:160 gpio_ensure_requested+0x4c/0xb4()
[ 0.645518] autorequest GPIO-25
[ 0.645535] Modules linked in:
[ 0.645564] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.0 #126
[ 0.645615] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 0.645656] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68)
[ 0.645696] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c)
[ 0.645736] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (gpio_ensure_requested+0x4c/0xb4)
[ 0.645776] [] (gpio_ensure_requested+0x4c/0xb4) from [] (gpiod_direction_output+0x80/0x2b0)
[ 0.645820] [] (gpiod_direction_output+0x80/0x2b0) from [] (rk818_parse_dt+0x170/0x20c)
[ 0.645864] [] (rk818_parse_dt+0x170/0x20c) from [] (rk818_i2c_probe+0xf8/0x344)
[ 0.645909] [] (rk818_i2c_probe+0xf8/0x344) from [] (i2c_device_probe+0xa8/0xd4)
[ 0.645952] [] (i2c_device_probe+0xa8/0xd4) from [] (really_probe+0xa8/0x20c)
[ 0.645990] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48)
[ 0.646029] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84)
[ 0.646067] [] (__driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90)
[ 0.646105] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c)
[ 0.646143] [] (bus_add_driver+0xac/0x20c) from [] (driver_register+0x9c/0x138)
[ 0.646182] [] (driver_register+0x9c/0x138) from [] (i2c_register_driver+0x40/0xac)
[ 0.646224] [] (i2c_register_driver+0x40/0xac) from [] (rk818_module_init+0x10/0x34)
[ 0.646264] [] (rk818_module_init+0x10/0x34) from [] (do_one_initcall+0x34/0xc8)
[ 0.646304] [] (do_one_initcall+0x34/0xc8) from [] (do_initcalls+0x70/0xa0)
[ 0.646342] [] (do_initcalls+0x70/0xa0) from [] (kernel_init_freeable+0x90/0x130)
[ 0.646383] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4)
[ 0.646423] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c)
[ 0.646481] —[ end trace ee001b13fb2e76e3 ]—
[ 0.646520] cpu_det_gpio up
[ 0.646556] of_get_named_gpio_flags exited with status 64
[ 0.646572] ------------[ cut here ]------------
[ 0.646600] WARNING: at drivers/gpio/gpiolib.c:160 gpio_ensure_requested+0x4c/0xb4()
[ 0.646621] autorequest GPIO-64
[ 0.646637] Modules linked in:
[ 0.646663] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 3.10.0 #126
[ 0.646703] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 0.646742] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68)
[ 0.646782] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c)
[ 0.646821] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (gpio_ensure_requested+0x4c/0xb4)
[ 0.646861] [] (gpio_ensure_requested+0x4c/0xb4) from [] (gpiod_direction_output+0x80/0x2b0)
[ 0.646903] [] (gpiod_direction_output+0x80/0x2b0) from [] (rk818_parse_dt+0x1c4/0x20c)
[ 0.646945] [] (rk818_parse_dt+0x1c4/0x20c) from [] (rk818_i2c_probe+0xf8/0x344)
[ 0.646989] [] (rk818_i2c_probe+0xf8/0x344) from [] (i2c_device_probe+0xa8/0xd4)
[ 0.647030] [] (i2c_device_probe+0xa8/0xd4) from [] (really_probe+0xa8/0x20c)
[ 0.647068] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48)
[ 0.647106] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84)
[ 0.647144] [] (__driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90)
[ 0.647182] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c)
[ 0.647220] [] (bus_add_driver+0xac/0x20c) from [] (driver_register+0x9c/0x138)
[ 0.647259] [] (driver_register+0x9c/0x138) from [] (i2c_register_driver+0x40/0xac)
[ 0.647299] [] (i2c_register_driver+0x40/0xac) from [] (rk818_module_init+0x10/0x34)
[ 0.647338] [] (rk818_module_init+0x10/0x34) from [] (do_one_initcall+0x34/0xc8)
[ 0.647375] [] (do_one_initcall+0x34/0xc8) from [] (do_initcalls+0x70/0xa0)
[ 0.647414] [] (do_initcalls+0x70/0xa0) from [] (kernel_init_freeable+0x90/0x130)
[ 0.647452] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4)
[ 0.647491] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c)
[ 0.647516] —[ end trace ee001b13fb2e76e4 ]—
[ 0.647545] power_hold_gpio up
[ 0.647583] rk818_i2c_probe: rk818_pmic_sleep=0
[ 0.651568] vdd_arm: 712 ↔ 1500 mV at 1100 mV
[ 0.655923] vdd_logic: 712 ↔ 1500 mV at 1100 mV
[ 0.659763] rk818_dcdc3: 1200 mV
[ 0.664036] vccio: 1800 ↔ 3300 mV at 3000 mV
[ 0.667919] rk818_ldo1: 3300 mV
[ 0.671714] rk818_ldo2: 3000 mV
[ 0.675550] rk818_ldo3: 1100 mV
[ 0.679382] rk818_ldo4: 2800 mV
[ 0.683205] rk818_ldo5: 3000 mV
[ 0.687025] rk818_ldo6: 1200 mV
[ 0.690883] rk818_ldo7: 1800 mV
[ 0.694728] rk818_ldo8: 1800 mV
[ 0.697606] vcc_sd: 1800 ↔ 3000 mV at 3000 mV
[ 0.699087] rk818_ldo10: at 3000 mV
[ 0.700894] rk818_irq_init: rk818_pmic_irq=1
[ 0.701494] fireprime_rk818_hdmi_5v_en enable:1
[ 0.702335] i2c-core: driver [rk818] using legacy suspend method
[ 0.702363] i2c-core: driver [rk818] using legacy resume method
[ 0.703987] Switching to clocksource arch_sys_counter
[ 0.726512] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 0.740825] fb disp policy is box
[ 0.740858] uboot-logo-on:1
[ 0.740938] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.740966] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.741430] rk-screen rk_screen.9: rockchip screen probe success
[ 0.758834] NET: Registered protocol family 2
[ 0.759756] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.759983] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.760186] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.760289] TCP: reno registered
[ 0.760317] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.760385] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.760793] NET: Registered protocol family 1
[ 0.761224] of_get_named_gpio_flags: can’t parse gpios property
[ 0.763143] rk818-battery rk818-battery: not battery, enter test power mode
[ 0.784863] rk818-battery rk818-battery: v=4200, ov=4200, rv=0, c=0, pwroff_min=0
[ 0.791054] rk818-battery rk818-battery: c=0, v=4200, relax=0, ocv=4200, est=4200, calib=-1
[ 0.791813] rk818-battery rk818-battery: reg soc=0, init soc = 0, init cap=0
[ 0.820547] rk818-battery rk818-battery: battery driver version 4.0.0
[ 0.821276] Unpacking initramfs…
[ 1.101810] Freeing initrd memory: 2664K (c4bf0000 - c4e8a000)
[ 1.102814] hw perfevents: enabled with ARMv7_Cortex_A7 PMU driver, 5 counters available
[ 1.103476] vcodec_service: probe device vpu_combo.10
[ 1.103512] vcodec_service: No reset resource define
[ 1.103532] vcodec_service: No reset resource define
[ 1.103550] vcodec_service: No reset resource define
[ 1.103671] vcodec vpu_combo.10: failed on clk_get clk_cabac
[ 1.103779] vcodec_service: vpu_combo.10: power on
[ 1.103927] vcodec_service: probe device 10106000.vpu_service
[ 1.103988] vcodec_service: checking hw id 4831
[ 1.105376] vcodec_service: probe device 10104000.hevc_service
[ 1.105442] vcodec_service: checking hw id 6867
[ 1.106398] vcodec_service: vpu_combo.10: power off…
[ 1.106469] vcodec_service: done
[ 1.106488] vcodec_service: init success
[ 1.106665] rknandbase v1.0 2014-03-31
[ 1.106922] rknand_probe clk rate = 148500000
[ 1.107100] rknand_driver:ret = 0
[ 1.108664] audit: initializing netlink socket (disabled)
[ 1.108737] type=2000 audit(0.700:1): initialized
[ 1.110142] bounce pool size: 64 pages
[ 1.120336] fuse init (API version 7.22)
[ 1.121180] msgmni has been set to 1469
[ 1.121279] SELinux: Registering netfilter hooks
[ 1.124832] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.124871] io scheduler noop registered
[ 1.124891] io scheduler deadline registered
[ 1.125102] io scheduler cfq registered (default)
[ 1.130536] rga 1010c000.rga: rga ion client create success!
[ 1.130854] rga: Driver loaded succesfully
[ 1.130966] rga: Module initialized.
[ 1.132285] IEP Power ON
[ 1.132390] iep ion client create success!
[ 1.132848] IEP Power OFF
[ 1.132902] IEP Driver loaded succesfully
[ 1.133035] Module initialized.
[ 1.136089] dma-pl330 20078000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.136128] dma-pl330 20078000.pdma: DBUFF-64x8bytes Num_Chans-8 Num_Peri-16 Num_Events-16
[ 1.136964] rk_serial.c v1.8 2014-03-04
[ 1.137337] 20060000.serial: ttyS0 at MMIO 0x20060000 (irq = 52) is a rk29_serial.0
[ 1.137804] serial 20060000.serial: membase f014a000
[ 1.138030] 20064000.serial: ttyS1 at MMIO 0x20064000 (irq = 53) is a rk29_serial.1
[ 1.138468] serial 20064000.serial: membase f014c000
[ 1.138678] 20068000.serial: ttyS2 at MMIO 0x20068000 (irq = 54) is a rk29_serial.2
[ 1.139094] serial 20068000.serial: membase fed60000
[ 1.145122] loop: module loaded
[ 1.145249] i2c-core: driver [mpu6050B1] using legacy suspend method
[ 1.145274] i2c-core: driver [mpu6050B1] using legacy resume method
[ 1.145301] mpu_init: Probe name mpu6050B1
[ 1.145625] ak8963_mod_init: Probe name ak8963_mod
[ 1.146841] SCSI Media Changer driver v0.25
[ 1.147532] tun: Universal TUN/TAP device driver, 1.6
[ 1.147560] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.147892] vmac_init.
[ 1.148993] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 1.149026] stmmac_probe_config_dt: Can not read property: pmu_enable_level.
[ 1.149051] stmmac_probe_config_dt: clock input or output? (input).
[ 1.149074] stmmac_probe_config_dt: TX delay(0x30).
[ 1.149095] stmmac_probe_config_dt: RX delay(0x10).
[ 1.149134] of_get_named_gpio_flags exited with status 24
[ 1.149159] of_get_named_gpio_flags exited with status 88
[ 1.149176] of_get_named_gpio_flags: can’t parse gpios property
[ 1.149197] stmmac_probe_config_dt: is rockchip,rk312x-gmac
[ 1.149217] stmmc_pltfr_init:
[ 1.149235] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 1.149331] stmmc_pltfr_init: init for RGMII
[ 1.149356] tx delay=0x30
[ 1.149356] rx delay=0x10
[ 1.149590] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.149612] Normal descriptors
[ 1.149628] Ring mode enabled
[ 1.149645] DMA HW capability register supported
[ 1.149666] RX Checksum Offload Engine supported (type 2)
[ 1.149685] TX Checksum insertion supported
[ 1.149701] Wake-Up On Lan supported
[ 1.149784] Enable RX Mitigation via HW Watchdog Timer
[ 1.150690] PPP generic driver version 2.4.2
[ 1.151060] PPP BSD Compression module registered
[ 1.151087] PPP Deflate Compression module registered
[ 1.151121] PPP MPPE Compression module registered
[ 1.151143] NET: Registered protocol family 24
[ 1.151198] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.151223] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.151246] Rockchip WiFi SYS interface (V1.00) …
[ 1.151321] esp_mem_init enter date Mar 3 2016 09:30:31
[ 1.151343] esp_mem_init VERSION [V2.5]
[ 1.151425] esp_mem_init complete
[ 1.151567] usbcore: registered new interface driver catc
[ 1.151657] usbcore: registered new interface driver kaweth
[ 1.151682] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.151768] usbcore: registered new interface driver pegasus
[ 1.151853] usbcore: registered new interface driver rtl8150
[ 1.151938] usbcore: registered new interface driver r8152
[ 1.151962] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.152103] usbcore: registered new interface driver hso
[ 1.152218] usbcore: registered new interface driver asix
[ 1.152306] usbcore: registered new interface driver ax88179_178a
[ 1.152392] usbcore: registered new interface driver cdc_ether
[ 1.152479] usbcore: registered new interface driver cdc_eem
[ 1.152565] usbcore: registered new interface driver dm9601
[ 1.152649] usbcore: registered new interface driver dm9620
[ 1.152757] usbcore: registered new interface driver smsc75xx
[ 1.152875] usbcore: registered new interface driver smsc95xx
[ 1.152966] usbcore: registered new interface driver gl620a
[ 1.153054] usbcore: registered new interface driver net1080
[ 1.153140] usbcore: registered new interface driver plusb
[ 1.153227] usbcore: registered new interface driver rndis_host
[ 1.153313] usbcore: registered new interface driver cdc_subset
[ 1.153398] usbcore: registered new interface driver zaurus
[ 1.153504] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.153640] usbcore: registered new interface driver int51x1
[ 1.153730] usbcore: registered new interface driver kalmia
[ 1.153816] usbcore: registered new interface driver ipheth
[ 1.153912] usbcore: registered new interface driver sierra_net
[ 1.154001] usbcore: registered new interface driver cx82310_eth
[ 1.154122] usbcore: registered new interface driver cdc_ncm
[ 1.154213] usbcore: registered new interface driver qmi_wwan
[ 1.154303] usbcore: registered new interface driver cdc_mbim
[ 1.154326] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.156280] EHCI: ehci_rk_probe f0180000 f0180010
[ 1.156315] rockchip_ehci_host 101c0000.usb: EHCI Host Controller
[ 1.156370] rockchip_ehci_host 101c0000.usb: new USB bus registered, assigned bus number 1
[ 1.157045] rockchip_ehci_host 101c0000.usb: irq 43, io mem 0x101c0000
[ 1.176450] rockchip_ehci_host 101c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.176599] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.176632] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.176659] usb usb1: Product: EHCI Host Controller
[ 1.176683] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 1.176706] usb usb1: SerialNumber: 101c0000.usb
[ 1.177672] hub 1-0:1.0: USB hub found
[ 1.177723] hub 1-0:1.0: 1 port detected
[ 1.178122] EHCI: ehci_rk_probe ok
[ 1.178269] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.178501] ohci-rockchip 101e0000.usb: RK OHCI Host Controller
[ 1.178554] ohci-rockchip 101e0000.usb: new USB bus registered, assigned bus number 2
[ 1.178645] ohci-rockchip 101e0000.usb: irq 64, io mem 0x101e0000
[ 1.239541] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.239577] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.239604] usb usb2: Product: RK OHCI Host Controller
[ 1.239629] usb usb2: Manufacturer: Linux 3.10.0 ohci_hcd
[ 1.239653] usb usb2: SerialNumber: 101e0000.usb
[ 1.240501] hub 2-0:1.0: USB hub found
[ 1.240550] hub 2-0:1.0: 1 port detected
[ 1.241130] usbcore: registered new interface driver cdc_acm
[ 1.241158] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.241274] usbcore: registered new interface driver usblp
[ 1.241366] usbcore: registered new interface driver cdc_wdm
[ 1.241511] usbcore: registered new interface driver usb-storage
[ 1.241593] usbcore: registered new interface driver ums-alauda
[ 1.241685] usbcore: registered new interface driver ums-cypress
[ 1.241769] usbcore: registered new interface driver ums-datafab
[ 1.241848] usbcore: registered new interface driver ums_eneub6250
[ 1.241926] usbcore: registered new interface driver ums-freecom
[ 1.242005] usbcore: registered new interface driver ums-isd200
[ 1.242083] usbcore: registered new interface driver ums-jumpshot
[ 1.242161] usbcore: registered new interface driver ums-karma
[ 1.242241] usbcore: registered new interface driver ums-onetouch
[ 1.242322] usbcore: registered new interface driver ums-sddr09
[ 1.242402] usbcore: registered new interface driver ums-sddr55
[ 1.242483] usbcore: registered new interface driver ums-usbat
[ 1.242678] usbcore: registered new interface driver usbserial
[ 1.242767] usbcore: registered new interface driver usbserial_generic
[ 1.242838] usbserial: USB Serial support registered for generic
[ 1.242921] usbcore: registered new interface driver option
[ 1.242986] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.243203] usbcore: registered new interface driver trancevibrator
[ 1.243228] usb20_otg: version 3.10a 21-DEC-2012
[ 1.243893] f0200040
[ 1.243922] Core Release: 2.91a
[ 1.243943] Setting default values for core params
[ 1.244218] Using Buffer DMA mode
[ 1.244242] Periodic Transfer Interrupt Enhancement - disabled
[ 1.244263] Multiprocessor Interrupt Enhancement - disabled
[ 1.244284] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.244302] ^^^^^^^^^^^^^^^^^Device Mode
[ 1.244327] Dedicated Tx FIFOs mode
[ 1.244362] pcd_init otg_dev = ed57ff40
[ 1.244680] usb20_otg 10180000.usb: DWC OTG Controller
[ 1.244738] usb20_otg 10180000.usb: new USB bus registered, assigned bus number 3
[ 1.244800] usb20_otg 10180000.usb: irq 42, io mem 0x00000000
[ 1.244921] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.244951] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.244978] usb usb3: Product: DWC OTG Controller
[ 1.245002] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.245027] usb usb3: SerialNumber: 10180000.usb
[ 1.245957] hub 3-0:1.0: USB hub found
[ 1.246006] hub 3-0:1.0: 1 port detected
[ 1.246571] usb20_host: version 3.10a 21-DEC-2012
[ 1.247460] usbcore: registered new interface driver xpad
[ 1.247577] usbcore: registered new interface driver usb_acecad
[ 1.247676] usbcore: registered new interface driver aiptek
[ 1.247770] usbcore: registered new interface driver gtco
[ 1.247865] usbcore: registered new interface driver hanwang
[ 1.247969] usbcore: registered new interface driver kbtab
[ 1.248082] usbcore: registered new interface driver wacom
[ 1.248890] sensor_register_slave:mma8452,id=17
[ 1.248918] sensor_register_slave:gs_mc3230,id=23
[ 1.248937] gsensor_init
[ 1.248955] sensor_register_slave:mpu6880_acc,id=24
[ 1.248975] sensor_register_slave:cm3217,id=47
[ 1.248995] sensor_register_slave:cm3218,id=48
[ 1.249364] .. rk pwm remotectl v1.1 init
[ 1.249761] input: 20050030.pwm as /devices/20050030.pwm/input/input0
[ 1.253848] rtc_hym8563 0-0051: clock/calendar information is no longer guaranteed
[ 1.258256] of_get_named_gpio_flags exited with status 28
[ 1.265606] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 1.265699] i2c /dev entries driver
[ 1.266584] IR NEC protocol handler initialized
[ 1.266609] IR RC5(x) protocol handler initialized
[ 1.266628] IR RC6 protocol handler initialized
[ 1.266646] IR JVC protocol handler initialized
[ 1.266664] IR Sony protocol handler initialized
[ 1.266682] IR RC5 (streamzap) protocol handler initialized
[ 1.266701] IR SANYO protocol handler initialized
[ 1.266719] IR MCE Keyboard/mouse protocol handler initialized
[ 1.267021] usbcore: registered new interface driver uvcvideo
[ 1.267046] USB Video Class driver (1.1.1)
[ 1.267069] CamSys driver version: v0.27.1, CamSys head file version: v0.10.0
[ 1.267094] E:camsys_soc_init(87): camsys isn’t support soc: 0x31260001!
[ 1.269200] i2c-core: driver [bq27320] using legacy suspend method
[ 1.269231] i2c-core: driver [bq27320] using legacy resume method
[ 1.270006] device-mapper: uevent: version 1.0.3
[ 1.270561] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 1.271256] Bluetooth: HCI UART driver ver 2.2
[ 1.271286] Bluetooth: HCI H4 protocol initialized
[ 1.271305] Bluetooth: HCILL protocol initialized
[ 1.271326] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.19
[ 1.271346] rtk_btusb: Register usb char device interface for BT driver
[ 1.271777] usbcore: registered new interface driver rtk_btusb
[ 1.274142] cpuidle: using governor ladder
[ 1.274171] cpuidle: using governor menu
[ 1.274246] Synopsys Designware Multimedia Card Interface Driver
[ 1.274269] MHSC version = Ver 2.00 2015-06-10
[ 1.274683] dw cru_regsbase addr 0x124.
[ 1.274707] dw cru_reset_offset val 3.
[ 1.274735] dwmmc_rockchip 1021c000.rksdmmc: Version ID is 270a
[ 1.274845] dwmmc_rockchip 1021c000.rksdmmc: failed to get hpclk_mmc
[ 1.275364] dwmmc_rockchip 1021c000.rksdmmc: Using external DMA controller.
[ 1.275785] dw_mci_init_slot: fmin=400000, fmax=50000000 [mmc0]
[ 1.275837] of_get_named_gpio_flags: can’t parse gpios property
[ 1.276064] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.294536] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.314270] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 1.314303] dwmmc_rockchip 1021c000.rksdmmc: DW MMC controller at irq 48, 32 bit host data width, 256 deep fifo
[ 1.314321] dwmmc_rockchip 1021c000.rksdmmc: 1 slots initialized
[ 1.314696] rockchip-pinctrl 20008000.pinctrl: pin gpio0-3 already requested by 20056000.i2c; cannot claim for 10218000.rksdmmc
[ 1.314736] rockchip-pinctrl 20008000.pinctrl: pin-3 (10218000.rksdmmc) status -22
[ 1.314764] rockchip-pinctrl 20008000.pinctrl: could not request pin 3 on device rockchip-pinctrl
[ 1.314791] dwmmc_rockchip 10218000.rksdmmc: Error applying setting, reverse things back
[ 1.314927] dw cru_regsbase addr 0x124.
[ 1.314950] dw cru_reset_offset val 2.
[ 1.314975] dwmmc_rockchip 10218000.rksdmmc: Version ID is 270a
[ 1.315032] dwmmc_rockchip 10218000.rksdmmc: failed to get hpclk_mmc
[ 1.315621] dwmmc_rockchip 10218000.rksdmmc: Using external DMA controller.
[ 1.316002] dw_mci_init_slot: fmin=200000, fmax=37500000 [mmc1]
[ 1.316052] of_get_named_gpio_flags: can’t parse gpios property
[ 1.316372] rockchip-pinctrl 20008000.pinctrl: pin gpio0-3 already requested by 20056000.i2c; cannot claim for 10218000.rksdmmc
[ 1.316409] rockchip-pinctrl 20008000.pinctrl: pin-3 (10218000.rksdmmc) status -22
[ 1.316437] rockchip-pinctrl 20008000.pinctrl: could not request pin 3 on device rockchip-pinctrl
[ 1.316466] dwmmc_rockchip 10218000.rksdmmc: Error applying setting, reverse things back
[ 1.316493] dwmmc_rockchip 10218000.rksdmmc: mmc1: Idle pinctrl setting failed!
[ 1.316532] rockchip-pinctrl 20008000.pinctrl: pin gpio0-3 already requested by 20056000.i2c; cannot claim for 10218000.rksdmmc
[ 1.316565] rockchip-pinctrl 20008000.pinctrl: pin-3 (10218000.rksdmmc) status -22
[ 1.316593] rockchip-pinctrl 20008000.pinctrl: could not request pin 3 on device rockchip-pinctrl
[ 1.316619] dwmmc_rockchip 10218000.rksdmmc: Error applying setting, reverse things back
[ 1.316647] dwmmc_rockchip 10218000.rksdmmc: mmc1: Default pinctrl setting failed!
[ 1.316879] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.333891] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.343805] dwc_otg_hcd_suspend, usb device mode
[ 1.353598] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.353704] dwmmc_rockchip 10218000.rksdmmc: DW MMC controller at irq 47, 32 bit host data width, 256 deep fifo
[ 1.353738] dwmmc_rockchip 10218000.rksdmmc: 1 slots initialized
[ 1.354121] leds-gpio leds.15: pins are not configured from the driver
[ 1.354183] of_get_named_gpio_flags exited with status 55
[ 1.354209] of_get_named_gpio_flags exited with status 54
[ 1.354230] of_get_named_gpio_flags: can’t parse gpios property
[ 1.354253] of_get_named_gpio_flags exited with status 55
[ 1.354499] of_get_named_gpio_flags exited with status 67
[ 1.354812] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.359153] usbcore: registered new interface driver usbhid
[ 1.359181] usbhid: USB HID core driver
[ 1.360061] zram: Created 1 device(s) …
[ 1.360929] ashmem: initialized
[ 1.361295] logger: created 256K log ‘log_main’
[ 1.361607] logger: created 256K log ‘log_events’
[ 1.361907] logger: created 256K log ‘log_radio’
[ 1.362226] logger: created 256K log ‘log_system’
[ 1.364053] of_get_named_gpio_flags exited with status 119
[ 1.364085] of_get_named_gpio_flags exited with status 119
[ 1.364689] input: rk29-keypad as /devices/2006c000.adc/key.19/input/input1
[ 1.367555] This platfrom have not i2s_mclk,no need to set i2s_mclk.
[ 1.368202] rockchip-spdif 10204000.spdif: spdif ready.
[ 1.369158] audio-rk312x audio-rk312x.14: ASoC: CODEC (null) not registered
[ 1.369254] platform audio-rk312x.14: Driver audio-rk312x requests probe deferral
[ 1.370837] rockchip-hdmi-spdif rockchip-hdmi-spdif.13: rk-hdmi-spdif-hifi ↔ 10204000.spdif mapping ok
[ 1.372374] u32 classifier
[ 1.372403] Actions configured
[ 1.372428] Netfilter messages via NETLINK v0.30.
[ 1.372556] nf_conntrack version 0.5.0 (15976 buckets, 63904 max)
[ 1.373512] ctnetlink v0.93: registering with nfnetlink.
[ 1.373655] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 1.373679] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 1.374490] xt_time: kernel timezone is -0000
[ 1.375035] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.375403] arp_tables: (C) 2002 David S. Miller
[ 1.375507] TCP: cubic registered
[ 1.375529] Initializing XFRM netlink socket
[ 1.376245] NET: Registered protocol family 10
[ 1.377613] mip6: Mobile IPv6
[ 1.377686] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.377995] sit: IPv6 over IPv4 tunneling driver
[ 1.378913] NET: Registered protocol family 17
[ 1.378982] NET: Registered protocol family 15
[ 1.379135] Bridge firewalling registered
[ 1.379169] Ebtables v2.0 registered
[ 1.379530] Bluetooth: RFCOMM TTY layer initialized
[ 1.379626] Bluetooth: RFCOMM socket layer initialized
[ 1.379651] Bluetooth: RFCOMM ver 1.11
[ 1.379673] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.379693] Bluetooth: BNEP filters: protocol multicast
[ 1.379725] Bluetooth: BNEP socket layer initialized
[ 1.379749] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.379780] Bluetooth: HIDP socket layer initialized
[ 1.379854] l2tp_core: L2TP core driver, V2.0
[ 1.379893] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.379914] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.380176] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.382170] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 1.382224] rk312x_init_suspend
[ 1.382242] rk312x_suspend_init
[ 1.382614] Registering SWP/SWPB emulation handler
[ 1.383988] rk818_ldo8: disabling
[ 1.385019] rk818_ldo4: disabling
[ 1.385776] regulator-dummy: disabling
[ 1.386572] audio-rk312x audio-rk312x.14: ASoC: CODEC (null) not registered
[ 1.386674] platform audio-rk312x.14: Driver audio-rk312x requests probe deferral
[ 1.386770] =======================================================
[ 1.386798] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 1.386818] =======================================================
[ 1.386839] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
[ 1.387028] dhd_module_init: in
[ 1.387055] ======== bcm_wlan_set_plat_data ========
[ 1.387076] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.387097] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: rfkill-wlan driver has not Successful initialized
[ 1.387119] host_oob_irq: -1
[ 1.387136] host_oob_irq_flags=4
[ 1.387152] dhd_wifi_platform_load: Enter
[ 1.387197] Power-up adapter ‘DHD generic adapter’
[ 1.387263] pcd_pullup, is_on 0
[ 1.387283] wifi_platform_set_power = 1
[ 1.387297] ======== PULL WL_REG_ON HIGH! ========
[ 1.387311] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.387325] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized
[ 1.387469] file system registered
[ 1.389586] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 1.389619] android_usb gadget: Number of LUNs=2
[ 1.389643] lun0: LUN: removable file: (no medium)
[ 1.389664] lun1: LUN: removable file: (no medium)
[ 1.390156] android_usb gadget: android_usb ready
[ 1.390347] sensor_init: Probe name sensors
[ 1.390391] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 1.392035] rtc_hym8563 0-0051: hctosys: invalid date/time
[ 1.402991] usbcore: registered new interface driver snd-usb-audio
[ 1.403025] ALSA device list:
[ 1.403044] #0: RK-HDMI-SPDIF
[ 1.403932] Freeing unused kernel memory: 360K (c0ba7000 - c0c01000)
[ 1.589740] wifi_platform_bus_enumerate device present 1
[ 1.589770] ======== Card detection to detect SDIO card! ========
[ 1.589793] mmc1:mmc host rescan start!
[ 1.806204] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc1]
[ 1.855418] mmc_host mmc1: Bus speed (slot 0) = 37500000Hz (slot req 300000Hz, actual 297619HZ div = 63)
[ 1.855463] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 600000Hz for init[mmc1]
[ 1.904604] mmc_host mmc1: Bus speed (slot 0) = 37500000Hz (slot req 200000Hz, actual 199468HZ div = 94)
[ 1.904650] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 400000Hz for init[mmc1]
<30>[ 2.392670] udevd[124]: starting version 175
[ 3.154270] EHCI: rk_ehci_hcd_enable, disable host controller
[ 3.557727] failed to power up DHD generic adapter, 0 retry left
[ 3.573676] wifi_platform_set_power = 0
[ 3.573703] ======== PULL WL_REG_ON LOW! ========
[ 3.573724] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 3.573745] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized
[ 3.573769] wifi_platform_bus_enumerate device present 0
[ 3.573788] ======== Card detection to remove SDIO card! ========
[ 3.573811] mmc1:mmc host rescan start!
[ 3.573855] failed to power up DHD generic adapter, max retry reached**
[ 3.573920] unregister wifi platform drivers
[ 3.573945] wifi_platform_bus_enumerate device present 0
[ 3.573966] ======== Card detection to remove SDIO card! ========
[ 3.573988] mmc1:mmc host rescan start!
[ 3.574017] dhd_module_init: Failed to load the driver, try cnt 0
[ 3.574082] dhd_module_init: Failed to load driver max retry reached**
[ 3.574104] dhd_module_init: Exit err=-19
[ 5.752062] rk818-battery rk818-battery: changed: dsoc=0, rsoc=0
[ 6.745897] rk818-battery rk818-battery: changed: dsoc=0, rsoc=0
[ 6.746881] rk818-battery rk818-battery: set charge to digital termination mode
[ 9.117333] [otg id chg] last id -1 current id 256
[ 9.117393] PortPower off
[ 9.216831] Using Buffer DMA mode
[ 9.216869] Periodic Transfer Interrupt Enhancement - disabled
[ 9.216894] Multiprocessor Interrupt Enhancement - disabled
[ 9.216915] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 9.216933] ^^^^^^^^^^^^^^^^^Device Mode
[ 9.710086] vbus detect**
[ 475.365725] rknand_init:
[ 1022.329110] rk30xxnand_ko: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 1050.525504] rknand_init:
[ 1058.495424] rknand_init:
[ 1062.278718] rknand_init:
Any Ideas??
It’s due to the GPIO2_A3.
@Bootloader(uboot): the official release @ FirePrime_Ubuntu15.04_201603030939.img
It shows MESSGAE @ Fireprime to indicate that its “customize” ubbot
Pull-High this pin cause NANDFlash (R/W error)
Debug console shown as below
@Bootloader(uboot)#
id block not found.
prog error: = 3fcc53
prog error: = 3fcc54
prog error: = 3fcc55
prog error: = 3fcc56
@Linux(Kernel + Initrd)
Plat-Arch-204学習ガイドの高品質と高効率は、同じ業界の製品で際立っています。私たちの教材は常にユーザーのために考慮されています。 Plat-Arch-204試験問題を選択すると、より良い自己になります。 Plat-Arch-204実際の試験では、輝かしい未来に貢献したいと考えています。私たちの教材は常に改善されています。良いアイデアがあれば、私たちの教材は喜んで受け入れます。 Plat-Arch-204試験資料は、このファミリーに参加するパートナーを増やすことを楽しみにしています。私たちは一緒に進歩し、より良くなります。
I really appreciate your article, it had a profound impact on me. Enhance your IT abilities and access New CDFOM test preparation for free. Wishing you the best!
I’m really thankful for your article, it’s truly unforgettable. The Organizational-Behavior reliable exam syllabus materials are first-rate, and they’re available for free.
多くの候補者がCGSSのソフトウェアテストエンジンに興味を持っています。 このバージョンはソフトウェアです。 オンラインでパソコンにダウンロードしてインストールした場合、他の電子製品にコピーしてオフラインで使用できます。 CGSSのソフトウェアテストエンジンは非常に実用的です。 電話、iPadなどで使用できます。 いつでもどこでも勉強できます。 PDFバージョンと比較して、ACAMS CGSSのソフトウェアテストエンジンは、実際の試験シーンをシミュレートすることもできるため、実際の試験に対する気分を克服し、気軽に試験に参加できます。
