firmware flashing on RKM possible
Hello, I’am the prowd owner of a RKM MK902II which should have the same hardware as the rk3288 has anyone here some information on how to flash that device with the firefly ubuntu image?
The ubuntu imagfe is one image file and I presume it was ment for putting on a SD card but I would love to write it to flash.
hi
it is the same way flash Android image to your board.
Fast2test에서는 소프트웨어버전과 PDF버전 두가지버전으로 덤프를 제공해드립니다.PDF버전은 구매사이트에서 무료샘플을 다움받아 체험가능합니다. 소프트웨어버전은실력테스트용으로 PDF버전공부후 보조용으로 사용가능합니다. Lpi 인증010-160덤프 무료샘플을 다운받아 체험해보세요.
