When I push power button, nothing happen.
I can turn on this board only after push the power adaptor after pull the power adaptor.
This power button had problem?
the power button is design for sleep/wake the system(like android),
and the reset button is design for reboot the board,
I’m not quiet sure about your question,
So ,what is your problem? Could you supply more informations?
isle Posted at 2/18/2017 09:42
and the reset button is design …
when my board is in shut down.
I press power button. then, nothing happen.
but, I plug out usb port and then plug in usb port. then board boot successfully.
Hi
did you have anther board? if yes,did it has the same problem?
Which board did you have . the firefly-rk3288 or firefly-rk3288 reload?
and,which firmware did you use?
isle Posted at 2/23/2017 15:44
Hi
Which board did you have . the …
I have only one board.
What is the difference the firefly-rk3288 and firefly-rk3288 reload?
How can i find firmware version?
this is the firefly-rk3288:
http://shop.t-firefly.com/goods.php?id=5
and this is the firefly-rk3288 reload :
http://shop.t-firefly.com/goods.php?id=1
please check which one do you have.
which system do you have on your board? ubuntu or android?
isle Posted at 2/24/2017 09:43
and this is the firefly-rk328 …
My board is firefly-rk3288.
I use this board in ubuntu.
I think power button is not work.
Hi
have you tested it in android?
This article is fantastic, thank you for sharing this insight. 200-201 trusted exam resource offers free access to a wealth of helpful material, supporting your learning goals.
This article truly broadened my horizons; thank you for sharing! The Salesforce-Data-Cloud latest dumps free system helped me secure a promotion and salary increase. Now, I’m sharing it for free. Best of luck in your career!
PEGACPSSA24V1練習問題を買いたい場合、自分のメールアドレスを記入してください。そうすれば、支払ったら、すくお客様にPEGACPSSA24V1練習問題を送付できます。だから、それは重要な情報です。また、もしPEGACPSSA24V1練習問題は更新されましたら、弊社は最新版をお客様のメールボックスに送付致します。
I totally get why people are cautious about these novelty diploma services, some are just big names, nothing much. From experience, I have worked with a service that got me exactly what I wanted. I was able to get my high school transcripts, and you don’t have to worry about those random delays or sloppy work.
That article was a goldmine of information. The Free H35-210_V2.5 questions and answers test questions are free—good luck with your exam preparations!
