RK3399 linux - error no firefly_linux branch
Hi Firefly,
I want to experiment with the RK3399 linux kernel. I’ve followed the “build android” wiki in order to download the linux kernel sources up to the “git pull bitbucket master:master” command. And then I go to the kernel folder and type “git checkout firefly_linux”. This command fails because there’s no firefly_linux branch.
Could you check this on your side?
Also could you provide a “RK3399 linux only” git repo as you did for the RK3288 kernel?
And finally, wiki page “build android” refers to the SDK "firefly-rk3288_android4.4_git_20141211.tar.gz. Is it really the RK3288 archive which contains RK3399 stuff?
Sometimes ago Isle posted me a link to a 4.4 kernel:
https://github.com/T-Firefly/kernel_4.4
This repo does not seem to be well alive, the last commit on branch tchip dates Oct 9, 2016. Is it really the linux kernel that’ll be installed on your coming kickstarter firefly-rk3399 board ?
Thanks.
Hi FesterBester,
we are sorry for this mistake, the sdk is not ready yet . we will upload it in February or March,before we send the kickstarter firefly-rk3399 board to our backers.
isle Posted at 1/20/2017 09:52
Hi FesterBester,
we are sorry for this mistake, the sdk is not ready yet . we will upload it in …
OK, no problem, I’ll wait until then.
Happy new year.
This article is remarkable, thank you for sharing it with me. The extensive content in Latest Rev-Con-201 exam dumps free is offered free of charge to support you.
Fantastic content, I’m giving it a like without thinking twice. The Test NetSec-Pro king questions were instrumental in my promotion and raise, and I’m sharing them with you today at no cost!
DumpTOP의 도움을 받겠다고 하면 우리는 무조건 최선을 다하여 한번에 패스하도록 도와드릴 것입니다. 또한 일년무료 업뎃서비스를 제공합니다. 중요한 건 덤프가 갱신이 되면 또 갱신버전도 여러분 메일로 보내드립니다. 망설이지 마십시오. 우리를 선택하는 동시에 여러분은ACD201시험고민을 하시지 않으셔도 됩니다.빨리 우리덤프를 장바구니에 넣으시죠.
This article has given me a lot of space for reflection, and I’ve gained a lot. Best of luck with your exam preparations! L4M2 latest exam tips questions available for free!
お客様の暇が少ないので、勉強する時間が少ないことを考えています。CY0-001試験資料は便利で、覚えやすいです。また、もう一つの特徴は時間を節約することです。つまり、CY0-001試験資料を短い時間で勉強すると、CY0-001試験を受けることができます。大切なのはCY0-001試験資料の的中率が高いです。
クライアントが支払いに成功すると、システムが送信するGES-C01ガイドの質問に関するメールを受け取ることができます。これにより、テストバンクをダウンロードして、GES-C01 STUDY教材を5〜10分で使用できます。メールはリンクを提供し、クライアントがリンクをクリックすると、クライアントはログインして学習するGES-C01学習資料を取得できます。手順は簡単で、クライアントの時間を節約できます。クライアントにとって時間は限られており、非常に重要です。当社の製品は、お客様のGES-C01練習エンジンをすぐにダウンロードして使用するというニーズを満たします。
