Hi
Can Firefly Team add ExFat filesystem support to Firefly devices?
Lots of 1080p/4K videos are over 4GB in size and then Fat32 can’t be used any more.
Hi
No ,We can’t offer it unless your have solved the issue of copyright.
https://github.com/relan/exfat
that is the open source version of exfat for linux/unix/bsd ect.
it uses the FUSE filesystem driver and has actually been around in mainstream linux distro’s for quite some time so I’m not sure what copyright issues you are referring to, could you please explain?
the exFAT is belong to miscrsoft, if you haven’t bought the rights,you can’t add it in your android devices.
well perhaps it would be a good idea to add the FUSE support into the kernel so people who need different filesystem support can then install the required FUSE modules in the userspace?
Your article is outstanding; thank you for sharing it! The 2V0-11.25 latest exam price test questions are free for all—your key to a successful career!
No hesitation, this is deserving of a like. The free content in CSCP valid test sims is meant to help guide you through your studies.
