Take the apk of firefly official SDKas an example to simply introduce how to add third-party applications.
To find thisdirectory(vendor/firefly/firefly_assistant) in SDK, it should be the Fireflyofficial to add apk by their own, then use it as an example.
Steps:
1、Create a directory under the vendor, such as:
2、Put the apk and related library files into the directory, suchas: DLNARemoteService.apk libtchip-vinit.so
3、Create an Android.mk file:
vendor/firefly/firefly_assistant/Android.mk
The code:
LOCAL_PATH := $(my-dir)
include $(CLEAR_VARS)
LOCAL_MODULE := DLNARemoteService
LOCAL_MODULE_CLASS := APPS
LOCAL_MODULE_PATH := $(TARGET_OUT_APPS)
LOCAL_SRC_FILES := $(LOCAL_MODULE)$(COMMON_ANDROID_PACKAGE_SUFFIX)
LOCAL_CERTIFICATE := PRESIGNED
LOCAL_MODULE_TAGS := optional
LOCAL_MODULE_SUFFIX := $(COMMON_ANDROID_PACKAGE_SUFFIX)
include $(BUILD_PREBUILT)
Explanation:
LOCAL_MODULE :=DLNARemoteService (The name of APK)
LOCAL_MODULE_PATH :=$(TARGET_OUT_APPS) ( after compilation, apk in the directory (/ system / app /) )
4、Create a mk file, such as:vendor/firefly/firefly_assistant.mk
CUR_PATH := vendor/firefly/
# add remote for remoteservice
PRODUCT_PACKAGES += \
DLNARemoteService
PRODUCT_COPY_FILES +=$(CUR_PATH)/firefly_assistant/libtchip-vinit.so:system/lib/libtchip-vinit.s
Explanation:
PRODUCT_PACKAGES followed by apk names
PRODUCT_COPY_FILES followed by the path tothe library file
- device/rockchip/rksdk/device.mk to add:
includevendor/firefly/firefly_assistant.mk
The position aftercompilation:
out/target/product/rk3288/system/app/DLNARemoteService.apk
