Technical briefing for Firefly-RK3288-Reload: Updates firmware (27/12/2016)
Android 5.1 update:
1.HDMI 4kx2k 60fps YUV4:2:0
2.CABC ,Dynamically to reduce power consumption
3.YUV MIPI camera fix
4.GPU support Directx
5.Add OHCI,fix EHCI bug
6.HDMI HDCP2.2
7.IEP modify 4kx2k
8.fix RGA2 bug
9.uboot nand and ddr fix10.fix uart1 and uart permission
Ubuntu 14.04update:
3.Add OHCI,fix EHCI bug
4.HDMI HDCP2.2
5.IEP modify 4kx2k
6.fix RGA2 bug
7.uboot nand and ddr fix
Please refer to the Download Android SDK on wiki, and upgrade to the latest tag: Firefly-RK3288_Android5.1_201611251533
Android Firmware from google drive
Ubuntu 14.04 Firmware from google drive
DualBoot(Android&Ubuntu) Firmware from google drive
有很多途徑可以幫你通過Microsoft MB-920 認證考試的,選擇好的途徑也就是選擇了好的保障。Testpdf可以為你提供好的培訓工具,為您參加Microsoft MB-920 認證考試提供高品質的參考資料。Testpdf提供的考試練習題和答案是根據Microsoft MB-920 認證考試的考試大綱研究出來的。所以Testpdf提供的資料的品質很高,具有很高權威性,絕對可以盡全力幫你通過Microsoft MB-920 認證考試。Testpdf也會不斷提升更新我們提供的Microsoft MB-920 認證考試資料,來滿足您的需求。
I found this article very inspiring, thanks for sharing! Ready for the DEP-2025 prep guide exam – hope I pass with flying colors!
This article has helped me understand many complex concepts, and I’ve gained a lot. Free Reliable 300-815 test dumps test materials—the essential resource for your promotion and salary increase!
So good, I’m liking it without any delay. Level up your IT abilities with free New NCM-MCI exam questions pdf. Best of luck to everyone!
Itexamdump의 Microsoft인증 MB-500덤프의 무료샘플을 이미 체험해보셨죠? Itexamdump의 Microsoft인증 MB-500덤프에 단번에 신뢰가 생겨 남은 문제도 공부해보고 싶지 않나요? Itexamdump는 고객님들의 시험부담을 덜어드리기 위해 가벼운 가격으로 덤프를 제공해드립니다. Itexamdump의 Microsoft인증 MB-500로 시험패스하다 더욱 넓고 좋은곳으로 고고싱 하세요.
