Resolution detection not working
I am completely new to the Rk3288-world, so I may be doing something wrong here but I cannot seem to connect my Firefly-Rk3288 Reload to any monitor properly:
  • When I connect it to an old 720p tv I get something that looks like overscan so the edges of the screen fall off and the screen is very blurry.
  • When I connect it to an 1080p screen I get 720p resolution.
  • When I connect to a 4k tv I get 720p resolution.
In the monitor resolution settings I can’t change away from 720p, and the Linux tool xrandr doesn’t do anything either. It does not make a difference if I use the HDMI 2.0 or the 1.4 port.
How can I get resolution detection to work properly?
which firmware did you use?
Did you try this one ?
http://bbs.t-firefly.com/forum.php?mod=viewthread&tid=1796&extra=page%3D2
I am using the original firmware that came with my Reload board, which is a dual boot with Android 5.1.1 and Ubuntu 14.04 with kernel version 3.10.0. On the Google Drive I can’t find a firmware for the Reload board newer than march 14 - can I use a firmware from the HardwareVersion-2014.09.30 folder? Because in the topic you linked it says the Reload board is not supported in kernel 4.4 yet?
Yes, you can .
there are a lot of similarities between this two hardware.
If flash the firmware I specified ,one of the HDMI should be working properly.
Thank you, this firmware indeed works much better. However, 4k support is still not good (about 1/3rd of the screen does not work) and indeed only 1 HDMI port works kind of - sometimes I have to turn the screen off and on after a display mode change (such as when the desktop environment loads).
hi wouter :
this firmware support two display, VGA and HDMI ,And the hdmi use the VOP little ,so it can’t support 4K.
We will build a firmware for you which support 4K display with HDMI.
I will let you know when the firmware is ready.
Hi wounter:
try this:
https://drive.google.com/file/d/0B7HO8lbGgAqAT3hYUnJjbzZjUEE/view?usp=sharing
Yes, HDMI works much better on this version. One thing that is still broken with the HDMI support though, is unplugging the HDMI monitor and plugging a different one in at runtime. Although this is not a requirement for our purposes, it is really annoying when testing things.
A different issue that I am having with both of these images is that Chromium browser is very slow, I think because it does not use hardware acceleration. Playing videos in the browser does not work at all. For our purposes this really needs to work properly.
hi wouter
yes ,the chromium browser have not supported video accelerate yet.we have only support video accelerate with VAAPI (h264 only) for now.
we will support more format like mpeg4 h265 h263 ..etc , and add these to browser.but it will take some times to do this.
Sorry for that.
Do you have some sort of road map or time estimate for when this is actually usable?
if evething goes well,we plan to release a version in the next july.
What a brilliant piece of writing, thank you for sharing it. Please wish me luck as I face the HPE7-A08 exam vce exam!
Unser ZertPruefung stellt Ihnen die besten Fragen und Antworten zur Pegasystems PEGACPSSA25V1 Zertifizierungsprüfung zur Verfügung und führt Ihnen schrittweise zum Erfolg. Die Schulungsunterlagen zur Pegasystems PEGACPSSA25V1 Zertifizierungsprüfung von ZertPruefung werden Ihnen eine reale Prüfungsvorbereitung bieten. Sie sind ganz zielgerichtet. Sie werden sicher ein IT-Expert werden. Unsere Pegasystems PEGACPSSA25V1 Schulungsunterlagen sind Ihnen am geeignetesten.Tragen Sie doch in unserer Website ein. Sie werden sicher etwas Unerwartetes bekommen.
IT인증시험은 국제적으로 인정받는 자격증을 취득하는 과정이라 난이도가 아주 높습니다. Salesforce인증 B2C-Commerce-Architect시험은 IT인증자격증을 취득하는 시험과목입니다.어떻게 하면 난이도가 높아 도전할 자신이 없는 자격증을 한방에 취득할수 있을가요? 그 답은Itcertkr에서 찾을볼수 있습니다. Itcertkr에서는 모든 IT인증시험에 대비한 고품질 시험공부가이드를 제공해드립니다. Itcertkr에서 연구제작한 Salesforce인증 B2C-Commerce-Architect덤프로Salesforce인증 B2C-Commerce-Architect시험을 준비해보세요. 시험패스가 한결 편해집니다.
Your article is absolutely mesmerizing, thank you for sharing! We offer free access to OMG-OCSMP-MBF200 practice exam fee, filled with material meant to help you succeed.
