Could not able to prepare a SDCARD for booting using Mainline Kernel (4.4 versi
I have a beelink R89 which can work with any firefly image ( at least all of them tested until now works ok). I ttried to prepare a SD card using 4.4 Mainline kernel but without success. The screen using HDMI remaine blank and No signal appear. Unfortunattely I don’thave UART - TTL connection so I don’t know what is wrong. The SD card image posted in download section works OK but it have 3.10 kernel. I was able to even replace the kernel with a 3.10 compiled one, and that works as well. However compiling 4.4 kernel I could not able to load it from sdcard. I used also method with parameter file, and also with extlink.conf, but without success. I tried to also use the image found in download section with linux and mainline kernel, but that image is not for SD card, so I slightly changed it, but again no luck.
Does anybody have an Mainline Kernel image that can boot from sdcard and works of course? I want to leave internal flash untouched in order to be able to boot android when the sdcard is not inserted.
Thank You very much
hi,spon901
look at here http://bbs.t-firefly.com/forum.php?mod=viewthread&tid=1777&extra=page%3D2
someone use mmind’s kernel4.4 boot from sdcard.
so ,there is no doult the mainline kernel can boot from sdcard. you have to make your uart debug wok,that is the right way to find your problem.
Hi, isle,
I agree with you. Uart debug is the right way. Unfortunately at this model uart2 is very difficult to solder. The pads are on the back board under the cpu without holes. And they are very very small. I don’t have right tools for this and I’am afraid if I try I’ll destroy the board. Uart 1 and Uart3 are very easy to solder but not UART 2 (the debug one). That’s whay I want to find a SDCARD image with 4.4 kernel, that somebody use it and works ok. I suspect that in my case the boot loader that should be written to the sdcard is not correct one. It works with 3.10 kernel, but not with 4.4 . So I suspect this is the reason.
I gained immense value from that article. The MS-900 Study Material resources are outstanding, and they come with no cost.
国際証明書を取得することが既に決まっている場合は、すぐにC11試験対策を購入する必要があります。当社の製品は、業界で最高品質の製品として認定されています。知り合いの紹介を通じてC11トレーニング資料を知っている場合は、C11の利点も知っておく必要があります。私たちのコンテンツとデザインは私たちに良い評判を築いてきました。私たちのユーザーは私たちのために喜んでボランティアします。これは素晴らしい製品だと想像できます!次に、C11実際の試験の最も代表的な利点を紹介します。これらの利点が必要なものであるかどうかを考えることができます!
This article is incredible, thank you for sharing it with us! Good vibes needed for the CFE-Law top dumps exam! Wish me luck!
